midelic: Glad you managed to solve it!
OKCjohn: Yeah as OLderDan points out it's probably something you can just trim to get it dead center. Select Calibrate Controller on the main menu and then "Go to Trim Settings" in the bottom right corner. On the Trim Settings screen you can see the stick input. When your controller sticks are in the center, the circles on the screen should also line up dead center. To get it right, you can either add some trim on the controller itself (recommended). Or, if you still can't get it right you can add some digital trim on the trim settings screen using the on screen sliders. (You will notice as you progress in your flying skills it will be less important to have perfect trim, since your brain will automatically correct it). |
Are also other levels available? I am speaking about the level showing here. I also encountered an error when trying to make a BIG complex (too many objects) level. It said "Low memory" or something like that, and I was not able to save the level.. |
The level in that video is from the original version of Freerider -
Android: https://play.google.com/store/apps/d...ride.Freerider Windows/Mac/Linux: http://fpv-freerider.itch.io/fpv-freerider (That version also has a racetrack generator which can automatically create an almost infinite amount of gate arrangements at the press of a button). I see, wow that must have been a large number of objects indeed, I've never encountered this myself. Good thing you were able to save it anyway. Generally speaking, level editing is a lot easier on the computer version since you generally have a bigger screen as well as mouse and keyboard input. When doing extensive editing on android I would recommend connecting a mouse and keyboard to the android device (either by USB or bluetooth). |
Hello Y’all,
I am a Spektrum radio user. My question is about the BetaFPV LiteRadio 2SE Tx. I want a rx that is compatible with Freerider. I would either use this transmitter with my MacBook Air or an android tablet. I have a dongle for the Spektrum and I’m able to use it with the Mac. Has anybody used this Tx with Freerider using a Mac or an android tablet? Please help, Tony |
I haven't tried it myself but I've heard from one person who said it was working fine out of the box on his Mac Mini. I have also heard reports that it is working on Android. Can't guarantee it though, there are so many different devices around. Guess the only way to know for sure if it will work on your devices is to try it yourself.
On the Mac you should be able to connect it using a regular USB cable. To connect it to an android phone you need a USB OTG adapter. (If running the simulator on Windows you might need to change the endpoints. Since the radio has no screen you need to use the "Opentx Companion" app. Change the Weight from 100% to 50%, and the Offset from 0% to 50% for each axis. You can this mode to a switch so you can use the radio for both simulator and real life flying. There is more info including explanatory pictures in a post in this thread). |
Minimalize Freerider screen in Win10?
I've been practicing FPV using this sim, slowly crashing less...
What bothers me, is that I can't minimalize the screen size, like all other programmes can by clicking the '-' sign in the too right corner, because it's not there... If I want to do something else, I have to shut Freerider down completely (and restart it if I want to resume). Did I miss something, or does this function not exist in Freerider? Regards, Jan. |
./FPVFreerider.x86_64 -screen-fullscreen 0 -screen-width 1280 -screen-height 720 From the command prompt in winders: FPVFreerider -screen-fullscreen 0 -screen-width 1280 -screen-height 720 /or any other size window you want. //not sure if FPVFreerider is the name used to start the sim - haven't used winders in a long time. |
Thread Tools | |
Similar Threads | |||||
Discussion | FPV Freerider - Quadcopter racing simulator | trase | Simulators | 22 | Sep 28, 2016 11:05 AM |
