New F3P Sequences for 2016/2017 - RC Groups
Jul 12, 2015, 12:16 PM
Jurgen Heilig's Avatar
Hello Indoor Pilots,
the FAI has published new F3P sequences for 2016/2017. For the first time, there is now also an "official" sequence for entry level/advanced pilots - basically a simplified F3P AP-17 version.
As usual I use the FAI sequences as guidelines for the F3P-Sport and F3P-Expert programmes at the DMFV German Indoor Aerobatics Championships.
The new AA-17 appears much easier to perform than the previous national F3P-B/ -Sport sequence (for years, competitors have been flying a "Horizontal Circle with a single roll integrated"). In AA-17, the maneuver with the highest K-factor (K=6) is now supposed to be a simple "Horizontal Eight" (which was flown at entry level in Indoor competitions since 2001).
I was considering the following changes for the DMFV F3P-Sport sequence (changes marked in RED):
The stall turn will be flown exactly the same as the first stall turn in AP-17 and ends after leveling off. This enables the pilot to fly the "Double Immelmann" in the middle of the hall (as in AP-17) and position the model for the "Horizontal Eight" either in the front or the back of the hall.
For the "Half Rectangular" I considered adding a full roll.
The "Half Circle" could be flown in "Knife Edge". For pilots who have been flying rolling circles with integrated rolls for years, this will still be very easy.
The "Alternative Torque-Roll" could be made mandatory (as it was a mandatory manoeuvre in the previous F3P-B/ -Sport sequences).
The K-Factors should be modified, to reflect the actual difficulty level of the manoeuvres:
Stall Turn - K=2 (instead of 3)
Horizontal Eight - K=3 (instead of 6)
Humpty-Bump - K=2 (instead of 3)
Cobra-Roll - K=3 (instead of 5)
Torque-Rolle - K=4 (instead of 5)
1/2 Square Loop - K=2 (instead of 3)
New total K=31 (instead of 40) makes the difference in difficulty level compared to AP-17 (total K=42) more visible.
Those were my thoughts so far ...
If the main goal of the new FAI F3P sequences however is "to increase the number of F3P competitors", some of my modifications may be partially counterproductive.
In this case I would just modify the stall turn for The DMFV F3P-Sport sequence and adjust the K-factors. You could even go a step further and replace the torque-roll by a simple vertical roll, establish a minimum weight limit, and ban coax-drive systems for the entry level sequences.
Your comments are much appreciated!
So far, the details for the 15th. German Indoor Arobatics Championship are still in a draft status.
Best regards,
Jürgen
Jul 14, 2015, 11:43 AM
Nice balance between entry and expert level. It allows F3P-C pilots to step up to the national classic without being too much of a hassle.
I woud not restrict the minimal weight, nor prohibit the use of mylar covered models or coax driven models in the national class though.
I think it is a good idea to limit the min. weight and forbid the use coax in the entry level class (F3P-C). This allows novice pilots to compete with 'equal' commercially available weapons. After a couple of seasons in novice level pilots will want to fly more sophisticated and more expensive models. In most cases they will step up the national class at the same time.
Aug 25, 2015, 02:12 PM
Hi together,
first trainings of new indoor program F3P AP-17 in a hall of 6-7m height.
F3P carbon model Novus
2S coaxial-system SG CRE 02 V9 + 13" props
120 mAh GensAce battery
span 850mm
lenght 1050
Sergej Glavak Training F3P AP-17 (4 min 0 sec)
Regards
Sergej Glavak
Aug 25, 2015, 11:11 PM
Soft control, very good-looking!
Aug 27, 2015, 01:03 AM
Originally Posted by Glavak
Hi together,
span 850mm
lenght 1050
Hallo Sergej,
das schaut doch schon recht gut aus. Bei der Figur M hast Du einmal nach links und einmal nach rechts gedreht. Ein Modell mit Koaxial Antrieb sollte nach beiden Richtungen gleich gut drehen. Für alle: Die Drehrichtung ist nicht vorgegeben.
Jürgen
Aug 28, 2015, 08:47 PM
Sergej, I don't know what Jurgen said but i thought it looked pretty nice!
What did your model weigh?
Vince
Aug 29, 2015, 12:58 AM
I don't want to "Switch Now"
pmackenzie's Avatar
Vince
Pretty much what you said, according to Google translate
looking but already quite good . In the figure, M You once left and once turned to the right . A model with coaxial Drive should run well in both directions equal . For all : The direction of rotation is not specified.
Aug 29, 2015, 06:42 AM
Hi guys,
Thanks for your kind words.
@ Vince
The weight of model is 53g ... it was my first carbon model.
There is still potential to build model lighter ;-) ... especially painting was quite heavy (3,2g).
For the frame I have used 0,5mm carbon rod, for reinforcements 0,3mm carbon rod and for chassis 1mm tube.
Regards
Sergej
Oct 25, 2015, 06:23 PM
Hi together,
trainings indoor program F3P AF-17 (draft) in a hall of 6-7m height.
weight of model 53g RTF
span 850mm
lenght 1050
Training F3P AF-17 (draft) (4 min 35 sec)
Regards
Sergej
Oct 30, 2015, 03:17 AM
Lantsov Alexey's Avatar
Hi Serёga .
AF-17. 06 your flight has no two 1/2 reverse on the vertical
http://www.fai.org/ciam-documents
AF-17.06 Knife-Edge Top Hat with two consecutive ½ rolls, two consecutive ¼ rolls
From upright, pull through a ¼ loop into a vertical upline, perform consecutively two ½ rolls in opposite direction, perform a ¼
knife-edge loop into a horizontal knife-edge flight, perform a ¼ knife-edge loop into a vertical downline, perform consecutively two
¼ rolls, push through a ¼ loop, exit inverted.
Nov 09, 2015, 04:55 PM
Sergej,
Can you post some photos of your model?
Vince
Nov 22, 2015, 10:12 PM
AP+AF-2017
VICTORY -1SL .
AL12-80 coaxial system
https://yadi.sk/i/J8A-FN2okeq2z
Nov 22, 2015, 10:33 PM
Yandex player heavily compresses, it is advisable to download and view
