XIRO Xplorer V *******Owners Thread ********* - Page 5 - RC Groups
Sep 12, 2015, 12:35 AM
Originally Posted by Ten2
Hi for that "clamp" message i contacted the Xiro Support sending the flight log files to them. ...
How you get the flight log files? Are they readable?
Sep 12, 2015, 02:30 AM
UAV Quadcopters User
How to extract the logs files .hj extension
Hi, this is the way to extract the logs file (if you fly using the app):
Open Xiro APP -> Setting -> Repair, and then send the email to your own address.
You will receive an email with the logs, the files have a .hj extension.
I did not succed to reading/open them, Xiro support does.
However i am not an expert so if someone knows how to read/manage the logs, please share it.
HERE there is a way to access/convert the .hj files, i am not sure it will work with the Xiro log files.
Sep 13, 2015, 08:59 AM
New firmware updates available for drone and gimbal:
http://www.xirodrone.com/index.php/downloadcenter
UA3500_FCU_FW_1.0.0_20150710.bin:
1、The firmware (0710) supports the latest Follow Snap function
2、It must be matched upgraded with the gimbal firmware (0521)
2、The gimbal and the aircraft should be used together
UG3300 V_PTZ_FW_1.0.0_20150521.bin
Sep 13, 2015, 10:02 AM
Thanks i made yesterday the upgrade but i noticed that the FCU firmware version number was the 0740!!!! The Snap function is not still ready for the Android users, it should be for the Apple devices.
Sep 13, 2015, 10:16 AM
I did the update today (13/09/2015) but the weather prohibits me to test it ... now it's the waiting game that has to be played for the new Xiro app to appear ...
Sep 13, 2015, 10:25 AM
Yeah, i also hope in a good "Xiro Assistant Software" upgrade soon!
Let's wait, autumn is coming......
Sep 14, 2015, 12:32 PM
Xiro Xplorer V
Rodina's Avatar
Works great on a iPhone happy with this
Sep 14, 2015, 12:34 PM
Ok, do you know if there is a way to force the atti mode when the xiro is outside (and receives the gps signal)?
Sep 14, 2015, 12:59 PM
Xiro Xplorer V
Rodina's Avatar
I don't think you can force this my guess is they wanted to build a drone everybody can fly (my opinion) so they chose for stable (gps) and the atti mode is only indoors (no gps, at least under the six)
Maybe they can bring that in a update for the app would be nice if you could put gps off.
Sep 14, 2015, 01:45 PM
I think that the atti mode is very important to have and to use outside when there is no constant gps signal, like in a valley, in that scenario the gps signal is often wrong or has a very low precision and the quadcopter could have strange behaviour ......
Sep 14, 2015, 02:04 PM
Xiro Xplorer V
Rodina's Avatar
i totally agree but what i have been reading about it less then 6 fixes in gps is atti mode otherwise it will be always gps. if i'm wrong correct me please and you can't choose between them.
And the only difference i know is in atti mode it doesn't hold his position (wind) for the rest its the same as gps
Sep 14, 2015, 04:31 PM
Yes Rodina, you are right, when the quadcopter is in atti mode, the copter maintains its height (using mainly the barometer and compass sensor), but it can shift or drift fast or slowly because it has not any position reference.
It is a good choice to have the copter in a good sight when it is in atti so the pilot can see immediately the drift and he can control it.
[UPDATE] Here the Xiro answer (about the atti mode).
"attitude mode, it should be enabled if you fly in mode 3 and no GPS fixed, it'll turn on automatically but not manually."
Sep 17, 2015, 12:53 AM
Thanks for the information. I hadn't looked at the "Repair" option.
I don't know if the record format is the same as that mentioned in the YS-X6 post , but the record length is the same, 99 bytes, so there's a pretty good chance that it is similar.
Today I flew for ~14 minutes and generated 1081 records. I'm going to try to build a log display tool.
Sep 17, 2015, 03:05 AM
Hi, a log display tool could be very useful, however it is available a Graph Tool that maps the CSV log files , and yes i tested that the .hj file are readable (after the CSV conversion using the Parser tool).
You can start downloading this files "HJ files Parser and Graph Tool".
[TIP] To run the Parser i added some OCX files in the folder of the .exe file.
Now i have to understand how to use the log data, in the graph tools there are a lot of parameters and option.......
Bye
Sep 17, 2015, 11:55 AM
I'm interested in syncing the log data with video.
