May 30, 2015, 01:55 PM
SeByDocKy's Avatar
Mini-Review
Wingsland Scarlet Minivet (Under construction)
ALERT
The last firmware (20150805 black.vast for black PCB ) seems partially buggy and can provoke some crash (especially in L1-0 slow GPS mode). I advice to not upgrade to it or if you have it already to downgrade to the former given in the bottom of #2.
ALERT
Actually, software associated with FC & Gimbal are not yet released. It's strongly advised to wait before to purchase it until their availability (should come in june 2015)
Softwares have been released (FC & gimbal)
INTRODUCTION
Here are the first elements of the mini-review of the Wingsland Scarlet Minivet, a all-in-one 390mm brushless quadcopter equiped of a 3D gimbal, a full HD cam (30fps) and 5.8G FPV part. I will construct this mini-review step by step in order to give you as soon as possible important elements of the model.
BOX CONTENT
+ 1 x Wingsland Scarlet Minivet
+ 1 x 3S 5200mAh battery (proprietary connector)
+ 1 x Charger
+ 4 x Prop lock
+ 1 x Transmitter (10 channels using FSSS technology)
+ 1 x 2.5" FPV monitor
+ 1 x Instruction manual (english/chinese)
OVERVIEW
The general informations given by the constructor : http://www.szsungreen.com/en/index.p...t=list&tid=129
- Maximum of 3m/s
- 600m of radio control range and video range
- Camera : 4Mpx, [email protected], [email protected]
- Main body
- Battery connector
A proprietaty one is used, but in a first glance, it could be possible to mod this connector to welcome a more standard model
- 2.4G receiver
- Top canopy
A serie of LEDs are located on the border of the black plastic indicating the GPS reception quality.
Close to 900g without the battery and props
- Landing gear
Landing gear fixation
Rubber feet
Both the 2.4G and the 5.8G antennas are located in each foot respectively. Here, the 5.8G atenna
and the 2.4G antenna
ESC aeration holes
- Arms
Motors are 2212 model (no KV information yet). Shafts are7mm (5mm screw)
- Propeller
1045 model with 8mm shaft (w/ two flat sides). This model is for example compatible with XK X380 model.
- Prop lock
With a diameter of 5mm
- 5.8G VTX
Two micro dip switches are located to select channels. By default, the frequency is set to 5645Mhz (a Boscam freq). I will check if there are some Fatshark compatible frequencies. Notice the gimbal's micro-USD port proably to set gimbal parameters/flash new gimbal F/W.
- Battery
A 3S 5200mAh LiPo
The battery after 48h is entering automatically in auto-storage mode .... Great feature....
Disassembling
You will need a 2mm hex screwdriver to remove the 16 screws to access to the main quadcopter electronic
After a quick overview, all soldering jobs are very clean and covered with hot glue.
-ESC
-Flight Controller and PDB
I received the pre-release version. The final version have minor improvement. The pre-release version have a green PCB while the final have a black one. This is why FC firmware (.vast files) have color indication in their name
The gimbal is connector on the "P7" port. No information about the FC design. Maybe a home-made model ? Ground station software have been released (see below)
The GPS module is well protected to RF interférences
The flight controller software can be downloaded with these 3 links (installed them in the same directory)
http://img.banggood.com/images/uploa...GSLAND_GCS.exe
http://img.banggood.com/images/uploa...WPFToolkit.pdb
http://img.banggood.com/images/uploa...WPFToolkit.dll
May 30, 2015, 01:56 PM
SeByDocKy's Avatar
Gimbal and camera
You can see the 2 micro dip switches to select one of the 8 frequencies
a microSD slot located beneath. Be aware, to not push the micro-SD by accident Inside the camera chassis..... It would have been much more better to add another micro-USD port to export via a cable all contents
The set camera + 3D gimbals scales around 200g
Main gimbal PCB
After removing the 4 screws behing the camera module, we can acceed to the main camera electronic
The INS sensor
and the main video MCU: a NOVATEK NT966508G
Main codec informations:
Wingsland scalert minivet first camera snapshot (0 min 45 sec)
Actually no gimbal software available in the official webpage : http://www.szsungreen.com/
minivet camera menu2 (1 min 18 sec)
Transmitter
A very nice chassis with mate plastic. A 10CH model : 2 left 3-way switches to select flight modes, 2 right switches (one 3-way, one toggle) for the camera module and joystick located behind to control the gimbal. Both sticks have springs. I didn't find yet how to turn in into mode 1 and vice and versa.
