Jan 19, 2018, 10:59 AM
There are some here that will tell you that discharging to 3.3, 3.5, or 3.6 is bad for your battery. Not sure I agree with that but I don't believe there is any benefit to going that low. Pretty much everyone agrees that 3.7 is a safe floor.
Honestly I have never seen much evidence that any of this is helpful. If it were me I would just charge and fly and take it easy for a few flights if I thought there was any benefit, which I'm not sure there is.
Jan 19, 2018, 04:52 PM
EYEinSKY's Avatar
I am a little confused by all the suggestions . I do like the idea of a 3.7 V floor for cycling, as most advice recommends somewhere in the 3.8 volt area for storage. Have you ever had a battery manufacturer recommend the "Formation" charge cycle when batteries are new?
Tom
Jan 19, 2018, 08:30 PM
Originally Posted by EYEinSKY
...Have you ever had a battery manufacturer recommend the "Formation" charge cycle when batteries are new?
Tom
Not with LiPo. No, I've never seen that.
Jan 22, 2018, 10:05 PM
Thank you for the reply! I was hoping to automate this sequence they were talking about in Post #41 in "Ask the battery guy" thread. It seems like a good idea for the length of time my lipos are stored. I had also better do more advanced reading about my GT chargers to see if some of this capacity already exists. Perhaps use a set of 3 presets in sequence to accomplish this?
Quote from Post 41...
How would the formation function be different from the charge/discharge you can do on the powerlabs today?
Good Question.
Preconditioning works better on a controlled manner, especially after longer term storage.
That is maybe cycle 3.3 - 4.1V first at a lower c rate
then 3.5 - 4.15 slightly faster
and then a fuller cycle at 1C rate
OK, how about this? I program 3 cycles and save them in preset locations 1, 2, and 3.
I set up preset#1 to discharge to 3.3V, then charge to 4.1V.
I switch to preset #2, which discharges to 3.5V, then charges to 4.15V.
I switch to preset 3#, which discharges to 3.6V (I could use an official recommendation here), then charges all the way to 4.2V/cell.
These 3 presets accomplish the 3 states of discharge / charge needed to PreCondition or Formation charge the batteries after storage.
Now, if the 3 (or more) presets could AUTOMATICALLY be run in sequence, that would automate the entire PreCondition regimen.
Is this possible?
Sorry, the current firmware is not able to automate any programs.
Jan 23, 2018, 06:34 PM
EYEinSKY's Avatar
Ah, thank you Fong. But maybe in the NEXT firmware update???
Jan 24, 2018, 08:40 AM
Yes, we will put this idea into consideration for the next update.
Jul 20, 2018, 08:08 PM
I just recently updated the firmware on my GT500 to Ver V2.31. Tonight I realized it does not properly execute parallel charge mode. I have the parallel charge option turned on. I have the option to select my charge current and number of parallel batteries. However, when I start charging, the current peaks at the set point for a single battery.
I've experienced this with both 2 cell and 3 cell batteries. I also reinstalled V2.29 of the firmware, and the parallel charge operation returned to normal. When I install V2.31 again, the parallel charge feature does not work.
Has anyone else experienced this? Is there a change to the parallel charge method that I'm not aware of?
Aug 02, 2018, 09:32 PM
Is there a way to charge an 18650 cell on the gt500? When I go to unbalanced charge, it says 2s only. It's kind of frustrating. There's got to be a way to do it..
Edit:
Nevermind, after a little while, it let me do it. Maybe a bug in the firmware? In the next update, maybe have a dedicated setting for LiIon ?
Thanks!!!
Sep 26, 2018, 07:49 AM
Question on Pb 18 volts charging possibility
Hi everyone who is owner of this nice GT500!
Pls can you tell, if it will charge 18 volts Pb battaries?
Means does it have setting possibility to charge 9 cells Pb battery or setting possibility for 18 volts battery?
Thanks!
Discussion iCharger 106/206b vs FMA GT500 amheck Batteries and Chargers 11 Jan 05, 2017 09:36 AM
Question GT500 in Cycle mode trimmkm Revolectrix 1 Dec 29, 2016 06:41 PM
Sold F M A Direct GT500 Charger + Power Supply latebrake Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 19, 2016 11:45 PM
Wanted Jr gt500 gyro instruction book jetfighter2008 Aircraft - Fuel - Helis (FS/W) 3 Mar 27, 2010 10:29 PM
