May 21, 2001, 06:01 PM
Covering for foamies
Has anyone tried to cover a foamie (specifically a Pico Cub) with anything other than coloured parcel tape? I'm thinking of something like solarfilm or profilm as used on traditionally built craft. Would the heat required to shrink the film affect the foam?
Trev
May 22, 2001, 10:29 AM
Balsa Kamikaze
Jensst's Avatar
For a foamie just take low heat covering film like Ultracote. Brian has covered his Zagi like this, looks much better than colored tape.
_Jens
May 22, 2001, 04:04 PM
Thanks, I'll try that
Trevsie
May 23, 2001, 02:15 PM
By the way, Ultracote is called Profilm or Oracover in the UK, but they are one and the same.
May 23, 2001, 02:41 PM
crazy builder
flying_pig's Avatar
will monocote work ok on a zagi? a workmate has just given me two rolls and i an re-building a un-covered zagi right now and would hate to use that colored tape again
May 24, 2001, 04:54 PM
crazy builder
flying_pig's Avatar
thanks, i have a roll of neon yellow and neon pink i think its going to be a bit bright!!
May 24, 2001, 05:37 PM
Balsa Kamikaze
Jensst's Avatar
To my knowledge Monokote is a high heat covering! Be careful with the temperature of the iron when applying it to the foam wing.
_Jens
May 25, 2001, 12:37 AM
Certified Slopehead
tenover's Avatar
Works great on a Zagi!! I just did it myself...
