Jul 16, 2015, 10:59 AM
Have Guitar Will Travel
TravisBean's Avatar
New Product
New Blade 230 S
http://www.horizonhobby.com/blade-23...-blh1500#close
In these times of Walkera and others phasing out new heli designs in favor of quads, it seems like Blade is keeping the torch alive.
Description: Name: BLH1500_a16[1].jpg
Description:
Key Features
•Fully assembled, no building necessary
•SAFE® technology makes flight with a collective pitch helicopter easier
•Stability mode delivers the comfort of self-leveling and bank limits
•Progressive flight modes help your aerobatic skills build quickly
•Panic Recovery mode can recover the heli to a level attitude
•Collective pitch rotor system with flybarless mechanics
•Brushless main and tail motors for great power and response
•Impact resistant ABS main blades
•Tough, yet lightweight airframe
•Streamlined canopy with vivid color scheme
•Spektrum™ AR636 DSMX® receiver with AS3X® heli technology (installed)
•Durable, digital high-speed metal gear cyclic servos (installed)
•E-flite® 800mAh 3S Li-Po flight battery and charger (included)
•Spektrum DXe transmitter with DSMX® 2.4GHz technology (included)
•5–6 minute flight times
Needed To Complete
•Nothing! Everything you need is included in the box.
Overview
Take Your Heli Pilot Skills Higher
Collective pitch mechanics are a key element to learning sport aerobatics with a helicopter. When combined with the durability of a 230-size heli, pilots get the “wow” factor in an airframe that’s practical. Until now, learning with a collective pitch machine still had an intimidation factor. The Blade® 230 S collective-pitch electric heli is engineered to meet and go beyond the needs of the new heli pilot by offering a highly-tuned machine with innovative SAFE® technology so that it’s easy for any pilot to achieve first-flight success, prevent crashes and then move on into advanced flight, all with one heli.
Engineered around the abilities of innovative SAFE® technology, its progressive flight mode system makes flying the Blade® 230 S collective pitch heli more comfortable, even if you’re a beginner. Stability mode helps keep you in control with the safety of bank limits and self-leveling so it’s possible to fly and build pilot skills quickly. When you’re ready to progress your skills, Agility mode opens the flight envelope to explore basic aerobatics and 3D mode enables the 230 S to really come to life. In addition, Panic recovery mode allows you to recover the 230 S to level flight at the press of a button and prevent a crash. Durable features like ABS blades and metal-gear cyclic servos mean you can be flying more often than fixing. All combined, the 230 S is the heli you’ll want to fly whether you’re a new pilot or seasoned heli expert.
SAFE® Technology
The Blade® 230 S features exclusive SAFE (Sensor Assisted Flight Envelope) technology, a revolutionary electronic flight envelope protection system that makes it easy for anyone to fly helicopters with confidence. Flight mode versatility means that you can instantly choose the level of assistance and maneuverability that’s right for you. Plus you get the virtual protection of Panic Recovery mode that will recover the heli to a level attitude for you at the push of a button.
Three Flight Modes
•Stability mode—limited flight envelope with self-leveling and a bank angle limit
•Agility mode—full control authority for sport aerobatics with no bank angle limit
•3D mode—turns up the flip and roll rate for 3D capability
Panic Recovery Mode
1.Orientation is lost
2.Panic Recovery button is pressed
3.Recovery to a level attitude
Collective Pitch Rotor System
The collective pitch rotor mechanics of the 230 S have been engineered to give you just the right level of maneuverability for learning aerobatics and inverted flight.
Brushless Motors
The high-speed brushless main and tail motors work together to deliver a simplified drive system that makes the 230 S light weight so that it’s quick in response to your commands.
Metal Gear Servos
The 230 S comes equipped with the same 9-gram, digital metal gear servos used for cyclic control in high-performance Blade mini-helis like the 360 CFX.
Durable
The fiber-filled plastic main frame is incredibly resilient. ABS main blades, molded in bright-white material help with visibility and hold up better in a crash compared to wood blades.
DXe Transmitter
The all-new Spektrum™ DXe transmitter delivers the 6-channel control you need with the industry-leading precision of DSMX® 2.4GHz technology. When you’re ready to experiment with radio settings, just connect the DXe to your PC and adjust settings such as the expertly set Dual Rates and Exponential parameters to your liking.
Includes
◦Fully assembled Blade® 230 S helicopter
◦E-flite® 800mAh Li-Po Flight Battery
◦AC/DC Li-Po Battery Charger
◦Spektrum™ DXe Transmitter with DSMX® 2.4GHz Technology
◦4 × AA Transmitter Batteries
Jul 16, 2015, 11:06 AM
if it uses the same due esc as the 200 will need a mod
Jul 16, 2015, 02:19 PM
Landings are not optional!
