This thread is privately moderated by nero1156, who may elect to delete unwanted replies.
Mar 15, 2015, 07:16 AM
Trader Rating: 479
$100.00 USD
Seller Pays Shipping
Sold
Spektrum AR9100 9 ch. RX DSM2 w/Flight log
Up for sale is a dual input voltage Spektrum AR9100 DSM2 RX with three remote RX's. Comes with original box, manual, soft start switch and RX. I used on a giant scale warbird for 5 flights. Getting out of giants.
KEY FEATURES
Robust power bus designed to manage high-current loads
Dual 16AWG battery input leads with EC3™ connectors for use with larger battery packs
Includes a soft switch that fails "on"
Includes three remote receivers
Features SmartSafe™ technology plus preset failsafe
Compatible with all Spektrum™ and JR® full-range radio systems
Can add an optional fourth remote receiver (sold separately)
Flight log compatibleOVERVIEW
The AR9100 PowerSafe™ receiver is designed for models using multiple servos that draw excess current or multiple high-torque servos, such as Giant-Scale airplanes and jet models. It features a robust power bus designed to manage high-current loads, as well as dual 16AWG battery input leads with EC3™ connectors for use with larger battery packs. This makes it possible to support high-current systems straight through the AR9100 receiver without the need for a separate power system. As an added measure of safety, the Spektrum™ brand designed the AR9100 receiver with a soft switch. Servo current is routed around the switch, so, should it fail for any reason, power to the system will not be interrupted.
This unique receiver design contains a main unit which houses the power bus, and it includes 3 remote receivers which come with one of each: 9”, 12” and 24” remote receiver extensions. The dual path redundancy of Spektrum patented DuaLink® technology, plus the fact each of the receivers is mounted in a slightly different location, exposes each to a different view of the RF environment and creates a bulletproof RF link in all conditions. You can add an optional fourth remote receiver (SPM9545—sold separately) to further enhance the receiving capabilities of the system for more complex aircraft.
In addition to Spektrum exclusive SmartSafe™ technology, the AR9100 receiver gives you the option of using standard user preset failsafe settings. It is also compatible with Spektrum optional flight log.
$100 with free shipping and a Spektrum flight log.
