sn20a are still holding up well on my 2208/20 6x4.5" ship
Latest blog entry: Unoffical FrSky Horus X10 and X10S...
Hi, friends,
Regarding the DYS mini esc issue, before some customer reflected the mini esc will be burnt easily and it cannot work with the motor properly, until now for some study and testing, we find the solution. All the mini escs no need to send back to the dealer now. It just need to upgrade to BLheli 14.0 version to avoid these issue now. Please take a little time to upgrade the version to save more time for your flight. Sorry again for the inconvenience to you. Thanks & Best Regards, DYS |
Advice...
I'm going to direct solder SN20A's signal & ground directly to the naze due to space restraints... How do you all update/change settings on ESC when directly soldered to naze? Any tips? |
Meanwhile two of these esc's cought on fire! First one on stock settings and mid air.
And the second one after flashing it with BLHeli 14 and this time on the table not eaven flying it! ![]() Consider this when you buying this esc's! |
![]() The post above this one should make this evident. |
how do I implement the code to the Firmware? thanks Cheers Matt |
What is the benefit (if any) of flashing the ZTW 18A with the DYS 20A hex? Do you expect this to be much different than flashing them with the blueseries hex? Thanks |
Please tell us what is the reason for the failures, if you cover this with a mystery it will make people suspicious and prevent from buying. I guess.
Without understanding whats going on I'd rather buy different esc. Just not to risk. |
This is bl13
This is bl14
And this is on the bench after double checking settings. ![]() |
Thanks, |
