Jun 21, 2015, 06:43 AM
SAR
New Product
Volantex Ranger 757-4 FPV 1380mm Plane Unboxed
The Volantex Ranger FPV Series known to have lots of room for FPV gears and durability, now has a smaller siblings at 1380mm. Fits better in our cars. We hope to have it fully tested shortly and loaded up for SAR missions. More details to come
Specifications
  • Brand Name: Volantex
  • Item Name: Ranger 757-4 Airplane
  • Wingspan: 1380mm
  • Flying Weight(without battery): 800g
  • Motor Size: 2812/1400KV powerful out runner brushless motor
  • ESC: 30A brushless ESC
  • Servo 9-gram Servo * 4pcs included
  • Recommended Battery: 11.1V 1800mAh Li-Po
  • Charger: Not included
  • Flaps: Yes
  • Retracts: No
  • Recommended Radio: 2.4Ghz 6-Channels
  • Experience Level: Beginners ~ Expert
  • Recommended Environment: Outdoor
  • Assembly Time: Less than half hour
  • Is Assembly Required: Yes
  • Requires: PNP requires Radio System, Battery and Charger
* Originally published at DroneMission, a DM Archives project. 写评论文章*
Jun 21, 2015, 02:04 PM
thanks for the coupon. i wonder how much the flight time compared to the 757-3 version.
Jun 22, 2015, 06:30 PM
sub.
Jul 04, 2015, 08:26 AM
Hey guys ... I was fortunate enough to order this here in the USA and it took 3 weeks to arrive from Hong Kong. I highly recommend paying the additional $9 or so to get it quicker. I clicked the free s&h option and it was torture waiting for it. As for the plane itself, yes I can confirm it doesn't have flaps or flap cutouts. I believe it wouldn't need them even with a heavy FPV setup. Also unlike it's bigger brother the fuselage is EPP .. very very strong. The wingspar is aluminum and not carbon fiber which was new to me. As for her maiden, She flies great even with a 3s 5000mah lipo. She still felt light and floaty but a bit under powered. A switch to 4s can increase power by a factor of 25% which should help. On her maiden there was very little to no trim and she tracked true and held her course. I know this plane will make an excellent moderate 3 to 5 mile range FPV platform. And with some upgrades even further. Take a look at " Aero Mondo " on youtube. If you have any questions, please feel free to ask. Thanks guys.
Jul 05, 2015, 03:04 AM
Originally Posted by AnyZoneFlyer
also unlike it's bigger brother the fuselage is EPP .. very very strong. The wingspar is aluminum and not carbon fiber which was new to me. As for her maiden, She flies great even with a 3s 5000mah lipo. She still felt light and floaty but a bit under powered. A switch to 4s can increase power by a factor of 25% which should help. On her maiden there was very little to no trim and she tracked true and held her course. I know this plane will make an excellent moderate 3 to 5 mile range FPV platform. And with some upgrades even further. Take a look at " Aero Mondo " on youtube. If you have any questions, please feel free to ask. Thanks guys.
thanks for the update, this is great, all great things about it without the sacrifice. does the tail lift up first during take-off?
Jul 12, 2015, 01:16 AM
Photos from the unboxing shoot.
Aluminum main spar
Lots of room for LiPos and more. Included a 30A ESC.
Strengthened with wooden rods
Dual servos pre-installed at the tail end, one for the rudder and the other for elevator
Plastic motor mount, I wonder how much vibration
Flight controller or receiver compartment with plywood base.
Aug 11, 2015, 02:18 AM
Leo
Maiden Flight, the new Volantex Ranger 757-4 1380mm for long range FPV
Volantex Ranger 757-4 FPV 1380mm Long Range Edition (2 min 51 sec)
Aug 18, 2015, 12:07 AM
Leo
another view point from the Ranger. test run with the new Runcam HD. this camera has great potential.
RunCam HD born for RC Fanatics (1 min 55 sec)
Aug 27, 2015, 02:31 AM
华科尔 R&D USA
awesome
Aug 31, 2015, 12:18 AM
SAR
Snippet. Runcam HD F2.8 and Mobius C2 on Ranger 757-4 and Walkera e-Eyes
RunCam HD F2.8 FPV Volantex Ranger 757-4 (6 min 7 sec)
Oct 06, 2015, 01:41 PM
biomecanoid's Avatar
Hello guys,
I just received my Ranger 757-4 can you guys gimme a crash course on the plane ? maybe some tips/tricks/mods i need to know about ?
Lets see what i realized for far:
* Moving surfaces need hinges
* Wings and Horizontal/Vertical Stabilizer need laminating
* Motor needs more angle
* Larger Wheels (maybe)
Anything needs gluing ? do you guys glue the wing in one piece ?
Any more advice you can give me ?
Best Regards
Oct 07, 2015, 12:54 AM
Leo
Originally Posted by biomecanoid
Hello guys,
Best Regards
i just tape the hinges. i think the wings need to be better secured, added some velcro for support, but have not found the best solution. i am still trying to bolt those wings down, mine came missing some part.
The tail wheel needs to stay in position, so i added a little hot glue or tape to keep it in place but not restricting it from spinning.
Oct 18, 2015, 01:28 PM
Can you please recommend a good OSD with RTH as a failsafe when the Tx signal is lost ?
I was thinking of cyclops breeze OSD but i am not sure that supports what i want.
This my Ranger is new i want to be as safe as possible untill i work out the bugs out of the system.
Oct 19, 2015, 03:38 AM
check out APM/minimosd or Feiyutech for autopilots
Jan 23, 2016, 07:07 AM
I have already order the following for my Ranger:
Stand:
http://www.hobbyking.com/hobbyking/s...ter_Stand.html
Used for extra batteries or for a 2nd failsafe
http://www.hobbyking.com/hobbyking/s...15Mhz_FM_.html
Used for telemetry
http://www.hobbyking.com/hobbyking/s...r_9XR_Pro.html
I am ready to buy more hardware for my Ranger and i need opinions:
Camera
http://www.ebay.co.uk/itm/1608742972...14a7274d5&cp=1
Signal Alarm
http://www.banggood.com/MJX-F45-RC-H...r-p-71544.html
Balance plug Splitter ( For Bec and Quanun Voltage Alarm )
http://www.banggood.com/DYX-0010-11_...-p-979384.html
Also i wanna buy 2 more Batteries
http://www.banggood.com/BlackMagic-3...-p-946803.html
or
http://www.banggood.com/ZOP-Power-11...-p-998821.html
I have a simple XLS to compare the batteries i have find. It would be nice if you can check it out and comment.
http://www.megafileupload.com/ekT5/Batteries.xls
Since this hobby requires a lot of DIY i want to get some half-decent soldering irons:
http://www.banggood.com/Portable-But...p-1015142.html
http://www.banggood.com/60W-220V-Ele...-p-993252.html
I want to buy all of the above hardware this weekend if possible because i don't have time to devote to the hobby during week days so i would appreciate any assistance. Also all of the hardware come from Hong Honk or such and take 1-2 months to arrive so the sooner the get them the better and in the mean while i can test my ranger.
