Mar 11, 2012, 11:03 AM
S.A.D. member
ivanc's Avatar
Naim,
From your picture I see two or even three possible issues:
1. The battery holder itself. It seems your is of low quality and might have contact issues.
2. Bad soldering job to the battery holder.
3. The red wire next to the connector - where I put the yellow arrow pointing at it.
Mar 11, 2012, 11:09 AM
S.A.D. member
ivanc's Avatar
Originally Posted by naim
Actually I'm talking about the battery pack wire. It is accidentally cut off when I'm trying to close the battery compartment with the cover (not the battery wrapper). Maybe as I fitted the battery pack and it cut off. And then I had to open the battery wrapper to make a new connection (soldering the wire back to the battery pack). Can I change the whole wire with another one? Does it will affect the Tx?
Yes you can change the wire but you will also need the connector. Once crimped, the terminals of the connector can not be reused (recrimped). You do not list your location in your profile so I can not give you advice on where to get the pigtail (connector with the wires already crimped).
I'd still recommend that you get rid of the battery holder and get a rechargeable pack, preferably made of Eneloops or other brand NiMH Low Self-Discharge cells.
Mar 11, 2012, 11:44 AM
Inciting Riots
village_idiot's Avatar
Those battery holders are about $5 to $10 for the real JR product, I would suggest getting a new one. It will come with the correct plug on the end to just plug into your radio. Alternate would be to buy a rechargeable pack for that radio, a little more expensive but again it should come with the proper connector attached.
Mar 11, 2012, 01:02 PM
Inciting Riots
After looking around it seems the AA holders for these older radios are pretty much gone. Next best bet would be to buy a generic holder from Mouser or Digikey and put the correct connector on the end.
Mar 11, 2012, 01:58 PM
Originally Posted by ivanc
Naim,
what do you mean by no. 3 issue? it is in correct position right?
Mar 11, 2012, 02:03 PM
Thanks for the advice. Yes, the connector is the problem if i change the wire. I dont know how to find it in Malaysia as the tx is very old one. Peoples now moved on 2.4ghz transmitter. I think that I should do that too but I'll keep this Quattro. =)
Again, thanks everyone. I'll try to fix it.
Mar 11, 2012, 02:05 PM
I got bad solder and it melt my battery pack. So bad.
Mar 11, 2012, 06:18 PM
S.A.D. member
ivanc's Avatar
On your picture the red wire seems damaged approximately 5 mm from the plug - where the yellow arrow points.
That connector is more popular than you may think - every old and current JR and Spektrum radio uses it.
Mar 11, 2012, 06:50 PM
60 years of RC flying
Daedalus66's Avatar
There are two kinds of JR connector: old black and newer white.
Just looking at the fuse isn't good enough. It needs to be replaced or at least tested with an ohmmeter.
Mar 11, 2012, 11:18 PM
I'll try to fix it. Thanks guys for the advice.
Sold Jr propo quattro with charger & jr rx r700 Robert Boudreau Aircraft - General - Radio Equipment (FS/W) 0 Oct 25, 2016 02:24 PM
Sold Price drop $50.00 Jr propo quattro with charger & jr rx r700 Robert Boudreau Aircraft - General - Radio Equipment (FS/W) 0 Dec 08, 2015 01:04 PM
Jr Quattro Tx Problem David A Ramsey Radios 0 Mar 06, 2004 12:20 PM
JR Quattro problem! Any similar? joedj Parkflyers 3 Jul 27, 2002 10:39 AM
