First off, I fly Blade Chroma...I like it but it has its limitations. Please convince me that i will be more than amazed by a P3P. How is connectivity in suburban areas? Dont worry lots of green spaces..
Range is outstanding. and the video feed quality is great as well, There is simply no other camera quad that can produce the results the P3 can, Its a tripod in the sky. The only thing that betters it is the Inspire . |
Latest blog entry: DJI OSMO Pocket Review - Unboxing -...
Any headwind subtracts from that speed (noted in many stories over recent years), hence the need to be aware when flying far away down wind as RTH might not get it back before running out of battery. |
In GPS mode input is interpreted as moving at a set speed to a certain point/direction rather than angle, so its returning to location, bank angle will be based on on whats needed to achieve the desired speed, however this is within the limits of wind, looking at all my logs RTH is generally around 9- 11ms in normal conditions, but if the wind is enough to overcome forward force then speed will drastically reduce. Looking over my logs iv noticed first of all that i not often use RTH, far less that i would have thought tbh, of the ones i have done the majority have been 9ms but the odd one at 11ms but a few well below 5. It possible DJI have instigated it based on ATTI mode and input is correlated to bank angle but its unlikely, It may be bank angle but i don't believe it is, regardless both will be affected by wind. |
Thank you Mad Angler
I ran my Headplay glasses till the battery went flat. Mad Angler posted that I had to re set the battery by using a 9v battery and hooking it up to the Headplay battery and then it could be charged. I have to admit that I was very skeptical. I hooked the 2 batteries together for about 10 seconds. Plugged in my lipo charger and lo and behold the battery charged!!
Thanks Mad ![]() |
My Phantom came with the new version shell with the extra webbing that you can see down along side of the motors. I also had the larger vents. I'm not sure if it had the X brace or not. I bought is just over three months ago. Last time out after flying three batteries I found one major and two real small cracks in the lower shell during post flight. The major crack is between screws as seen in the photo. Dealing with DJI for repair here in the States so far has been nothing but great. If there is a 3rd gen shell I sure hope mine has it when it comes back for DJI.
I have mine set to 1 Day on all batteries which I have always used and always worked no longer seems to be working -- Batteries are not going into Self Discharge--and I am not pushing the on button on the battery which would reset the timer button in the past--I have let 2 Batteries sit for 5 Days touching nothing--checked that it is set for Discharge in 1 day and and both Batteries still show full charge after 5 days!! Thanks Jack |
Official Phantom 3 Professional / Advanced ***Owner's Thread*** First post h...Quote:
Odd, not seen many other reports of it, there has always been the odd report of it but nothing conclusive. Try setting to 10 days, leave 24 hours then set back to 1 day again and see if that resets it. I also note you have posted in both the P3 and I1 thread, what product is it affecting ? Both are not the same FW |
Jack |
![]() Cheers, Jon |
No problem ![]() Affects both the Headplay and Fatshark. Batteries. I did the same thing my self, I found this out after I split my pack in half and found the circuitry then twigged then tried a few things and got it to charge Could have saved my self an hour of messing if I had just looked online. The main problem is a lipo charger won't start the process unless it detects a voltage. Originally HP included a basic mains adapter to charge the packs and with that it was not an issue as it was just cv charge and would work. They later moved to the Hyperion packs that are larger capacity but they removed the charger. I think the RMRC still have the adapters as they buy the googles with out battery and add their own. Just some info for you |
![]() Cheers, Jon |
RHO lens for Headplay glasses, 2 thumbs up
Hi guys. Recently I bought a set of Headplay glasses to use with my P3. I'm 53 and need reading glasses for close up things.
I was bitterly disappointed that I could not focus on the LCD screen. I tried the two lenses that came with it but no joy, I tried using reading glasses and again no go. I ordered an RHO lens from Ralf in Germany I thought it would be my last kick at the can. I was really surprised at the quality of the RHO lens, it has a little weight to it and is quite "thick." After fitting it into my Headplays and turning them on I was shocked at how clear and in focus everything was. Thanks to RHO for a tremendous product ![]() http://www.rho-lens.com/ |
