Jun 02, 2015, 03:40 PM
SeByDocKy's Avatar
Mini-Review
HUAJUN W609 (under construction)
INTRODUCTION
Here is my mini-review of the W609-10, a micro-hexacopter equiped of 2Mpx camera. It's one of the first camera hexacopter plateform and thanks to its 6 motors, the W609 should offer more stable videos. Let's analyse this new "alien"
BOX CONTENT
+ 1 x HUAJUN W609-10 (with a 1S 650mAh LiPo ending with JST connector )
+ 1 x Transmitter (using 4xAA batteries not included)
+ 1 x USB microSD reader
+ 1 x 4Gb microSD
+ 1 x USB charger for the quadricopter LiPo
+ 4 x Spare props (2 CW, 2 CCW)
+ 1 x Instruction manual (English/Chinese)
+ 1 x Screwdriver
OVERVIEW
side view
rear view
top view
The ground clearance is around 9cm thanks to these long legs
The camera is connected via a 3 pins mini-JST connector. Good news, there is power switch
Some nice and bright LEDs (white on front and green on rear) give to W609 excellent night capacities
The battery bay must be opened by first turning the lock clockwise then too slide the battery door up
The bay don't have a lot of room. Anyway some 750mAh turnigy LiPo seems compatible
The shipped LiPo have a 650mAh capacity, no discharge rate indicated. I found this one a little bit weak.... probably with a low discharge rate value.
and with the LiPo. The total weight reach 160g ... a little bit heavy IMHO even for an hexacopter especially with some 7mm motors
Motor pod
Motor and oil bushings
oil bushing are 2.5mm(ID)x5mm(OD)x2mm(witdth)
Disassembling
As you can see, arms are jailed into a transparent plastic holer. It means in the absolute, you can remove the canopy structure to save close to 20g. If you remove also motor pod canopy, at least 10 extra grams can be saved. The flying duration should increased a lot in such conditions.
Some 5mm metallic boon
Some weight would have been saved with some carbon models
Flight controller
Some small ball are absorbing transmitted motor's vibration
The classic invensense 6050C for the 6-axis stabilization and a XN297 for the RF part. Good news, the emulation of the XN297 by a nRF24L01 is almost complete. We can hope a deviationTX hacking for this quad.
Camera
The lens orientation can be tuned .... a good point
This camera for a toy model is pretty good. High frame rate, sharp and color respected. Unfortunatly, the lens mount is a M5.5 model and as far I know, there is no available widelens for this size.
Transmitter
4xAA batteries are required to feed the TX. The throttle trim is used to turn on/off lights when pressed up or to cycle between the two speed modes when pressed down. The right shoulder button turns on/off the camera recording (no photo mode) while the left shoulder button activâtes the flipping move. To calibrate gyroscope, you have push both sticks in lower left position. It's a very basic radio model, nothing special ....
FIRST USAGE
First thing, the W609 offers video jellofree out of the box even without installing any foam/sponge between camera/batery doors (to absorbe remaining vibrations). Videos are sharp and frame rate constant. The field of view can be better of course but at least, you can tune the lens orientation. Unfortunatly, with the tiny lens mount size, it will be hard to find a compatible wide lens. The quadcopter is already "touchy" in beginner mode and in expert mode, thank to the increased pitch rate, the W609 becomes much more sporty. The yaw rate is normal not slow not fast. I was not impressed by the power lift of this quad. I think the 160g even for six 7mm motors is not so favorable and/or you need to install a LiPo with a better discharge rate. Last con point, the control range also is not great: around 60-80 maximum out of the box. You can install the RX antenna vertically below the top canopy part as well as for the TX part. It should improve the radio control range.
HUAJUN W609 outdoors test (Courtesy Gearbest) (7 min 8 sec)
raw camera sample
W609 raw sample (1 min 48 sec)
CONCLUSIONS
Very stable and jellofree plateform out of the box. Coupled with a really good HDready camera, for less than 60 USD this W609 is one the best camera microcopter in the market. In expert mode, this copter can be very sporty and fast. I really appreciate the LEDs too. I regret the lack of power lift and the none-fantastic range control out of the box.
