Custom HDMI Cables
Anyone who has used DSLR's or higher end cameras with HDMI output has probably been frustrated by having the wrong size HDMI cable or needed a 90 degree angle on the connector to make it fit within a gimbal...
Finally Get the Right Cable
Anyone who has used DSLR's or higher end cameras with HDMI output has probably been frustrated by having the wrong size HDMI cable or needed a 90 degree angle on the connector to make it fit within a gimbal. Up until now it has been fairly hard to find the perfect cable for your needs. Aerial Pixels is offering a service that should solve most of our woes. The custom HDMI cable service is available on their website and allows you to spec out the length of either 15 or 30cm and connectors used on each end so you can be sure you are getting what you need. They can be a little pricey at $43-$56, but getting the perfect cable without using finicky adaptors and excess cable is worth it. Check it out at Aerial Pixels.
May 02, 2015, 12:56 AM
They should offer hyper thin and flexible cable too. That would be sweet!
Question Custom hdmi cables ulkar Aerial Photography 1 May 13, 2014 06:11 AM
