Jun 17, 2015, 03:57 AM
Certainly not for someone as polite as you are
Jun 17, 2015, 05:59 AM
On a vertical learning curve!
Hi, thanks for the information, I think you are describing the transmitter (the part you hold).
Should you ever take the top off (20+ screws), the flight controller is in there.
Love the way it flies by the way.
Jun 17, 2015, 01:19 PM
Droneguy's Avatar
Hi PiNgOa,
Was your video taken with the stock Camera or GoPro 3? Very impressed with the footage
Jun 18, 2015, 04:39 AM
I'll try that tonight and post pictures
Originally Posted by Droneguy
Hi PiNgOa,
It was taken with the stock camera, which is basically an SJ4000-like camera
Jun 19, 2015, 01:25 AM
Hi there ! You'll find 2 pics of the inside of the controller attached to this post, and here's a new video
Just a bit higher with the XK Detect X380 (5 min 29 sec)
Jun 19, 2015, 02:06 AM
darkh2o's Avatar
Does it have any altitude hold or loiter mode?
Jun 19, 2015, 04:14 AM
Yep, it has both thanks to the GPS and the barometer, both sticks return to neutral position when you let them go and the quad then hovers where it is
Jun 19, 2015, 06:22 AM
https://www.youtube.com/watch?v=8lvchRSxajg
Nice pics!
Jun 19, 2015, 03:09 PM
The X380 is on sale at Banggood. With coupon "midyear6" you'll get a 6% discount.
http://www.banggood.com/XK-X380...-p-974720.html
Jun 20, 2015, 01:29 AM
FC in quadcopter
Thanks Pingoa for your troubles taking the fine photos.
I didn't make myself clear, the Flight Controller is inside the quadcopter.
I have the recently discontinued wltoys v303 with the recently discontinued Zerouav ys-s4 v2 FC. Flight characteristics are similar to the XK Detect x380, the quad is virtually identical but in carbon lookalike and more durable and I have a problem with mine. The x380 seems to be influenced by the 3dr solo to my mind.
I wondered which FC replaced the ys-s4 v2. There seem to be a raft of similar controllers on the market but with differing names. I wonder is the x380 quad and FC another chinese clone, and an improvement over the v303, or a new model rebranding?
Jun 28, 2015, 08:29 PM
the size of X380 is same with Gopro, lots of gimbal fit for gopro, balance is key to gimbal, try to make sure about the gimbal balance except the price.
And also what kind of frame u use?
i think frame should be some reasons for choosing gimbal.
X-CAM A10-3H 3 Axis Gimbal is for Gopro series
GL-2X Two-axis CNC Brushless Gopro Gimbal
Foxtech FT-2 Brushless Gimbal for Gopro3/3+/4
try and check!
Jul 01, 2015, 01:36 AM
3 axis is best. I have the wltoys v303 which this quadcopter is based on and it has 100mm clearance, too low for existing 3 axis gimbals so I've gone for a 2 axis alternative.
Gopro like I would go for:
http://www.banggood.com/Light-FPV-Br...-p-968168.html
with a Xiaomi Yi also available at Banggood.
I've opted for a mobius on a Turnigy mobius gimbal for its height,
although the rclogger x1 is due in early July & looks good (but its been due since March???)
Coptercentre cs-1 is another option.
It would be interesting to know what PiNgOa's setup is? His video looks good on youtube.
Jul 01, 2015, 01:45 AM
try and check!
TRY THIS ONE: http://www.banggood.com/FPV-2-Axis-B...8803992014116A
ONLY 44$
Jul 01, 2015, 07:05 AM
Similar, looks good but solid motor cases mean weight. Maybe not a problem with the large x380 lipo.