W0WG's Avatar
Is this supposed to replace the Nano CP X ?
Jul 16, 2015, 02:21 PM
its the same rotor diameter as a 300CFX.
From the blade site, it looks like the main motor is 3800kv - not sure how the kv ratings work as the 180CFX is rated higher than the 300CFX - chances it'll be woefully underpowered?
Jul 16, 2015, 03:13 PM
Looks like a sport heli with advced features. DXe TX looks like Devo 7s type ?? give them credit they keep em coming. Hope it does well. I have two V200d03's bl/ Blade 300 X working on with upgrades. That said good form HH. blade does it again. Still Nano CP-X should not have been dropped. Great little heli and reasonable priced. Plus option of bl kit. 200 SR-X/ 180 CF-X/ 300 CF-X/ 360 CF-X good for you HH.
Jul 16, 2015, 03:38 PM
Glad to see someone still thinks there is a market for helicopters. Looks a bit like another attempt to hit the market segment that the Blade SR was aimed at. With advances in stability technology, lets hope this one does better than that one did. If nothing else, maybe the introduction of another heli in this size class will drive the price of the 180CFX down a bit!
Jul 16, 2015, 03:53 PM
Rookie
Excited about this. Seems like I can start my CP journey with this in beginner mode and slowly move my way up
Jul 16, 2015, 03:55 PM
I checked HH site. This is a c/p version of 200 SR-X. Twin bl motors so its motor driven tail. I guess repacement for SR model. Well another heli for some to wait for. Good for them anyway to bring another bird out. Wonder how long quad boys will last before sheer boredom kicks in ??
Jul 16, 2015, 04:23 PM
bvrrocks5150's Avatar
I saw the parts list.... It uses 300x head parts, 200srx tail rotor..... I'm going to cross reference some of the other part numbers later, just for curiosity's sake. I was looking at getting an Ares 300cp...... till I saw this 230s today. I wonder what else HH is up to?
Jul 16, 2015, 04:59 PM
Stupid Gravity
Man, i am so confused! i was all set to buy a 300CFX, just to get another "sport flying" helicopter (absolutely no interest in aerobatics) and along comes the 230S!!
its got to make a better sport flyer than the 300CFX, right!
i'm about an inch away from preordering!
Jul 16, 2015, 05:17 PM
Never let it down
Pachapapa's Avatar
I was looking for something a little bit smaller than a 250 (and bigger than a 180), here comes a 230 that is bigger than a 250
No problem, also interested
Jul 16, 2015, 05:32 PM
Rookie
Anyone have any idea when is this out?
Listed as preorder on the website
So glad I held off on getting a mcpx bl
Jul 16, 2015, 05:43 PM
the blade website says late august.
Also, they just put the video up -
Blade - 230 S Official Video (2 min 46 sec)
Jul 16, 2015, 05:48 PM
Stupid Gravity
you sound like me and my situation, 230S vs the mcpx bl, a sport heli vs a 3D heli, for me the 230S vs the 300CFX, a sport heli vs a 3D heli.
i really like the 300CFX, looks like a really solid heli, although i am only looking for a sport heli and i am kind of hesiitant because it could end up being like my mcpx bl, which behaves like a hummingbird on "crack".
Jul 16, 2015, 05:55 PM
Both of your situations sound like mine; my super CP is ready for the garbage and I was debating a MCPX BL or a 180CFX until this was announced. My 3D skills are extremely beginner level and while the 180CFX may be "more" heli for the money, it isn't worth it if I'm constantly wrecking it trying to learn 3D. The 230S's panic button coupled with its larger size and supposedly robust (metal gear servos!) build make it sound like the ideal choice for an outdoor sport flying / basic 3D heli. Now I just need to decide whether to go BNF and get a DX6i or go the convenient route and get the RTF....
WhiteCloud - the rotor diameter on this should put it very close in size to a 300CFX
Sold Blade 230 S BNF Brand New!!! tico30 Aircraft - Electric - Helis (FS/W) 3 Feb 26, 2017 02:48 PM
For Sale Blade 230 S BNF Brand New!!! tico30 Aircraft - Electric - Helis (FS/W) 0 Jan 05, 2017 04:36 PM
Sold Blade 230 S BNF Brand New!!! tico30 Aircraft - Electric - Helis (FS/W) 0 Jan 03, 2017 04:04 PM
Sold Blade 230 S - Like new yakky Aircraft - Electric - Helis (FS/W) 2 Oct 10, 2016 03:57 PM
Sold Blade Night 230 S BNF Basic with SAFE® Technology Like NEW baddb1 Aircraft - Electric - Helis (FS/W) 1 Aug 12, 2016 01:14 PM
