This thread is privately moderated by K9000wner, who may elect to delete unwanted replies.
Mar 14, 2015, 05:00 AM
Thatsright I drankthe rum
K9000wner's Avatar
Cool
the rules of thumb .....repost from else where
Electric Flight Rules of Thumb
July 1, 2004 for QuietFlyer Magazine
http://www.stefanv.com/rcstuff/escbec.htm
( Stefan Vorkoetter ) I’ve been writing this column since late 1999, and over the years, have mentioned many rules of thumb. A reader recently asked if these were all written down in one place, so I thought this would be a good opportunity to do exactly that, revise some of the older ones, and see how they work together. None of these rules, used by themselves, will guarantee a good performing airplane, but taken together, they almost ensure it.
Power Systems
Probably the most used rule in the history of electric flight is one originated by well known electric flight guru Keith Shaw. The rule states that for reasonable sport performance, a plane’s power system should draw at least 40 to 50 Watts per pound (W/lb) of airplane. For good aerobatics capabilities, 70 Watts per pound is more suitable. These figures are in terms of motor input power (Watts = Volts x Amps), and assume a motor efficiency of about 75%, which was typical of a good cobalt motor when this rule was suggested. With a modern brushless motor operating at 85% or better, this can be changed to 35 to 45 W/lb for sport performance, and 60 W/lb for aerobatics.
Rules of Thumb:
Another early electric flight rule is that the power system (propeller, gearbox, motor, speed control, and battery) should account for about 50% of the total ready-to-fly weight of the aircraft. This rule, based on the technology of the 198os and early 1990s was intended to help ensure adequate power and duration. Modern nickel metal hydride (NiMH) cells have about twice the capacity for the same weight as the cells available then, and lithium polymer (LiPoly) cells are much lighter yet. Similarly, most brushless motors are lighter than a brushed motor of the same power output. This means that the same performance can be achieved with a power system that represents 25% to 40% of the ready-to-fly weight.
Batteries
A number of years back, former Demystifying Electrics columnist Matthew Orme proposed a simple rule for sport model battery packs: there should be approximately one nickel cadmium (NiCd) cell for each 50 square inches of wing area. This rule was intended for models powered by Sub-C sized cells, and if I remember correctly, either the 1900SCRC or RC2000 were the state-of-the-art at that time. Having chosen the battery pack, one could then apply the other rules to choose the motor, gearbox, and propeller.
A suggestion for full-throttle current draw was that models powered by Sub-C sized cells should draw about 25 Amps, and those powered by AE or AA cells should draw about 10 Amps. The 25 Amp limit was to ensure adequate flight duration, whereas the 10 Amp limit was to prevent cell damage. Modern 3300mAh NiMH Sub-C cells can provide the same durations at 40 Amps, although the smaller cells are still best kept at 10 Amps. LiPoly cells have specific current limits suggested by the manufacturer.
Propellers and Gearboxes
Choosing the right battery and motor will not guarantee a plane that performs well (or even flies at all). Having determined the required power level, an appropriate propeller and possibly a gearbox must be selected to turn that motor output power into something that can move the plane.
The first rule in this area concerns pitch speed, which is the speed that the propeller would move through the air if the air were a solid material. It is approximately the speed that the air leaves the back of the spinning propeller. The rule states that the pitch speed should be about 2.5 to 3 times the aircraft’s stalling speed (the speed below which it cannot fly – more on this later). Pitch speed in miles per hour is equal to rpm x pitch x 0.000947, where pitch is measured in inches. If the pitch speed is too low (i.e. much less than 2.5 times the stalling speed), then the propeller becomes inefficient at high speeds. If it is too high, the propeller is inefficient at low speeds.
The rule needs to be modified somewhat for non-sport models: electric sailplanes should have a pitch speed of 2 to 2.5 times the stall speed, and 3D models about 1.5 to 2 times the stall speed.
Another factor is static thrust. This is the amount of pull that the power system provides when the plane is stationary. In general, a model should have static thrust of 1/4 to 1/2 of the plane’s weight. Sailplanes that are to make rapid high-angle climbs benefit from higher thrusts, as do 3D models (which require thrust greater than weight in order to be able to hover).
Keep in mind that what really matters is the thrust provided when the plane is moving, but this is hard to measure. Thus, any rules regarding static thrust should be used in conjunction with the pitch speed rule appropriate for the model.
Often, with a given motor and battery, it is not possible to produce the desired combination of thrust and pitch speed, in which case adding a gearbox can help matters by allowing the use of a larger, more efficient, propeller. Of course, there is a rule of thumb that can be used to select the right propeller for a given gear ratio. First, choose the direct-drive propeller that gives an appropriate pitch speed. For example, for a particular high-revving motor, this might be an 83. Multiply the diameter by the square root of the gear ratio, and multiply the pitch by the gear ratio. For example, if using a 3:1 gearbox, the 83 propeller would become a 149. This will allow the motor (not the propeller) to turn at the same rpm, produce the same pitch speed, and far more static (and in-flight) thrust.
A final rule regarding propellers for sport models is that the diameter to pitch ratio should be somewhere between 2:1 and 1:1 (for example, 84, 85, 86, 87, and 88 fall into this range). Somewhere in the middle is usually best. Used in conjunction with the previous rule, it lets you choose an appropriate gear ratio.
