May 22, 2015, 07:58 PM
TDM30076's Avatar
Build Log
EVOLUTION W The build
First of all thank you for your purchase.
I have reserved the first few spots where I intend to present and perhaps answer all questions regarding this kit.
I will do my best to be as thorough as possible with the risk of boring some of you with details you can figure out. The idea is to have enough information so that someone who did not build a wood model in their life after watching and reading this , be able to build this model the first time correctly and without any problems.
Let's start with what is inside
As a base there is a Short kit to which I add Wood part components or Composite pod components.
Not in pictures there is a frame plan for building the wing.
TDM30076's Avatar
Wing Frame Construction
Start with a flat board. Preferably some shelving material or the white MDF. I prefer to have two pieces that i van independently move around and it is specially practical if you work in a tight space. I used 3M 77 to glue the plans directly to the piece of MDF.
To make the frame I started with the root make sure you place the root frame rib in the correct position (match the engraved lies on the print) then frame piece 1B and after that the rest of the frame pieces. I think i made the TE frame piece a little narrow so when you glue it in place elevate the piece flush to the top of the frame ribs and glue in place.
The 1B marking is on the rear lower corner of the piece check the third picture.
Frame (4 min 27 sec)
I have added a CA bottle tip insert
CA bottle tip (2 min 58 sec)
May 22, 2015, 07:59 PM
TDM30076's Avatar
Wing construction
I am going to put here a series of little videos.
I hope this clarify the building of the wing.
I will continue to update this thread with future videos.
First Taping
030 (3 min 17 sec)
Taping part 2 (1 min 9 sec)
Second is glue the TE. A little patch on the tip to finish completing the TE with scrap is OK.
Ribs There is also rib information on the Seer web video. you may want to watch that one too before you jump in to gluing of the ribs.
Ribs (1 min 38 sec)
Sheer webs. I nthis video there is some information touching off details about the root rib glue information.
Sheer webs (10 min 0 sec)
Launch Blade side details build
Wing tip build (11 min 30 sec)
Leading edge
Leading Edge (7 min 48 sec)
Sanding
Sanding tips (57 min 2 sec)
Top Sheeting
Wing top sheeting (31 min 17 sec)
Final prep before covering
Misc wing final prep (17 min 41 sec)
TDM30076's Avatar
Stab work
I can't believe i have added so much information in this video.
Stabs (1 hr 3 min 7 sec)
May 22, 2015, 08:00 PM
TDM30076's Avatar
Flaps
Flaps tips and tricks (26 min 11 sec)
TDM30076's Avatar
Wing Servo Feet Install
KST245H
Wing Servo Feet Install (7 min 43 sec)
May 22, 2015, 08:01 PM
TDM30076's Avatar
Wing LE TE (35 min 40 sec)
May 22, 2015, 08:03 PM
TDM30076's Avatar
Applying film DOCULAM
Doculam Part 1 (26 min 9 sec)
Doculam Part 2 (16 min 19 sec)
TDM30076's Avatar
Assembly Part 1 Wing Joining
Assy 1 Wing Join (33 min 4 sec)
Assy 2 Rudder (25 min 22 sec)
Assy 2 Riser Horizontal (24 min 4 sec)
Assy 1 Wing Fitting (7 min 8 sec)
Assy 3 boom join Hinges Springs (42 min 0 sec)
Jun 05, 2015, 08:35 AM
TDM30076's Avatar
New
Videos added
CA bottle tip video.
Sanding techniques
Jun 05, 2015, 08:36 AM
TDM30076's Avatar
New
Videos added
CA bottle tip video
Sanding techniques
I know they are a bit long but I tried to cover them thoroughly.
Jun 05, 2015, 02:46 PM
Toaster, not Toast
Traian- Thank you for all the video work you are doing for us.
-Topher
Latest blog entry: Evolution Woodie
Aug 14, 2015, 12:05 PM
Yes..ok..maybe..lol.....
Here are all the PDFs
https://www.rcgroups.com/forums/thum...one&starter=no
Sep 13, 2015, 10:22 AM
TDM30076's Avatar
Radio Instalation (46 min 12 sec)
Sep 19, 2015, 02:00 AM
OcsiRC's Avatar
A very thorough and useful tutorial for happy owners of Evolution W kit !
