Aug 21, 2019, 07:21 AM
I fly direct drive setup with a 6S-3100. 44mm x 44mm square is about as large as you can go in cross section. Barely fits between the threaded insert tabs and sits just below the top surface of them. The 138mm length would not be an issue on my setup. The one pictured is 135mm in length. JS
Aug 22, 2019, 08:46 AM
Originally Posted by blue92ehsi
Without a gearbox motor maybe but why so much capacity? even if then i wouldn’t waste money on the thunder power because this is the same exact battery for less https://www.roaringtopusa.com/70c-37...is-70c-3700-4s
Sure that the TP is better by quality on the full power load.
For my new X-Plus i want use Leomotion L4038-2700 motor.
And you right, we can step down with capacity to 2700mAh for example. In this capacity one battery size will be 26 x 39 x 129.
Is it possible to fit two batteries inside xplus fuse?
Aug 22, 2019, 10:25 AM
pnc
pnc
pnc's Avatar
Leomotion motors are so nice
Aug 22, 2019, 10:27 AM
I will post assemble process again👌
Aug 22, 2019, 05:09 PM
Anyone need a new PNC X-Plus mount for a Jeti motor? $25 shipped in USA. PM for Paypal address.
Aug 23, 2019, 02:41 PM
pnc
pnc
pnc's Avatar
I should be machining mounts today
Aug 23, 2019, 02:55 PM
Let me know where to send $ for the P29 mount.
Aug 24, 2019, 10:44 AM
Electric
Very elegant design for a $487 motor plus shipping. 2 minutes at 2500 watts.... It says. Should handle several seconds of hellfire just like we lik`em!
Aug 28, 2019, 11:27 PM
One Idiot is plenty...
Dbox's Avatar
Advertising Georgi's props is always pleasure
Yuri
Aug 29, 2019, 05:35 AM
You down with EPP?
johnnyrocco123's Avatar
Yuri
You sell wing bags?
Aug 29, 2019, 06:09 AM
Yuri
Thank you for order!
Assemble process on me
Aug 29, 2019, 02:25 PM
tic
tic
thunderscreech
tic's Avatar
Man, I've bought three of Georgi's props and I didn't get a sticker
Aug 29, 2019, 02:34 PM
Dbox's Avatar
Just because Georgi does not make sTICkers.
Yuri
Aug 29, 2019, 04:15 PM
tic
tic
thunderscreech
tic's Avatar
Wise guy eh?
Aug 29, 2019, 06:08 PM
Anyone care to guess how Yuri likes his water?
.....Carbonated
