Thread Tools |
This thread is privately moderated by Red.Sneakers, who may elect to delete unwanted replies. |
Data
Flight Log Debrief ReportsAfter modifying HobbyKing Altimeter down to an all-up weight of 1.8 gram & powered by the flight battery, I have started to record some flights to learn more about the characteristics of my planes & help me become a better pilot. I will record more flights as the season progresses. They will be posted here, each with a specific question answered, like what is the glide rate, how fast can I loose altitude, why am I floating under Nimbostratus clouds... Great little Speed Conversion calculator click here Keep Warm at the Core! U & the Batts click here Flight Logger, Part II “1s Power Mod” click here Flight Logger, Part I “The Bench Test” click here Triangulation Calculator, click here Join the RCG discussion click here This blog includes reports for ~ umx Radian ~ ~ umx Sport Cub S2 ~ click on images to view larger ~ ~ ~ ~ ~ Sport Cub S2 Stratus 2 Scariest flight ever Last Spiral 22.9fps / 15.6mph Flight log from June 12, 2015 click here ~ ~ ~ ~ ~ Sport Cub S2 Stratus 2 Eiffel Tower sortie with 800+ foot spiral Flight log from May 7, 2015 click here ~ ~ ~ ~ ~ umx Radian Debrief report on a 13+ min thermal ride Flight log from April 12, 2015 includes graph click here ~ ~ ~ ~ ~ Sport Cub S2 Stratus 2 ![]() ![]() Debrief report on a 27+ min sortie Flight log from April 12, 2015 click here ~ ~ ~ ~ ~ umx Radian Wind Surfing Max altitude 37 feet Flight log from April 3, 2015 ![]() … Aero: umx Radian … Field: Oval … Time: 12:46PM … Temperature: 63°F … Average Wind: 3 mph W … Gusts: 12mph NW … Humidity: 64% … Pressure: 29.84" rising … Cover: Stormy … Streamers attached: no … Battery: Mini Aviation 220mah 45C … Battery warmer used: Yes set to 95°F … Enjoyed a 6+ min wind surfing sortie Weather conditions: Winds steady, heavy gust, light turbulence. Note 1: Added weight of the logger & 220mah batt surely helped. Landing on the downwind wheel or wing tip is never pretty. ~ ~ ~ ~ ~ Local conditions: umx Sport Cub S2 Power off glide plus spiral mode 2 & 3 3.0 / 13.2 / 21.0 fps Flight log from March 31, 2015 ![]() ![]() ![]() ![]() ![]() … Aero: umx Sport Cub S2 aka Stratus II … Field: Oval … Time: 8:47 am … Temperature: 38°F … Average Wind: 3 mph W … Gusts: 11mph N … Humidity: 59% … Pressure: 29.84" … Cover: Party cloudy … Streamers attached: yes … Battery: Hyperion 550mah 25C … Battery warmer used: Yes set to 95°F … Power off glide descend 263 feet, 1 min 28 sec / 3.0 feet per sec / 2.0 mph / 3.3 kph … Mode 2 (aka Intermediate) Spiral (full rudder, full aileron, power off) descend 172 feet, 13 sec / 13.2 feet per sec / 9.0 mph / 14.5 kph … Mode 3 (aka Expert) Spiral (full rudder, full aileron, power off) descend 126 feet, 6 sec / 21.0 feet per sec / 14.3 mph / 23.0 kph … Enjoyed a 1 min 45 sec tour at 240–279 foot / 73.2-85.0 meter AGL … Total mission lasted 10 min 9 sec. Weather conditions: Winds steady, light gust, no turbulence. Note 1: Due to the CG, the 550mah battery is placed mostly inside the fuse & is therefore protected from the wind & temperature. Voltage reading was 3.91 at room temperature - Actual amps recharged = 185 mah or 42% used. I did not hit LVC during flight. ~ ~ ~ ~ ~ Local conditions: umx Sport Cub S2 Rate of climb, spiral mode 1, 550mah battery 5.3 / 12.4 fps / 10+++ min Flight log from March 27, 2015 ![]() … Aero: umx Sport Cub S2 