Dec 03, 2016, 03:56 PM
Marabu II
Modification 1
Separate connections of the two struts instead of one.
Was easier to build and the struts together are stronger.
Dec 03, 2016, 04:03 PM
Marabu II
Modification 2
At the bottom of the tail I made an opening for easyer access to the connection of the rudder.
Dec 03, 2016, 04:10 PM
Marabu II
Modification 2
extra photo
Dec 04, 2016, 01:46 AM
ultralajt's Avatar
Originally Posted by De Charel
Hallo Mitja
Marabu II is ready.
Started building medio of july.
De Charel from The Netherlands
Hi! Nice to see another Marabu ready for the flight!
You did a great job! It is almost as mine, but much prettier!
Modifications on the wing struts and opening at the bottom fuselage are really an very clever upgrade and came very handy at assembly of the model!
I wish you better weather soon and happy maiden!
Regards!
Mitja
Dec 04, 2016, 06:49 AM
Modification 3
Ball Coupler at tail for easy connection
Dec 04, 2016, 07:42 AM
Balance point
Carbon rod for balancing can be demontabled.
Dec 04, 2016, 08:29 AM
Triangel plywood in cockpit window
In the cockpit the windowfront is fastened on a plywood triangel so the cockput is is with light corners.
The opening to the battery is closed with magnet 10mm.
Dec 04, 2016, 01:41 PM
Showtime
Dec 17, 2016, 11:46 AM
Svede's Avatar
Too cool!
Feb 15, 2017, 09:26 AM
ultralajt's Avatar
My first flight this year...
First in 2017 (1 min 16 sec)
Feb 15, 2017, 02:42 PM
Sometime plane and heli flyer.
n0bbyUK's Avatar
Nice, jealous...I've not flown mine since its maiden 😞
Sent from my HUAWEI VNS-L31 using Tapatalk
Feb 19, 2017, 04:04 AM
ultralajt's Avatar
You should take some free time to fly Marabu!
It is so easy and fun!
Feb 22, 2017, 06:57 AM
n0bbyUK's Avatar
I know Mitja, but moved house 5 months ago and not joined a local club yet and no big fields near me to fly in Also too busy building hot foam cutters (CNC upgrade in the future....) and VAC forming machine to make another Guppy MS....
Feb 24, 2017, 02:14 PM
n0bbyUK's Avatar
See Mitja....vac former (glueing with weights on) and hot wire cutter....I will be flying my Marabu soon though, need a flying fix!
Feb 24, 2017, 02:48 PM
ultralajt's Avatar
Hehe, clever hotwire cutter temperature regulator!
