May 19, 2015, 08:18 AM
TeamSiam
New Product
Jf-130 pro
Hello Folks,
We proudly present some pictures from our biggest new fan,
the "JF-130 PRO".
here you can see some pictures from different angles from our new beauty.
Keep whoooshing my friends,
Rainer
www.ejets.at
May 19, 2015, 08:21 AM
Need 4 Speed!
pdawg's Avatar
Awesome!
Latest blog entry: original Y/A F-18 Kit
May 19, 2015, 09:04 AM
Nice!
May 19, 2015, 10:08 AM
Official Boat Bum
Eddie P's Avatar
Wow. I'd love to see one of these close up... like in my shop! Are you using a JF80 shroud as a stand?
May 19, 2015, 10:29 AM
Classic jets rule
AIR SALLY's Avatar
Looks great my friend.....your fans are very impressive, in looks and performance and sound.
May 19, 2015, 10:35 AM
Pro Hoarder
turbonut's Avatar
Super Nice!
Latest blog entry: In flight
May 19, 2015, 12:03 PM
Dont forget the velcro straps
corsair nut's Avatar
son of a B! my f15 needs a couple of those bad boys!!!!
May 19, 2015, 01:05 PM
Hi Rainer,
Gratulation!
Hope to see you at WTD51 in 2 Weeks :-))
In the moment i build the Ultra Tribute, would be a nice Place for the 130 :-)
May 19, 2015, 01:20 PM
TeamSiam
Thank you my friends
Hi caps,
i'm very proud to bring it to good end with this fan.
Here we tried a lot of different motors, but didn't get the right performance out of all this 56-58mm motors.
Here the power level is overloading most of them, and if they had no issue with the power, they had poorly performances :-(
Was a long way to design a custom build motor and to get it into a serial solution!
But now we have the best 130mm fan on earth ( it's the only one :-D )
On the bench we had 13,2 - 13,5 kilos of thrust at 14s and 180-186 Amps, pending on the voltage of the single cells.
And the motor was pretty cool, even without the fins! It was just a security issue to add fins also, just to get a good feeling selling this beast to the consumer!
AND YES, it's an 80mm shroud :-)
AND we already got more than 15 kilos (33 lbs) out of it at 14s, just using another motor of this series.
But here we have again to develope and evaluate how to get a serial solution.
Personal i think that the 15,5 - 16 Kilo isn't an issue, pending on the cells and motor.
So my friends, keep whoooshing and whoooshing and whoooshing and .....
BR Rainer
May 19, 2015, 02:09 PM
DS JUNKY
Rainer what is the weight of the unit? Cost?
May 19, 2015, 02:22 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
What are the specs for the custom build motor?
May 19, 2015, 03:36 PM
kevin's Avatar
Very impressive Rainer. Next up, JetFan 100!
May 19, 2015, 03:44 PM
I'm guessing it will be a JF 110mm fan.
May 19, 2015, 04:03 PM
HAL... Open the damn doors!
jfetter's Avatar
Price, availability (date), order from?
Jack
May 19, 2015, 05:40 PM
kevin's Avatar
Im guessing you are right but I wouldnt mind seeing a 100mm.