aka Stratus II (mode I – stability) … Field: Oval at White Lake Park … Time: 3:00 pm … Temperature: 40.1°F … Average Wind: 5mph NW … Gusts: 19mph NW … Humidity: 30% … Pressure: 30.18" dropping … Cover: Clear blue skies … Streamers attached: yes … Battery: Hyperion 550mah 25C … Battery warmer used: Yes set to 104 F … Rate of climb: 5.3 feet per second / 3.6 mph / 5.8 kph … Spiral rate of descend (full rudder & full aileron = lazy spiral): 12.4 feet per second / 8.5 mph / 13.6 kph Weather conditions: Clear blue skies. Gusts, heavy turbulence & sink present. Note 1: Due to the CG, the 550mah battery is placed mostly inside the fuse & is therefore protected from the wind & temperature. Very happty with the cold weather performance of the battery. 10 min sortie. Voltage reading was 3.86 at room temperature (52% of practical capacity left = 550 x 0.80 x 0.52 = 229 mah left / 48% ~ 211 mah used) - Actual amps recharged = 216 mah or 49%. I did not hit LVC during flight. Note 2: In mode 1 – stability (beginner), the lazy spiral was caused by a) windy conditions & b) the system's attempt to stabilize the spiral. Good to know that even in mode 1, you can spiral the plane with full rudder, full aileron & motor off, thereby overriding the stability system, to an extent, when you need to drop altitude ‘rapidly’. ~ ~ ~ ~ ~ Local conditions: umx Radian Rate of climb, glide 7.6 / 1.5 fps Nimbostratus clouds Flight log from March 26, 2015 ![]() ... Aero: umx Radian aka umx Rad II ... Field: Oval at White Lake Park ... Time: 9:39 am ... Temperature: 45.1°F ... Average Wind: 0mph SSW ... Gusts: 6mph SSW ... Humidity: 78% ... Pressure: 29.9" dropping ... Cover: Nimbostratus clouds ... Streamers attached: no ... Battery: 220mah 45C ... Battery warmer used: Yes set to 95F ... Rate of climb: 7.6 feet per second / 5.2 mph / 8.4 kph ... Spiral rate of descend: n/a ... Glide rate of descend: 1.5 feet per second / 1.0 mph / 1.6 kph Note 1: Nimbostratus clouds covered the entire sky, with a homogenous gray appearance. Nimbostratus occurs along a warm front where a slowly rising warm air mass is present. Flying under a Nimbostratus cloud provides a very smooth relaxing ride. ~ ~ ~ ~ ~ umx Radian Rate of climb, spiral 8.6 / 50 fps a great flight with thermal activity Flight log from March 24, 2015 ![]() Here is why I will always fly my umx Radian II with a Logger. Most days, boring but on a day like today, much appreciated. Again, boring flight, so I induced a spiral to see how fast it would come down. Spiral rate of descend = 50 feet per second / 34mph / 55 kph Them ![]() ![]() Note 1: Rate of climb - range: 8.6 / 9.9 / 4.7 / 5.5 feet per second. What may cause a wide range of climb rates? I find that sink will hamper the rate of climb, worse case it will look like you hit a glass ceiling. In these cases, best to try a different part of the sky. On the converse, when climbing in a thermal, the rate of climb will be significantly increased. For today, I believe the drop in the rate of climb during the flight was due to the voltage drop of the battery, i.e. lower prop rpm. ~ ~ ~ ~ ~
Actual results will vary, the question is why? ![]() |
All currently possible but at a much higher weight penalty. Due to the new FAA drone rules, you will see some of these features integrated into the Rx in the next 5 years or so, me thinks. First one will most likely be altitude telemetry. We will have to stay tuned.
Reason: update