The L1 in upper position represents the manual mod while in bottom position engages the RTH. For L2, if in bottom position, you are activating the Headless mode. In upper position, you set/record a POI (Point Of Interest) (I think L1 must be also in central position).
I will investigate later about this new feature.
a CC2530 RF chip (a variant of the CC2500 used for the FrSky and Futaba protocols) is installed
If you plan to install an external antenna, you will have to solder directly for example a RG316 coaxial cable or to solder a uFL connector to welcom a uFL-RG178-RP-SMA cable for example
2.5" FPV monitor
The 2.5" FPV monitor offers on the right side ; a press button (long pressing : to turn on/off monitor, short pressing: to cycle over the 8 videos frequencies), a 1.5mm jack (probably an AVout), a micro-USB slot (to recharge the 850mAh LiPo) and a status LED (red : recharging, blue : charged)
The instruction do not mention the frequencies available via this FPV system. I collected them
FPV monitor
Channel Freq
CH1 5645Mhz
CH2 5685Mhz
CH3 5725Mhz (work also @5733Mhz)
CH4 5760Mhz(work also @5765Mhz)
CH5 5800Mhz (work also @5805Mhz)
CH6 5840Mhz (work also @5845Mhz and 5847Mhz)
CH7 5885Mhz
CH8 5925Mhz
There are some boscam band and probably some Fatshark ones ...
The 5.8G antenna seems a half-plan model
An mod would be to install a RP-SMA connector
A 850 mAh 1S LiPo
Unfortunatly, this monitor offers blue screen when the connexion is lost ....
FIRST USAGE
Here the video of my first flight with the Minivet. Unfortunatly, my gimbal is not perfectly tuned and rotate by itself. Whatever here is the results of my first flight. From 5min50, you will have toverlayed he FPV live video on bottom left and the 1080p recording on bottom right.
I used an AOMWAY RX004 to record the FPV part.
Wingsland Scarlet Minivet first (raw) outdoors test (Courtesy Banggood) (10 min 15 sec)
For a first test, I was positively impressed by the general quality of the camera especially with the HDR option turned on. Even if my gimbal is not correctly calibrated, videos are jellofree. In another hand, I was not impressed by the VRX sensitivity. Clearly, this FPV monitor need to be modded in order to install RP-SMA connector + cloverleaf antenna. The latency is around 100ms and no extra latency/frames drop is observed when recording is turned on too.
Concerning the quadcopter itself... very positives feedback: stable, GPS position hold efficient, visible LEDs,
EDIT 06/29/15
I installed the gimbal V1.01 and perform a first stability flight.
wingsland scarlet minivet stability demo flight (Courtesy Banggood) (3 min 10 sec)
This video is not processing by any stabilization software. The result is already very good
Wingsland scarlet minivet maiden beach session (Courtesy Banggood) (8 min 17 sec)
WIth balanced prop, the results is even better
Wingsland scarlet minivet raw footage demo flight with balanced props (Courtesy Banggood) (3 min 1 sec)
For a 600USD RTF package, it's really not bad.... I am positively impressed
FyreSG videos (amazing work):
Wingsland Minivet FPV Quadcopter, Part 2/3 - Test Flight #1 (4 min 37 sec)
Wingsland Minivet FPV Quadcopter, Part 3/3 - Photo, Video, FPV (5 min 36 sec)
UNBOXING AND QUICK TESTING
Wingsland scarlet minivet unboxing and first analysis (Courtesy Banggood) (16 min 35 sec)
FyreSG unboxing video (superbe work):
Wingsland Minivet FPV Quadcopter - Unbox & Quick Look (4 min 37 sec)
PROS
+ Stable quadcopter
+ Efficient and lightweight 3D gimbal + camera combo (~200g)
+ OSD informations
+ POI
+ Powerful 5.8G VTX (400mW sharing Boscam & Fatshark freq)
+ uFL connector the VTX antenna
+ Quality build
+ Good battery duration (~around 20min) with auto-storage feature (after 48h)
+ For 600USD, (500 with WS M499 coupon) complete and cheap 3D gimbal AP + FPV
CONS
- Too small FPV monitor
- No DVR in the FPV monitor
- Poor VRX sensitivity (but can be modded)
- Proprietary battery (but can be modded)
- No pan control of the gimbal via the joystick
- No mission planner software (yet)
- Not sporty quadcopter, it's a real AP
- FC software still uncomplete but should be updated soon
- No microUSB plug in the camera module
- MicroSD card can fall by accident into the camera support
You can find the "Green" Firwmare for pre-release model (green FC PCB) and the "Black" firmware for the final minivet version (black FC PCB)
EDIT 07/21/15
Please find the full instruction manual at: https://mon-partage.fr/f/887F0ibu/
EDIT 01/20/16
For all new Minivet owners. Here are the firmware instructions updates for (gimbal, camera & FC)
1) Download all updates
https://www.dropbox.com/s/br9dnw74r1...nivet.rar?dl=0
2) Gimbal f/w update instructions
http://v.youku.com/v_show/id_XMTQxMD...ml?from=y1.7-2
This quadcopter have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thanks them for this attitude.
