Nov 23, 2016, 04:12 AM
Itry to hook up Cesco mod to replace the stok 27mhz radio...as he shared the file.
Nov 28, 2016, 01:56 AM
hi ... i got error
exit status 1
'setupRX' was not declared in this scope
May 08, 2017, 01:17 PM
You have to move all files in same folder,the main sketch could not find companion sketch.
Nevertheless very nice project,I have been trying to find this modd.
Jun 14, 2017, 05:02 AM
Hi,
SerialOpen() compile error fixed.
Serial.ino
Line47:static void inline SerialOpen(uint32_t baud)
change
static inline void SerialOpen(uint32_t baud)
or
static void SerialOpen(uint32_t baud)
There is no need to define inline clearly?
Jul 28, 2017, 02:55 PM
Hi all,
this is my first post and I hope anyone can help me.
I have a HL Tiger at home, an RX 18 and a Spectrum Satellite. So it should be the same setup like Cesco's one.
But I'm realy new with arduino.
So perhaps anyone can say me what I have to upload to the arduino board step by step?
Thanks for your help!
Jan 09, 2018, 08:31 AM
Hi, the original sketch on git hub has been deleted. Could someone please reply with the sketch. Thankyou for anyhelp
Jan 30, 2018, 03:03 PM
Hello! Try it:
Mar 10, 2018, 03:21 PM
Originally Posted by Stal
Hello! Try it:
Hello Stal,
is it possible that you can explain what to do with these files?
Or what has to be written on the arduino board?
Thank you for your help!
Nov 05, 2018, 10:49 AM
Hello) All) I am the new owner of RX-18. I understand that and how to solder to arduino, but I can not flash my Board. Missing files:
wdt.h
arduino.h
and the compiler in the Arduino IDE this gives an error:
the compilation has completed.
output status 1
avr / wdt.h: no such file or directory
Dec 09, 2018, 09:14 AM
if u want to use arduino on heng tanks,
u will want to buy the arduino nano board or any other board will do.
then goto college to learn computer programming.
then enjoy.
Dec 20, 2018, 12:13 AM
then enjoy.
I'm sorry, but I didn't get your answer.
Jun 25, 2019, 12:53 AM
Question
Originally Posted by Cesco
I am new owner of a HengLong Tiger 1.
I want to substitute the 27mhz radio for a 2.4G one. But the HL radio is not what i am used to from normal RC gear. The protocol is completely different. I did hook up my oscilloscope and made some pictures.
This is a digital serial protocol an nothing like the conventional PPM. The data stream is sent over 27mhz radio and fed into the RX18 as is. Unluckily the available products like IP4HL, RC5HL, DBC2 dont tell me anything about the protocol and are not open source.
I did grab an arduino and made a sketch to read the stuff. Input is pin2, output is over serial line 115200 baud. Source is attached.
Hello) Dear) Prompt me a layout of channels of the transmitter FrSky on the tank. I repeated your project. The receiver is connected via a signal pin.
P. S. In the layout AETR and TAER tank does not start
