Jun 18, 2015, 09:00 PM
Originally Posted by Liv2Die View Post
I run this game with a dx6 and the Phoenix dongle and it works fine, are you making sure that you don't turn the controller on but let it turn itself on when it gets plugged in? I know it won't work if you turn the switch on
Yes sir tried several things all give same result.
Quad takes off in one direction and basically flips.
I plug in dongle...TX turns on..I never turn switch on with the sim.
All works fine with my HeliX sim.
The only difference between this Sim and HeliX is that HeliX allows end point calibration this one does not.
That's were the other possible solution programs come into play. Also I have a DX8.
Jun 18, 2015, 09:03 PM
Originally Posted by will_newton View Post
Successfully got my DX8 working with Freerider on Mac OS X!
1. I use the FMS simulator USB adapter. http://www.amazon.com/gp/product/B00...ilpage_o01_s00 Other USB adapters with the audio jack style may work as well. I'm not affiliated with the seller and you may find one cheaper/better somewhere else.
2. Download the newest version of Freerider. It is a shame there are not version numbers available that I could find, but I downloaded today's version. Apple will not let you do the install right off and you will have to go to the System Preferences-Security and check the "Open Anyway" button
3. Now, this next part may or may not work for you, but cross your fingers and hope for the best and make adjustments accordingly. You may have a different USB adapter or your radio or computer or software may be different. This is what worked for me and my radio today. If you fly a different stick Mode, your configuration may be different from mine.
  1. Set up a new Acro model in the DX8 and name it "Freerider" or something.
  2. Under servo setup, reverse the throttle channel.
  3. Turn off the radio.
  4. Plug the FMS adapter audio jack into the DX8. Your DX8 will turn itself on in "Slave" mode. Do not use the switch to turn on your radio. The adapter will do it.
  5. Plug the USB end into the Mac. You should see a red LED come on in the USB housing.
  6. Start FPVFreerider. Select as follows: Input-USB Controller, Throttle zero at center, Dead zone is on.
  7. Click on Calibrate Controller. You will see a row of circles below a joystick and instructions for calibration. Do not calibrate yet! You see that row of circles? Toward the left there are four that are probably out of line (circle 1, 2, 3, and 5). Wiggle the sticks and you should see four circles go up and down as your radio talks to the software. Got no wiggle? Then you have no connection.
  8. The circle on the far left is your throttle, it is probably fine where it is if you have done the proper reversing, so don't worry about that channel. What you need to do is try to line up the errant circles with the aligned ones. You will do this with the stick trim tabs AND with the SUBTRIM function in the servo setup. I had to apply stick trims at 100% left rudder, 100% left aileron, 100% forward Elevator. I needed more and so I added 100L rudder, 100L Aileron and 100D Elevator from the SUBTRIM menu. Yes, it takes a lot!
  9. Now do the calibration. Follow the instructions onscreen, and perform the following actions, one at a time, with the other sticks untouched: Apply left rudder with throttle at center. Click OK. Apply full throttle. Click OK and pull throttle back to center and leave it there. Apply full left aileron. Click OK. Apply full forward pitch. Click OK and finish.
  10. You will return to the main screen. Next, pick a flying site and cross your fingers.
  11. You should be resting on the ground waiting to take off. Give it some throttle to lift off and check your controls for proper operation. If the throttle won't turn off, or flips you over, or doesn't behave normally, something is not configured correctly, or you may not be able to use this particular instruction set. Hopefully, it will lift off and it will probably be slow and dopey, but correct. Click on the High rates and go flying!
  12. Smile!
One of the keys was that I figured out Step 8. Freerider operates a bit like Cleanflight. If your reversing and trims are not in the right place, it will not perform as planned, even if your channels are correct. Much like a different receiver may translate/output slightly different PPM signals than CF is expecting, if the FMS adapter sends an unexpected signal to Freerider, it will perfom poorly as well. So you must adjust your radio accordingly. The FMS adapter only sends four channels, so don't expect a lot, but it will get you what you need. Also, I bet I have just laid it down the DX8 with FMS adapter poking out the back and being bent sideways, again! So look out for that!
