Apr 05, 2015, 06:36 PM
A different attitude to RC
extremewing's Avatar
Mini-HowTo
Adding wireless charging to the Taranis
With a renewed interest in wireless charging, I was given some USB, 5V 500mA wireless receivers to play with and so this is what I did with one today.
The images detail step by step instructions for installing a wireless charging system in your Taranis. With this mod you can still use the wired charger as usual.
I take absolutely no responsibility if you damage your Taranis in any way from following these steps. Make sure you work neatly and nothing is left loose inside the radio.
Parts:
- Wireless charging receiver.
- Pololu step up regulator.
- Some wire, double sided tape, multimeter and a soldering iron.
For flexibility in experimenting, I used this variable output step up converter form Pololu: https://www.pololu.com/product/2570
This one should also work: https://www.pololu.com/product/2117
The charge pads are on eBay. I have some 1A receivers on the way too.
Before installing the electronics, you should test them.
- Solder the wires from the wireless charger receiver pad to the regulator INPUT.
- Set the receiver pad on a wireless charging transmitter and measure the output from the regulator.
- You want to measure at least 12V (a bit more is good, like 12.4) for the Taranis to initiate charging.
On the bench with a power supply, I measured 120mA or so to the Taranis charge port (with a solid green light).
On the wireless charger, the Taranis also drew the same when measured with a multimeter.
Please let me have your feedback and Enjoy!
Adrian
Apr 05, 2015, 06:50 PM
See the other thread for charging a plane (in this case a DLG) wirelessly.
https://www.rcgroups.com/forums/show....php?t=2385736
Apr 06, 2015, 03:54 PM
Limbo with 30,000V...
J_Arner's Avatar
Sounds like a good project. Thank you for sharing.