You can find it actually for 650 600 USD at Wingsland Scarlet Minivet
100$ off cupon: WSM499
500 USD the minivet !!!!! amazing
May 30, 2015, 01:57 PM
SeByDocKy's Avatar
Antennas modding:
TX antenna
uFL RP-SMA replacement
Pre dril a hole with thin tweezer
enlarge current hole with drimel
RX antenna
Disassembling
Lift the black connector locker to remove the ribbon cable of the LCD
Pre-drill a hole (be aware, the hole have to be at the bottom part, if not you won't be able to reassemble)
You can see where to drill the hole (You can see my unsuccefully first attempt....)
Motor raiser
Courtesy Onepoint21: https://www.rcgroups.com/forums/show...postcount=1421
http://www.thingiverse.com/thing:1375053
May 31, 2015, 12:27 AM
SeByDocKy's Avatar
New Gimbal model reset/rescue procedure (from LARSON CHRISTIAN):
https://www.rcgroups.com/forums/show...postcount=2174
May 31, 2015, 06:40 AM
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Wow, that's a highly detailed review! Thanks for showing the internals. And thanks for sharing my videos.
May 31, 2015, 10:58 AM
Trackercal's Avatar
Great review , thanks. Hopefully Fat Shark will work with it. Also is Tx range only 1 km / .62 mile?
May 31, 2015, 12:12 PM
SeByDocKy's Avatar
Are you kidding your videos are awsome ... mine look rubbish ....
Anyway, it's not yet the review, just first informations collected.... Much more to come ....
May 31, 2015, 12:51 PM
SeByDocKy's Avatar
I am afraid with the current FPV monitor, this 600m is true is pure LOS condition. A basic mod would be to install a better RX antenna and probably also a CL antenna for the TX part. I will check this point asap
May 31, 2015, 02:22 PM
SeByDocKy's Avatar
I updated #1 and #2 with the list of the 8 freqencies I found for the FPV system and more photos/informations
Jun 03, 2015, 11:45 AM
SeByDocKy's Avatar
According to some BG contact, the Wingsland website (http://www.szsungreen.com/) should be updated on 5th june... I hope, they will release the gimbal software coz mine in not yet usable
Wingsland Minivet Gimbal problem (0 min 44 sec)
I am frustrated coz it seems to be a very good machine by the way ....
Jun 05, 2015, 10:41 AM
Trackercal's Avatar
Any word on if Fat Shark goggles work with this?
Jun 05, 2015, 11:47 AM
SeByDocKy's Avatar
Here are the freq I found
Channel Freq
CH1 5645Mhz
CH2 5685Mhz
CH7 5885Mhz
CH8 5925Mhz
So at least 5760 MHz, 5840Mhz are in Fatshark list
Jun 05, 2015, 07:15 PM
Trackercal's Avatar
Fat Shark
Channel Freq
CH1 5645Mhz
CH2 5685Mhz
CH7 5885Mhz
CH8 5925Mhz
Thanks for information.
Jun 10, 2015, 06:48 AM
SeByDocKy's Avatar
Spare parts are now available : http://www.banggood.com/buy/Wingsland-scarlet.html
Good news
ESC are announced to be 20A and 2212 motors to be 930KV