Motor Timing
Like a gasoline engine which has to have the relation between the piston movement and the spark plug firing properly set, a brushed electric motor requires the brushes to be properly positioned relative to the magnets for optimal operation for the conditions (voltage, current, and load).
The simplest method, known as the 10% rule, was suggested by Bob Boucher of Astroflight. First, adjust the motor to neutral timing by running it with no propeller while measuring the current, and turning the end-bell until the current is minimized. Next, rotate the end-bell opposite to the direction of the motor’s rotation until the no-load current increases by 10% of the expected full-load current.
This is not a 100% perfect method, but then few rules of thumb are. It will however get you close enough for all but the most demanding purposes.
Aerodynamics
Earlier, we talked about pitch speed versus stall speed. How do you find out the stall speed? Using a rule of thumb of course. A plane’s stall speed in mph is approximately equal to 4 times the square root of the wing loading in ounces per square foot. This rule applies to both models and full scale aircraft. For example, my Sig LT-25 has 5 sq.ft. of wing, and weighs 105 oz, for a wing loading of 21 oz/sq.ft. This gives a stall speed of about 18 mph. A full scale Cessna 152 has 160 sq.ft. of wing, and weighs 1,670 lbs (26,720 oz) fully loaded, for a wing loading of 167 oz./sq.ft. This would put the stall speed at 52 mph (the actual stall speeds are 55 mph flaps up, and 49 mph flaps down).
Wing loading itself is not sufficient to indicate how a model will fly. The size of the aircraft has to be factored in (a model with the 167 oz./sq.ft. wing loading of the full scale Cessna 152 would fly like a brick). A measure that is indicative of flying qualities is cubic wing loading, which is computed by raising the wing area to the 1.5 power, and dividing by the weight (if your calculator can’t do powers but has a square root key, first cube the wing area by multiplication and then take the square root). Table 1 shows some typical cubic wing loadings for various classes of aircraft.
Type of Model Cubic Loading (oz./cu.ft.)
Sailplane or Park Flyer.......... 5 to 7
Trainer................... 7 to 13
Sport .................13 to 20
Pylon............. 20 to 30
My LT-25 has a cubic wing loading of 9.4 oz./cu.ft. which puts it in the trainer category. A full scale Cessna 152 has a cubic loading of about 13 oz./cu.ft., which puts it at the high end of the trainer category (not surprisingly, it’s one of the most popular full scale trainers).
Miscellaneous
There have been a few rules of thumb over the years that don’t fall into any particular category.
Electric model power systems can generate a lot of heat, and unlike in a glow powered model, the heat isn’t all generated up front out in the breeze. This necessitates cooling air inlets and exits. Because the air expands as it is heated, and to ensure that all the air coming in can get out, the total area of the exits should be about three times the area of the inlets. I don’t always follow this rule, but it’s a good idea to do so in high power models.
As a modeler in the northern half of North America, there are times of the year where I fly my models off of snow. As a result, I’ve done a lot of experimenting with skis, and have come up with a rule that states that there should be about 14 square inches of ski per pound of model weight (or slightly less than one square inch per ounce). This size minimizes the aerodynamic effects of the skis, yet holds the model up on most snow surfaces.
Finally, none of these rules will do any good if you crash the model because you can’t tell which way is up. From both my experience and that of other modelers, I can safely say that it can be easy to lose orientation of the model, and then crash it because you’ve got up and down mixed up. The best cure for this is a color scheme that is light on top and dark on the bottom. This is in agreement with our experiences that it’s generally darker underneath objects. All-white or transparent schemes can be very aesthetically pleasing,
but hard to fly.
Wrapping Up
These are most of the rules of thumb that I have made use of during my electric flight career. Keep in mind that they are not hard and fast rules. Some can be ignored in some cases. Others are almost essential to follow, but following them doesn’t guarantee success. However, used together, they can go a long way toward achieving electric flight bliss.
K9000 >>> please feel free to add comment and your own Rules for discussion
Mar 14, 2015, 05:18 AM
K9000wner's Avatar
I will add one rule I use
or when a plane proves to be dicy landing
when in doubt of the landing chacteristics / behavior of a new plane or just current flying issue
I will fly it into / onto the ground wheels up if prudent rather than stall crash or bounce crash
or side-wind crash the result is usually much less damage
http://www.stefanv.com/rcstuff/qf200203.html
just good info on Propeller Basics
actual rules ....no thumb
Mar 16, 2015, 03:05 PM
Another factor is static thrust. This is the amount of pull that the power system provides when the plane is stationary. In general, a model should have static thrust of 1/4 to 1/2 of the plane’s weight. .
This must be rules of thumb for yesterdays (brushed motors and NiCd/Nihm or glow, club size) rc planes or bigger.
Today's small RTF planes may need more than 1/2 their weight to barely fly.
Why? Small planes got a high drag ratio.
My Kyosho A-6 Intruder had around 270g thrust stock, weight 492g it did fly ...
but loop ... forget it! Many claimed it would not fly!
https://www.rcgroups.com/forums/show....php?t=1622702
Mar 19, 2015, 04:32 AM
K9000wner's Avatar
cant really compare Props to EDFs
to say it will fly does not mean it will loop
yes old data but easily converted and still accurate,
a 200watt plane old or new still needs to be light
just easier now.