UNBOXING
HUAJUN W609 Unboxing and quick testing (Courtesy Gearbest) (15 min 24 sec)
PROS
+ Very good flyer, stable for beginner and sporty in 100% mode
+ Nice design
+ Good ground clearance
+ Night flyer
+ Good 720p camera (30fps)
+ Jellofree video plateform
+ Orientable lens
+ Power switch
CONS
- Oil bushings (2.5mmx5mmx2mm)
- [60-80m] of control range out of the box
- No headless mode
- Lack of power lift
- Flight time of 5min with the camera turned on
- Lens mount (M5.5) not comptabile with M7 lens
This quadcopter have been courtesy provided by Gearbest in order to make a fair and not biased review. I would like to thanks them for this attitude.
You can find it actually for 57.7 USD at W609-10
Jun 02, 2015, 03:41 PM
SeByDocKy's Avatar
reserved
Jun 03, 2015, 12:07 AM
SeByDocKy's Avatar
Added raw video sample in #1 and extra details
Jul 03, 2015, 05:43 AM
Pedja
good test, as usual, thanks
It is also interesting to the test :
http://www.gearbest.com/rc-quadcopters/pp_193699.html
.... Berometric pressure sensor: This function provides you to set a height for W609 - 8 to hover......low voltage reminding function, smart headless mode, one key return, video recording / picture shooting, berometric pressure sensor ( set high hovering, vertical above or below 0.7m ), 5.8G FPV real-time transmission ( 2.0MP HD camera )
Copter size: 54 x 47 x 21cm
Copter battery: 7.4V 1500mAh lipo battery
Charging time: About 150mins
Flying time: 8 - 10mins
Remote distance: Above 300m ( max. 500m )
Jul 03, 2015, 05:52 AM
SeByDocKy's Avatar
Hummm ... I am a little bit in doubt when I see associted photos. Seems to be a FPV with a Digital 2.4G system like the H9D, CX-30S.... After the lens of the camera is not wide IMHO. Anyway I can be wrong
Jul 06, 2015, 11:35 AM
I'm very curious to see if this W609-8 thing is for real. According to the specs, it's got 6x 220mm props and looks like a ~550mm frame size. If it's got rudimentary altitude and position hold and FPV, might be a fun little copter that could carry a GoPro on the cheap
Jul 06, 2015, 01:08 PM
that quad will doubtfully carry a gopro
Jul 06, 2015, 02:26 PM
SeByDocKy's Avatar
For sure not or maximum 15s
Jul 15, 2015, 08:37 AM
SeByDocKy
I am expecting one of these shortly, I am wanting to replace the camera setup with a TX/Camera setup. I have been looking for sometime for this combo but I am just too unsure on which one to buy. I am more concerned I guess with the weight than I am with any thing else. I see that the camera and housing weighs 10.3 (your review is greatly appreciated by-the-way) and that should be my goal. Or no more than 10grams in addition.
The following are links to the ones I am looking at, if you have a setup that you feel may be better. Please post:
http://www.goodluckbuy.com/fpv-fov16...ter-combo.html
http://www.goodluckbuy.com/-fpv-fov1...er-qav250.html
http://www.goodluckbuy.com/700tvl-hd...50qav-fpv.html
Jul 15, 2015, 09:15 AM
SeByDocKy's Avatar
Originally Posted by RemyMartinXIII View Post
SeByDocKy
If you can solder a bit, I would advise a lightweight TX5823 or even better a FX758 (https://www.rcgroups.com/forums/show....php?t=2456116), a very light cam
http://www.banggood.com/600TVL-8_0MP-14-2_8mm-CMOS-FPV-170-Degree-Wide-Anlge-Lens-Camera-PALNTSC-p-984345.html,a pololy Vreg. and a cheap CL antenna
I will produce a building log video for such combo. The ojvective is to have a cheap and light FPV setup. The total bill shound be around 35USD and scale around 5g.
You can have lighter but more expensive
Jul 15, 2015, 09:19 AM
Subbed.. I'm curious about that bigger model.
Jul 15, 2015, 10:32 AM
Thanks for the quick reply!
5 grams would be GREAT! but at what cost (not that it matters with a toy). I would like to get around a 50 - 70 meters before we start losing signal.
Looking forward to your build log!
Jul 15, 2015, 04:07 PM
SeByDocKy's Avatar
With this 200mW ... you can have 300m of video range without problem
Jul 26, 2015, 03:35 PM
Battery drain
I have some older 1S batteries that I had with my SYMA X5. They are 680mah. The battery that came with the W609-10 are 650mah. However, I am unable to get more than 3-6 minutes out of a fully charged battery.
Has anyone else experienced this?
Jul 26, 2015, 03:38 PM
SeByDocKy's Avatar
Like me... I wrote as con point the relatively poor flying duration time
