Nov 13, 2019, 06:01 PM
Low budget fun
Beaver_XT's Avatar
GT3B is really good for the price. It has everything you'll need to setup the car from dual rate, EPA, etc. However I've heard exponential doesn't work in stock firmware but you can install other firmware in and it's pretty much perfect.
You can run LED directly from battery. There are 2 plugs. The white one is balance plug (JST-XH 2.5mm 3 pin) that you use if you run stock 2-in-1 unit. The other one is read plug (JST) which is standard plug that you would use normally and also when you use other ESC. So calculate the resistor you want and wire the LEDs to the battery plug you don't use to power the car.
http://ledcalc.com/#calc
Nov 14, 2019, 11:01 PM
UltimateMicroQuads's Avatar
Perfect, thanks!
Nov 19, 2019, 10:47 PM
So I know I'm way late to the party but does anyone know where I might find a JJRC Q35 or Q36?
Nov 20, 2019, 04:01 AM
Low budget fun
Beaver_XT's Avatar
Q35/36 is probably still in banggood or aliexpress.
Discussion Wltoys K989 1:28 - dogbone fix, dif hub fix, videos bouzx6r Micro Cars 6 Dec 02, 2016 04:45 AM
Discussion 1/28 WLToys A999 mod Engan Micro Cars 0 Dec 13, 2015 03:22 AM
