May 28, 2015, 01:59 AM
ChuckTseeker's Avatar
New Product
Blade Chroma Drone RTF w/ ST-10+ and C-Go3 Camera
WOW! the future sure is here
Everything in One Box
Flight-Ready Chroma Drone with Stabilized CGO3 4K Camera • ST-10+ Controller with Touch-Screen Display
• Long-Lasting 5400mAh LiPo Flight Battery • Flight Battery Charger • USB Programmer Cable
Video Overview
Everything at Your Fingertips.
You don’t need a separate smart device with the ST-10+ controller. Everything you need, including the camera controls and a touch-screen video display, is built right in.
Large, 5 inch touch-screen display with intuitive Android interface
Displays live video and real-time telemetry info like speed, altitude and battery voltage
Clearly marked switches and buttons
Super-simple flight and camera controls
Slider switch for adjusting camera tilt
Slider switch for adjusting drone speed
Look Like a Pro.
SAFE Plus technology gives you several flight modes that have been specially programmed to make smooth, steady image capture easy. In fact, it can make you look like a pro even if you’ve never flown a camera drone before! All flight modes feature self-leveling and use GPS and altitude sensors to precisely hold position. SAFE Plus technology will even land the aircraft for you if you activate the Return Home function.
This version of the Chroma drone gives you the added benefit of Follow Me and Watch Me flight modes that let you focus on getting the shot while the drone does the flying.
Look like a Pro with SAFE Plus
Smart Mode
Perfect for first-time drone flyers.
Stick Relativity moves drone in whatever direction the control stick is pushed, no matter which way the nose is pointed
Creates a SAFE Circle™ barrier that prevents the aircraft from flying too close to you
Auto-holds position and altitude when control sticks are released
AP Mode
For more experienced drone pilots.
Responds like a conventional drone without Stick Relativity
Gives you greater control authority by turning off the SAFE Circle
Keeps control response smooth so panning and tracking shots look great
Follow Me Mode
Your built-in copilot.
Frees you to focus on lining up the perfect shot
Pan and tilt the camera while the drone follows
Drone follows at an altitude and distance you set
Tracking Mode
Be the Star.
Drone follows and keeps the camera pointed at whoever holds the ST-10+ controller
Resume full control at any time
Return Home
Safe landings with the flip of a switch.
Returns the drone to its start-up point and lands it for you
Great for first-time flyers who aren’t ready to land themselves
Easy way to regain visual contact if you lose sight in flight
Activates automatically if controller signal is lost
Adjustable Flight Boundaries
Stay legal. Stay safe. Fly responsibly.
Keeps the drone within altitude and distance limits you define
Easily adjusted using the Chroma programmer
Helps you avoid sensitive airspace ...and neighbors
cheers chuck
May 28, 2015, 05:57 AM
PSALM 14:1
Sammy70's Avatar
Sweet!
May 28, 2015, 06:34 AM
Scale for me!!!!
LRSSIX's Avatar
Looks interesting. I may replace my QX3 with it.
May 28, 2015, 06:55 AM
Looks good, but ...
have you, or has anyone else, tested it to verify that it lives up to that description?
do you have any idea when it may be available? I am reminded of the Hubsan H109S that is reputed to be able to fly for 40 minutes, but it was announced about a year and a half ago and we still can't buy it.
May 28, 2015, 07:55 AM
The spec's seem pretty good. Basically a QX4. Along the lines of phantom 3 or 3DR solo, but a real all in one package without the need to use a tablet or buy a GoPro.
Only thing i dont like the look of is the screens at the bottom of TX - wouldn't it be better at the top? Easy to catch something with your hand holding the transmitter - although it has been used with the Yunecc for a while so might be OK - just seems a bit unnatural to me
May 28, 2015, 08:03 AM
I think its pretty cool that they incorporated the go pro into the quad. I wish their was someway to stream the gopro video and not have to buy the $1200 drone. Im 14 and I don't have the money, but I have the experience of 4 years of flying. What do you guys think of it.
May 28, 2015, 08:37 AM
Why not FPV to a tablet? It costs money, but not nearly that much.
May 28, 2015, 09:28 AM
Champagne Supernova
Remote_Pilot's Avatar
When is somebody gonna have AV out to fatshark goggles with OSD built in so we don't have to add all those items after the purchase
May 28, 2015, 09:52 AM
Critic at Large
craigiri's Avatar
Aren't these just relabeled Yuneec machines?
Not to say that's a bad thing, but surely nothing latest and greatest. But they may be solid machines if the 4K cam is sweet.
I don't see where it mentions full GP control on that model. If it does not have that, it's not good.....we are past the times of "start the GP on the ground and fly" IMHO.
May 28, 2015, 10:22 AM
What's the expected release date on these I wonder...
May 28, 2015, 10:23 AM
Surface, Air & Water Rc Toys..
Mid July my LHS buddy said but that can always change and be pushed back.
Sounds too quick but here's to wishful thinking.
May 28, 2015, 10:26 AM
Technica's Avatar
And it still looks like a 350QX. Yawn.
May 28, 2015, 10:30 AM
Medical IT Geek
Syntax's Avatar
Does anyone know if the Follow Me and Watch modes are using Microsoft RealSense technology? Not sure, but it may be that LILY is using the same kind of technology.
The next questions are:
Could this technology be used to follow another RC aircraft as a video "wing man" with predetermined distance limits?
Are there potential radio interference issues?
May 28, 2015, 10:48 AM
(͡ ͜ʖ ͡)(͡ ͜ʖ ͡)(͡ ͜ʖ ͡)
JohnCC's Avatar
Blizzard Jonas 2016 / Chroma Drone / GoPro 4K & GB203 (2 min 36 sec)
Blade Chroma Camera Drone / 5.8 Ghz FPV Setup with TS832 (9 min 2 sec)
Aeronaut CAMcarbon Light Prop for Blade Chroma (2 min 17 sec)
Chroma Drone at Panama City Beach (4 min 42 sec)
