This thread is privately moderated by smoothvirus, who may elect to delete unwanted replies.
Jul 12, 2015, 02:31 PM
smoothvirus's Avatar
Mini-Review
NEW Finwing Sabre 1900 - Full Review and Build Log
The Sabre will soon be the newest model of FPV aircraft from Finwing, known for their excellent Penguin FPV plane. Finwing graciously sent a pre production sample of this new plane for me to review. I only received the airframe kit so all the electronics I am installing in it are my own. I'll be using the Eflite Power 25 for a motor since I have a spare one in the shop.
Parts List:
Finwing Sabre 1900 FPV/UAV Elite - Basic
http://www.finwing.cn/goods.php?id=53
Finwing 390 Mini Pan & Tilt
http://www.finwing.cn/goods.php?id=64
RMRC - 1.3GHz 800mW* Transmitter - US VERSION
http://www.readymaderc.com/store/ind...roducts_id=914
VAS - 1.3 GHz Airscrew Ultra Antenna RHCP
http://www.readymaderc.com/store/ind...oducts_id=3611
Transmitter Cable (Large Plug)
http://www.readymaderc.com/store/ind...roducts_id=357
EZUHF 8 Channel Lite Receiver
http://www.readymaderc.com/store/ind...roducts_id=715
Eagle Tree - Vector FPV Controller Package
http://www.readymaderc.com/store/ind...oducts_id=2307
Vector Airspeed Expander with Pitot
http://www.readymaderc.com/store/ind...oducts_id=2991
Scorpion SII-3020-890 V2 Brushless Motor
http://www.rcdude.com/Scorpion-SII-3...i-3020-890.htm
60-Amp Pro Switch-Mode BEC Brushless ESC
http://www.e-fliterc.com/Products/De...rodID=EFLA1060
Xoar 11x5 PJN Electric Series Beechwood Propeller
http://www3.towerhobbies.com/cgi-bin...&I=LXAPTK&P=SM
RunCam 600TVL Plastic Housing FPV Camera - US
-note: the plastic housing for this camera will not fit inside the Finwing Mini Pan & Tilt!
http://www.securitycamera2000.com/pr...-%252d-US.html
Hitec HS-85MG x3 (ailerons and elevator)
http://www.readymaderc.com/store/ind...oducts_id=1197
Penguin 9g Servo x3 (Rudder and Flaps)
http://www.readymaderc.com/store/ind...oducts_id=1082
CP Laminating Film - 3 Mil x 18"
http://www.alofthobbies.com/new-stuf...ing-films.html
2 WWII Flying Tigers P-40 Warhawk Nose Art Decals
https://www.etsy.com/listing/2210320...f=sr_gallery_1
RangeVideo anti-vibration mount
http://www.rangevideo.com/vibration-...ion-mount.html
Reference:
Finwing Intro Video 1
Finwing sabre FPV UAV Aircraft First look Part1 (3 min 12 sec)
Finwing Intro Video 2
Finwing sabre FPV UAV Aircraft introduction Part2 (3 min 29 sec)
RCGroups Thread
https://www.rcgroups.com/forums/show....php?t=2436088
spectre909 Build Videos (playlist)
https://www.youtube.com/playlist?lis...8xAnN1vq0oXoIx
Compare to:
Skywalker 1900
Volantex Ranger EX
Sky Hunter
Jul 12, 2015, 02:32 PM
What Comes in the Box
I can't believe that they got a plane this big in a box that small! Once again I was impressed with the quality of Finwing's kits and how well thought out everything is.
Jul 12, 2015, 02:33 PM
The Build
It looks to be a fairly straight forward build. If you've put together an EPO plane before you shouldn't have any issues.
Jul 12, 2015, 02:34 PM
The Maiden Flight
Finwing Sabre Review Part 1 Intro and Maiden Flight (12 min 29 sec)
FPV Flight
Finwing Sabre Review Part 2 FPV Flight and Final Thoughts (9 min 50 sec)
Jul 12, 2015, 07:22 PM
Crazy Canuck
NEWBEFLYER's Avatar
Subscribed .........................reserved what happened? or are you keeping it under wraps for now.
Hope it turns out OK
Jul 12, 2015, 07:42 PM
Lol nothing happened yet I just saved that spot so I'll have all the important stuff at the start of the thread. She's still being assembled in my basement.
Jul 13, 2015, 01:17 PM
ATC Chilli's Avatar
Looking forward to the review. I'm a FPV fan but not so much the quads. Been looking for a good fixed wing platform.
What kind of foam is used?
Jul 13, 2015, 01:29 PM
It's EPO foam, the same as the Penguin and Air Titan. The nice thing about EPO is that you can use regular CA on it without damaging the foam.
Jul 14, 2015, 10:05 AM
Ran into some issues last night with the Eflite Power 25 motor. It's from my T-34 that crashed, and the shaft got bent. I have a replacement shaft for it already. I tried to replace the shaft last night and got the first two grub screws out but now the third is jammed in there and I stripped it trying to remove it.
I'll work on getting the jammed grub screw out and replacing the shaft. If worst comes to worst there are more efficient motors I can get for the Sabre, I'm using the Power 25 because I had it lying around the shop waiting for a new project.
Jul 14, 2015, 01:55 PM
ATC Chilli's Avatar
Is that the same foam Multiplex uses??
Jul 14, 2015, 02:22 PM
Multiplex uses something called "Elapor". From what I understand it is pretty much the same thing as EPO.
Jul 16, 2015, 04:47 PM
Crazy Canuck
NEWBEFLYER's Avatar
I know how difficult it is to get those ever so tiny screws out of the motors when they are stripped or the head part is worn out. I used a micro drill bit and do a reverse drill and pop it out.
What FPV system you putting in it? Also what will be the total weight of it.
SO HURRY UP AND BUILD IT!! LOL
Oh and have fun with it.
Jul 17, 2015, 06:54 AM
Yeah I still can't get that grub screw out. At this point I'm very close to ordering a Scorpion motor. They're really expensive but super efficient.
Jul 21, 2015, 01:59 PM
I pulled the trigger on the Scorpion motor this morning and updated the Parts List.
