Mar 24, 2015, 12:29 PM
RCTimer/ DYS Mini SN20a / SN30a / SN40a esc
Thread for discussing the two mini esc's which could be a good kiss wannabe
Buying options
USA
UavObjects (simonk firmware with simonk bootloader)
http://www.uavobjects.com/product/rc...monk-firmware/
MultirotorSuperstore (includes boot loader)
http://www.multirotorsuperstore.com/...sc-blheli.html
http://www.multirotorsuperstore.com/...sc-simonk.html
MassiveRc (blheli bootloader, currently)
http://www.massiverc.com/PrestaShop/...5-20a-esc.html
MiniQuadBros
http://www.miniquadbros.com/collecti...ucts/dys-sn20a
ReadyToFlyQuads
BL20A mini esc SimonK-
BL20A mini esc BLHeli
FreebirdRc
http://www.freebirdrc.com/#!dys-sn20...-mini-esc/co2p
TwistedQuads
http://www.twistedquads.com/electron...are-oneshot125
Sec3 Research
http://sec3research.com/site/cart2/i...roducts_id=154
Canada
Armattan (blheli pre-flashed) http://www.armattanminis.ca/armattan-20a-opto-esc/
Europe
Mobius Cam http://www.mobius-cam.com/en/esc-sne...f-blheli-p-108
Australia
BuzzHobbies
http://buzzhobbies.com.au/index.php?...30&search=sn20
pre-flashed with blheli +damped light
BoltRc
http://boltrc.com/index.php?route=pr...ry&path=62_129
MultiRotorShop
https://www.multirotorshop.com.au
China
RcTimer : http://www.rctimer.com/product-1280.html
DYS : http://www.goodluckbuy.com/dys-sn20a...ticopters.html
MyRcMart http://www.myrcmart.com/rcx-20a-supe...6g-p-8786.html
Banggood : http://www.banggood.com/DYS-SN20A-Mi...098648201211GT
The RCTimer one comes with bootloader installed which makes it easy to upgrade firmware using usb linker or arduino.
Both BlHeli and Simonk support braking and oneShot making it a good kiss competition.
Originally Posted by QuadMcFly
Since there seem to be a number of questions on how to flash these and we've been repeating answers, here's a PDF of instructions on flashing to BLHeli for these ESCs.
Maybe should get added to the OP.
BLHeli
SimonK
dys_nfet.hex (Please note some people didn't have luck running simonk with comp_pwm)
Installing blheli video tutorial
How to Flash DYS SN20A with Arduino Nano (10 min 43 sec)
Videos
Racing @ wellington (3 min 31 sec)
RandomFlying (3 min 42 sec)
Chases (1 min 58 sec)
Mar 24, 2015, 01:07 PM
SystemsGuy's Avatar
CoolD - you cooked the cap off of one of your SN20's? Was that running SK or BH?
Latest blog entry: FrSky Long Range!
Mar 24, 2015, 01:15 PM
blheli 13.1 with damped light, it didn't cook, just came off I am assuming its bad soldering on the manufacturer's end.
Mar 24, 2015, 02:05 PM
Reposting from original post on the bearhug thread:
Did a second test on the rctimer sn20a escs. Man I'm loving these, 3 flights in a row pushing them harder than I ever did the bearhugs and couldnt burn a single one (I was literally trying to). Heres a video with the mobius this time. forgot to angle it up sorry!
DYS SN20A/RCtimer Mini esc Test 2, with mobius (2 min 51 sec)
Mar 24, 2015, 06:18 PM
1sq
1sq
1sq's Avatar
Originally Posted by CoolD
Thread for discussing the two mini esc's which could be a good kiss wannabe's
Buying options
Dont forget to include UAVOBJECT's link as retailer for these esc mini.
Mar 24, 2015, 08:45 PM
~Multirotor Fanatic~
Is there another retailer with these in stock besides UAVObjects that anyone knows of?
Mar 24, 2015, 10:08 PM
no, but you can always order from rctimer and select dhl shipping for $15 in case you don't want to wait.
we could check with uavobjects to find out when he will replenish the stock
Mar 24, 2015, 10:27 PM
I called UAV Objects today. They said they will have stock Friday or Monday...depending on when shipment arrives
Mar 24, 2015, 10:38 PM
great thanks for posting
Mar 24, 2015, 11:03 PM
Is it true these use the same fets as the kiss esc's? If so are we talking maybe just as fast as kiss esc'?
Mar 24, 2015, 11:23 PM
I don't think so, as per the blheli docs the high side FET's are slow to turn on for SN20a, the kiss description says ultra fast FET driver.
unless somebody can check the part numbers we are only guessing here
Mar 24, 2015, 11:32 PM
Maybe I read wrong but I read somewhere both fets are AON7520 in kiss and sn20 sn16. Lol I copy and pasted the fet number to do some research. I am still looking now.
Mar 24, 2015, 11:38 PM
Either way I am going to pick up a couple 16amp to see how the perform. I guessing the sn20 in blheli works on the 16's? They seem pretty close to each other, the 20's and 16's?
Mar 24, 2015, 11:41 PM
that's what the blheli doc says, same firmware
Mar 25, 2015, 01:57 AM
Team Crazy Eagles
Can anyone compare it with kiss in terms of performance?
