Thread Tools |
This thread is privately moderated by mike_kelly, who may elect to delete unwanted replies. |
Basic Introduction to Multicopters
**** A note about asking for help ****
Most people on RCGroups are more than happy to help a beginner. But out of courtesy please use the search to see if someone asked the same question and it was already answered. Many times people ask the same question that was answered just a few posts up the thread. When you can't find the answer with the search tool then be as specific as you can with your question. Folks are not mind readers and there are lots of different parts and versions of parts. So when you ask, tell us about the exact flight controller, esc's etc and even provide pictures of your wiring. Then don't feel bad if nobody answers. Sometimes members just don't know. Your hardware may be uncommon and folks just don't know about your particular hardware. But when you get stuck don't be afraid to ask. ************************************************** *** This is a 7 part series, skip ahead if you like: #1 Newbie to Newbie: Introduction to Multicopters #2 Battery Technology #3 Motors and Electronic Speed controllers (ESC's) #4 Propellers #5 Flight Controllers #6 Radio Control Transmitters #7 Learning to Fly Index of articles Troubleshooting: Multirotor wants to flip over or tip over on first flight. Introduction to FPV Gimbals 101 RC Basics: Soldering RC Basics: Electric Motors RC Basics: Explaining motor KV RCModelReviews: Mini Quad Build Video part 1, complete build series that gives the basics needed for most any size quad..
Basic introduction to tuning your multirotor:
Basic introduction to learning to fly a multicopter:
RC Basics - Flight Controller Comparison by Painless360
P.S. A little plug here for those wanting to build a big Aerial Photography multirotor for their first build. Seriously think about making a 250 mini quad first. The mini quad will teach you a lot about multirotors. It is a cheap investment in your eventual big AP rig. The props are cheap and as you crash time after time, and you will, it is easier and cheaper to fix. Building it will give you the experience to be more successful at your bigger build. If you use a mini version of a flight controller that you plan to use in your big AP rig then all the learning of the flight controller will transfer right over to the big rig. Lastly the mini quads are fun to fly and will give you a positive build experience. As promised an image comparing the sizes of various multirotors: |
This is really interesting! Worth a reading
Outstanding beginners guide! How can I tag this post to request it be made into a sticky?
N/M I found how to request a sticky. I thought if you hit that report post icon it would report it as negative, but it brings up a list of things to report it as, and sticky is one of them ![]() |
If you expect your all-up-weight (AUW) to be say 1600g, in order to hover you need 1600/4=400g thrust per motor. Then the best thing is to use eCalc to determine what props would be most efficient for this AUW. Once you determine the props you then know what the frame must support in prop size. 1. Determine your payload, the cameras and gimbal, vtx, rcvr, flight controller weight. 2. Then your hoped for flight time. 3. Use eCalc (www.eCalc.ch) to determine what props would be needed: eCalc tutorial 4. Pick a frame that can support the AUW and prop size needed. Good Luck! |
Latest blog entry: UC4H: Gimbal flight test
I've attached a spread sheet.
Plug in the numbers for All Up Weight, Battery Weight, Cell Count, and Motor Efficiency in grams per watt of power. The spreadsheet will give you two numbers, Expected flight time based on exhausting the battery, and a Flight Time with a 20% reserve. The only difficulty is finding the G/W because not every manufacturer or vendor does the testing, but the good ones like Sunny Sky and others do... |
Hey I am building my first quad, here is the series I am making. Here's the video:
I like his channel for well explained details, so here it is:
