Jan 16, 2016, 04:29 PM
AMA16634...Just Me
I thank you again....that article was very informative and clears up, for me anyway, the next step I'll be taking.....will be placing an order for the dacron you linked to....Thanks for your input here, appreciate it.
Don
Jan 16, 2016, 06:54 PM
You're welcome!
Jan 16, 2016, 07:06 PM
Dominion 2-HW
A summary in pictures-shes come a long way-still a long way to go:
(click for larger view)
Jan 17, 2016, 11:56 AM
Dominion 2-HW---"Tank" Test-she floats!
The boat just barely fitted in the "tank" but she did and floated! I tested it up to 9.71lb(including the weight of but not the buoyancy of the keel, bulb and foils which extends the maximum to 10.5lb static*)
Ideal is exactly 9lb or less(9.784lb including extra buoyancy static). As of now the hull weighs 2.21 lb.(52" X 14.25")
Couldn't be more satisfied!
That is 211 sq.in SA(1900sq.in total) per pound of boat weight at 9lb all up!(exactly the same as a 6.6lb mini40 tri with her "A" rig) And she has the RM to carry that much sail in around 9mph of wind.
* that is the boat sitting on her seahugging waterline not moving with all foils in the water.
Jan 21, 2016, 04:15 PM
Dominion 2-HW
Sanded the boat and shaped the bows today:
Jan 21, 2016, 04:25 PM
Dominion 2-HW
Also mocked up the Trapeze Power Ballast System which will be 3' long and move the weight about 18" to windward from center in about 1 -1.5 seconds. It will move fore and aft about 12- 15" as well.
Jan 21, 2016, 10:01 PM
Will fly for food
davidjensen's Avatar
Will the ballast be adjusted by an on board tilt meter or by the skipper from the radio.
Jan 21, 2016, 10:32 PM
By the skipper. It's a whole lot of fun and any electronic device would take away from that on a boat like this that is self-righting. Boats that can capsize like a cat or tri could possibly benefit from an electronic device .
Another "normal" scow I did 21 years ago with similar system:
Jan 22, 2016, 01:39 PM
Dominion 2-HW
Used SuperFill on the boat today. It's very lite-3.6lb per gallon but this batch was different and didn't work as nicely as previous batches I've used. It was "dryer" and didn't smooth out as nicely as when I last used it. Next step is to coat the hull with one or two coats of Duratec and sand.
Jan 23, 2016, 06:03 PM
AMA16634...Just Me
D,
Shipment from Aircraft Spruce came in with the dacron cloth you suggested. Made up a test sample to see if I can make it work without messing up my hull. Will know in the morning. The dacron does look like a better cloth than I was trying to use for this purpose....thanks for the leads and the info...
Don
Jan 23, 2016, 06:21 PM
peel ply
Hope it works well-did you get the 1.8oz?
Jan 23, 2016, 06:30 PM
AMA16634...Just Me
Yep. got exactly what you linked me to. On the test I applied 1/2 oz cloth to a piece of ply, made sure it was completed saturated with epoxy, then layered that with the dacron and squeegeed the heck out of it. This test was more to test my ability to work with it....
Jan 23, 2016, 10:20 PM
peel ply
Don, please let me know how it goes........
Jan 23, 2016, 11:11 PM
AMA16634...Just Me
Will do....either before, after or between games tomorrow....
Jan 23, 2016, 11:13 PM
AMA16634...Just Me
I've got a small unheated shop so I built a foam oven with a small heater that I can control the heat in from 70-80 degrees. It'll sit in there all night...
