This thread is privately moderated by bigtruck169, who may elect to delete unwanted replies.
May 07, 2015, 02:29 PM
hotwire stuff
cheap DLG for $75 with hotwire foam -https://www.rcgroups.com/forums/showthread.php?t=1532669
old thread, but lots of talk on the hotwire material -https://www.rcgroups.com/forums/showthread.php?t=436753
Weekend Project: 5-Minute Foam Factory (4 min 55 sec)
https://www.rcgroups.com/forums/show....php?t=1244763
How to make a Hot Wire Foam Cutter w/ FREE 12" NICHROME (8 min 19 sec)
Homemade foam cutter power supply and hot wire bow. (10 min 27 sec)
cheap foam wing cutter (4 min 25 sec)
https://www.rcgroups.com/forums/show....php?t=2410367
physics on hotwire - pdf - https://www.physics.ohio-state.edu/p...Per13_over.pdf
sharp your cutting blade ( post 3618)
https://www.rcgroups.com/forums/show...e#post26466898
https://www.rcgroups.com/forums/show....php?t=1824594
https://www.flyingfoam.com/
http://www.matneymodels.com/wingcut.html
http://www.eurekaaircraft.com/
May 07, 2015, 10:06 PM
Waste Nothing
RickC_RCAV8R's Avatar
You are my HERO ! I sometimes require a simpler foam cutter than the one that I generally use from time-to-time . This simply constructed version will fit the bill for both me and my flying friend Frank . Frank does not have a cutter at all and little time for making one . MAKE rules ! RickC
May 10, 2015, 07:25 PM
good u find this useful. hope will benefit other busy hobbist.
Jun 16, 2015, 04:21 PM
Waste Nothing
A friend dropped off an old electric train transformer for me a couple of weeks ago . A British made one with a variable 15 volt DC output . (@ 4 Amps max.) This would work perfectly for a table top version foam cutter using an old 10 inch table saw as the base . Thanx for your interest in this . New foam cutter posting to come soon . RickC
For Sale Vacuum bagging stuff and hotwire cutter power supply. Disp0sablehero Aircraft - Sailplanes (FS/W) 6 Jul 18, 2016 10:29 PM
