Apr 17, 2015, 03:09 PM
rsrguy3's Avatar
Build Log
Guys' Tiger 2 electric conversion
Here's my take on how to electrocute the CG Tiger 2. First a little background. I bought the partially built kit at this year's swap, the wing had been rough framed and sheeted. I've done the rest .
I'm installing the Firepower 40 800kv (4250-8)
With the Hurc 80amp Opto ESC and a ubec.
I've always had good luck with the equipment I get from heads up rc so I just stepped up in size from the freedom I shocked last year, and let me tell ya it flys awesome. Servos will be a mix of whats on hand with one on each aileron torque rod.
Apr 17, 2015, 03:20 PM
rsrguy3's Avatar
pics
Test mounted for preliminary balance
Apr 17, 2015, 10:58 PM
rsrguy3's Avatar
Here are the fillets after sanding, and my mod for the conventional gear install.
Apr 18, 2015, 06:54 PM
rsrguy3's Avatar
center section
I glassed the center section with fiberglasst resin and satin cloth mms
Apr 18, 2015, 08:26 PM
I just want to go fly!
walter3rd's Avatar
i like the shape of that fuse. looks sweet. i just electrified this 80s pattern plane as well. maiden in the books today. groovy!
Apr 18, 2015, 08:51 PM
rsrguy3's Avatar
That spinner is stoopid cool. Where did you get that idea? Ground clearance?
Apr 23, 2015, 09:11 PM
rsrguy3's Avatar
I did some preliminary balance and found a nose heavy condition (2- 3s 5000) so I eliminated 51 grams from the nose, I'll also be integrating a long battery tray to make an adjustable battery bed system. This will accommodate the balance for my different battery packs.
Apr 28, 2015, 08:40 PM
marmalade1's Avatar
Looking good!
Apr 29, 2015, 08:54 AM
rsrguy3's Avatar
Thanks, here are some more pics, these are of the custom battery tray (variable cg for different batteries). And the pop top canopy.
Apr 29, 2015, 09:21 AM
rsrguy3's Avatar
Here's the high amperage XT-60 arming link.
Apr 29, 2015, 09:49 AM
Electric baptism 1975
DavidN's Avatar
Looking good. I have a kit on the shelf. My current project is a CG Super Chipmunk.
May 01, 2015, 12:49 AM
rsrguy3's Avatar
I'm starting this one as well.
https://www.rcgroups.com/forums/show....php?t=2404236
May 03, 2015, 10:32 PM
rsrguy3's Avatar
Finally finished the removable canopy.
Jan 06, 2016, 12:22 AM
rsrguy3's Avatar
I'm balancing for servo placement tomorrow, once I finger that one out I'll cover the fuse. Anyone have negative experience with running servo extensions without any ferrite rings?
Jan 07, 2016, 08:16 AM
Fly to live- Live to fly
ultimatetwo's Avatar
Good job done on the plane and the conversion... I built a couple of these Tigers and the Tiger 2 when they were launched to the market by C.G....
My humble opinion is that if you use 6volts for the battery and a 2`4 ferrite are not neccesary at all...
Regards.
Manolo.
