Mar 21, 2015, 02:55 PM
DX^ Switch from ACRO to Sailplane
I have a DX6 tx and a AR610 rx. I am setting up an EasyGlider Pro. Initially I set it up as an ACRO type, all the servos worked correctly. I then made another setup and used Sailplane type. The ailerons, rudder, and elevator throws got reversed. The throttle (Motor) is still working correctly. I have corrected the throws by reversing them in the tx setup. Is this normal or is something not correct.
Mar 21, 2015, 02:59 PM
AndyKunz's Avatar
When you change model type, everything gets erased and you have to program the whole plane again. That includes reversing, travels, etc. You are basically starting from scratch.
Andy
Mar 21, 2015, 05:09 PM
My Mistake. I did have to reverse the throws in both setups.
Mar 21, 2015, 06:24 PM
Andy, Thanks for the quick reply.