I am using the free version of FPVFreerider currently, so I know you don't have to pay to find out if it works. I JUST got this set up and have spent more time typing than flying on Freerider. I will mess with it a bit more and upgrade to the full version soon.
I might also suggest the Gamepad Companion OS X app. I have not tried it 100% with this Freerider, but it did recognize the DX8 and allow me to assign keyboard shortcuts to the radio. I did not fully explore running Freerider with it, as I figured out how to make it work using the above method, but it may help someone else.
I hope that helps some folks. I also hope this info will apply somewhat to Windows users as well having trouble getting their DX8 hooked up.
Edit: If you are the maker of FPVFReerider, and think this is useful, then feel free to add this to your website or manual as full copy or a link. Thanks for the cool software and for thinking about Mac users!
I will give it a shot and let you know.
Yes the TX is active and the circles all move before calibration.
Jun 18, 2015, 09:25 PM
Are the numbers moving correctly when calibrating?
Jun 18, 2015, 11:06 PM
Flykam's Avatar
Hi, here is how I set up my Taranis Plus to play on my WIN 8 64bit computers.
Taranis Plus Radio Set Up FPVFreerider Win 8 64bit (4 min 3 sec)
Jun 19, 2015, 01:47 AM
This sim is awesome..its part of the reason that I got more confident and am now practicing harder:
ImmersionRC Vortex FPV - Flips/Rolls Practice (3 min 6 sec)
Jun 19, 2015, 03:20 AM
My portable sim with Freerider. Love it.
And my desktop setup. Sorry about the messy desk with all the vaping gear.
Jun 19, 2015, 02:38 PM
how are you inputting the devo into your android?
Jun 19, 2015, 04:26 PM
We Do It With FRQZ
RM_Sparks's Avatar
Check this out guys!!! How's that for a dongle!?
http://www.goodluckbuy.com/usb-dongl...-receiver.html
Jun 19, 2015, 07:11 PM
Will
You are a Genius
...and a very patient man
Thank you very much I am now in a controllable state and flying.
You were right it took both trim and sub trim to pull it normal.
Funny though...reversing throttle? It worked LOL
Now I can flip the man 5 bucks and get more maps
  12. Smile!
Jun 19, 2015, 08:10 PM
How are you using the 7e?
Jun 20, 2015, 05:52 AM
With a USB OTG cable
Install Deviation and set up as a USB controller
Jun 20, 2015, 07:45 AM
I figured out how to put my 7e in USB mode but when I go to calibrate it in the game is selects the wrong stick input and makes the copter spin wildly out of control. Any help would be appreciated. Thanks
Jun 20, 2015, 06:27 PM
wishes this caption was longe
will_newton's Avatar
Hey Clayton, thanks. I don't know about being a genius, but I make a skilled guesser and had a little luck. I am glad to know someone else got it going as well.
As an update, I went ahead and purchased as well. The other flying sites are neat, but the main reason I would pay is to access the custom settings. The stock quad flies OK, but being able to get it to fly like my quad does was a bonus.
Is this a perfect FPV flight sim? No. But as they say,"Don't let the perfect be the enemy of the good." I am quite happy. I have owned several versions of RealFlight and never thought it was worth what I paid. I feel like this simpler program is worth more than I paid.
Will
You are a Genius
Jun 20, 2015, 07:17 PM
Tried to search but on phone so sorry if it's been asked already, is it possible to map flight mode and rates to switched on my taranis?
Jun 20, 2015, 08:27 PM
Jasonboz56's Avatar
Will these be available for iPhone?
Discussion FPV Freerider - Quadcopter racing simulator trase Simulators 22 Sep 28, 2016 11:05 AM
