This thread is privately moderated by herk1, who may elect to delete unwanted replies.
Apr 13, 2015, 03:11 PM
Herk pilot emeritus
herk1's Avatar
Bix3 tricycle gear mod
I got a Bix3 for FPV, and especially wanted to do takeoffs and landings in FPV. But the ground-handling with the stock tail-dragger Bix3 landing gear was atrocious. The plane would jerk 90 degrees to one side as soon as the tail gear lifted off the ground on takeoff roll. I finally fixed that by bending the main gear wire (which appeared straight to begin with, but whatever works...). That fixed takeoffs, but then landings were messed up -- the plane would ground-loop right after touchdown. The stock tailwheel mount is really a loose, rickety affair, and the long pushrod which splits into two rods (for the rudder and the tailwheel) is flimsy and a pain to deal with.
So I modified my Bix3 to give it tricycle landing gear. Now the ground handling manners are solid and smooth for taxi, takeoff and landing. I used this trike-gear set:
https://www.hobbyking.com/hobbyking/s...th_Servo_.html
The main gear is mounted onto a piece of lite ply of similar dimensions as a paint stirring-stick, which I threaded through the fuse foam at an appropriate distance aft of CG.
The nosewheel part fit like a glove onto the Bix3's nose, with very little trimming -- all I did was expand the cooling inlet forward to the edge, then slide the nose-gear servo shroud into the slot (secured with hot glue). Photo attached (I temporarily removed all my FPV gear to test the gear mod). I haven't decided if I'll put the nose cone back on or just leave it open for cooling.
Apr 13, 2015, 06:45 PM
jjmelo's Avatar
Awesome! Thanks for the tip. I could use that trike landing gear on other stuff!
Latest blog entry: Melo3D XL: 400mm3 3D Printer
Apr 14, 2015, 05:08 AM
ɹǝʎןℲ ǝıssn∀
taz101's Avatar
Looks good!!
I did the same with my Bixler1. But used the land gear parts for the Bixler2 for the main landing gear and also put a set in the front like the Bix3 now has. I can now just swap between Tricycle landing gear and Taildrager landing gear and also my floats.
I will soon (when I get time) mod my Bix3 to the same setup!
LURCH
