Try to build Tiger Moth Balsa kit - RC Groups
Jul 02, 2015, 02:37 AM
Build Log
Hi, Everyone
I'm just a new ,recently I bought one piece of balsa kit--Tiger Moth.
Maybe I'm not experienced in assembling.
Ok, let's begin.
I unpacked the kit on 2015-6-20. I found this drawing.
Jul 02, 2015, 02:41 AM
See inside of the box.
So many parts !
Jul 02, 2015, 02:42 AM
First, Let's get them out !
Jul 02, 2015, 02:44 AM
List all parts here
List all parts here
Jul 02, 2015, 02:19 PM
Garyss's Avatar
Well, you didn't pick the most newby friendly kit to start with. But, at least it is laser cut so the parts fit might be good. Get some thin & medium CA glue. Make absolutely sure you have a flat building surface and make each assembly FLAT on that surface. Don't drown each glue joint. If you want a nice looking model try to not get glue on the top surface of the wood where you eill apply covering. You probably will get some tho. You will have to sand that wood smooth (400 - 600grit ) at the end.
I'm done for now........others please add!
Jul 02, 2015, 11:39 PM
Ok, maybe I should pick a friendly kit to start. But now I have to go on.
It seems you are very experienced in it. Hope you can reply continuously.
Jul 03, 2015, 09:27 AM
Garyss's Avatar
If you see blacked edges on the various parts from the laser cutting you could lightly sand that off. This would be on the outer edges where your covering will attach. The black could show through! Take great care to not change the shape of the piece. If the black does not come off then it is best to just leave it.
Draw a long straight line on a paper as long as your fuselage. Place the unglued fuse (may need to use a few rubber bands to hold it together) on this line to verify the fuse will be straight before the final glue.
BTW what kit? Engine/motor? Covering method?
Jul 06, 2015, 04:48 AM
reply
Tiger Moth Kit
GP and EP are ok. you can choose GP or EP.
Jul 07, 2015, 12:05 PM
I am a nice guy! Really!
Yup, a Tiger Moth kit. We were able to glean that from your thread tittle. I think more than one of us want to know the maker of the kit.
Latest blog entry: $3 Wattmeter
Jul 07, 2015, 10:51 PM
go on
go on
Jul 08, 2015, 09:08 AM
What is the brand of the kit you are building?
In other words who made it? What company manufactured it? By whom was it made?
Jul 08, 2015, 12:01 PM
Joe Pierson's Avatar
Looks nice, where did you buy the kit?
Jul 09, 2015, 09:04 PM
God is my pilot
JimTMich's Avatar
Enquiring minds want to know
Jul 12, 2015, 10:38 PM
manufacture
It's manufactured by ELERC. Email: elerc@elerc.com
