This thread is privately moderated by bigtruck169, who may elect to delete unwanted replies.
Apr 29, 2015, 09:56 AM
notes
LED Lumen to Watt
To replace a 100-watt incandescent bulb, look for a bulb that gives you about 1600 lumens. If you want something dimmer, go for less lumens; if you prefer brighter light, look for more lumens.
Replace a 75W bulb with an LED bulb that gives you about 1100 lumens
Replace a 60W bulb with an LED bulb that gives you about 800 lumens
Replace a 40W bulb with an LED bulb that gives you about 450 lumens
print car body with design. Liquid Masking Film
http://www.amazon.com/3010-Liquid-Ma.../dp/B000X4J7UW
prop saver video
https://www.rcgroups.com/forums/show....php?t=1419378
KONTRONIK FUN480 3300KV WITH KPG4.2
COMES IN ORIGINAL BOX.
My plans changed i decided to go pylon instead of folder.
i'd like $120 plus shipping and fees, so $130 out the door
you could do the following setups on this
13x8 on 3S, pulling 38A, glider, warmliner to 2.5m, Siren, Orion, all esprit glider etc..
14x6 on 3S pulling 31A, glider, very warmliner up to 2.5m (slower, more thrust)
10x12 on 3S pulling 45A small pylon racer, 50", decent speed, Swift, or reverb from hobbyking, plasma etc.. sunracer
10x12 on 4S pulling 74A, fly burst, up to 8 seconds throttle, Swift, or reverb from hobbyking, plasma etc.. sunracer
10x17 on 4S pulling 90A, fly burst up to 5 seconds throttle. Swift, or reverb from hobbyking, . sunracer, xplane, viper
14x14 on 4S, fly on switch, 3 to 4 seconds burst, 100A ESC
12.8x13 on 4S fly on switch, up to 6 seconds burst, 100A ESC.
50mm edf for smaller jet
used this
http://www.x-flight.com.hk/index.php...faa743&lang=en
with a 30 amp esc I fly mostly on 3 s
with a 1000 mi 45 c 3s lipo with great performance
and flight time approx 5 mins
video of them flying
2 50MM SKYANGEL HAWKS (2 min 31 sec)
Sawtooth 9.5x24/6mm/30mm
They are used in F5D pylon racing. It's an FAI international class. I have a GM 10x23 carbon prop right now, but the 9.5x24 has a bit more rpms and a better bite and using less current draw. This stuff is usually direct from the makers in Europe. It's specialty stuff; you'll never see this sort of thing in any mainstream shop or website. These props are custom made and go around $75. to $200. each! My GM is from Ukraine. It's a $95. prop. The motors are specialty too, as well as the planes that are 100% carbon. These planes are around $1300-1900. ready to fly.
Soaring USA is one of the main US distributors. And there's Big Bruce Racing in Australia and Down Under Pilot from New Zealand. But Bruce DeChastel is now only doing the Sawtooth 12x25 props. Those are for a different set up.
tricopter
motors will swing a 10 - 11 inch prop with a 3s battery and a 9 inch prop on a 4s battery.The plans are here http://www.thingiverse.com/thing:231205
For Sale Galaxy Note 5 Verizon 32gb Sapphire hjstaples Non R/C Items (FS/W) 0 Aug 09, 2016 01:31 PM
Discussion Maybe a brighter note? Norman Adlam Life, The Universe, and Politics 4 Jul 26, 2016 09:54 AM
Found note 4 or note 5 airfilmx Non R/C Items (FS/W) 0 Apr 25, 2016 01:56 PM
Contest Deleted note...Discare Note.. guyg Aerial Photography 1 Aug 19, 2009 11:33 AM
