Mar 14, 2015, 12:26 AM
That's a wicked, high power motor you have chosen. It's also very versatile with the ability to take a large range of props >< voltage. I'll be watching and wishing for success on your very cool project.
David
Mar 14, 2015, 09:00 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
David
Thanks David, seems you know the motor well ... what prop / battery combo would you recommend for this one ?
Lockey
Mar 17, 2015, 09:31 AM
Gravity is my enemy
Balloon Bandit's Avatar
G'day Lockey, While in the Trekkie train of thought, would you consider the Klingon Bird of Prey? or has it been done already.. this forum is huge! Cheers
Mar 17, 2015, 10:39 AM
Retired CAD guy
birdofplay's Avatar
OK Lockey,
Dang it all ... Ya got me on this one.
I used to watch Voyager all the time.
AND I like the Necellerons idea. To coin a phrase
Send plans when you are ready and confident. Thanks :-)
Bob
Mar 17, 2015, 01:43 PM
Gravity is my enemy
No no, I didn't say bird of play, I said bird of prey! LOL, Hi Bob. Nice timing.
Mar 17, 2015, 01:59 PM
Retired CAD guy
birdofplay's Avatar
QaQ jaj puv
I note that Bing now also does Klingon Translations
but reverse is not so good :-(
It is a good day to Fly !
Mar 17, 2015, 09:12 PM
Lockey's Avatar
Hey Bob, don't want to push this one until its been built and flight tested
I don't have as much faith in this one as I do in most of the other models I design, probably why I am dragging my feet a bit
I have had a bit of a rest from ones that either don't fly (or don't fly well) and been playing with my EZ-Jets and these do seem to fly very well ... havent seen you there https://www.rcgroups.com/forums/show...0#post31087930 ... especially the Skyray
By the way, can you cut foam board ... or I guess they can be made from MPF as its about the same thickness
Drop me an email if you would like to do these ones
Lockey
Mar 18, 2015, 07:39 AM
Retired CAD guy
birdofplay's Avatar
Yes I can cut foam board.
I got some just to see what it was "all about".
The EZ jet is very enticing.
I like that you can take off from ground.
I may have to buy one of those fancy new factory balanced metal DF units.
My plastic DF experiences have never been remarkable to say the least.
Bob
Mar 18, 2015, 01:07 PM
SG Talon... Super Genius.
Hey BB,
The Bird of Prey is what got me hooked on building Spacecraft.
Here is the thread that did it too. Took 3 or 4 iterations before we got one that worked but it is a great looking ship!
https://www.rcgroups.com/forums/showthread.php?t=843143
I have designed about 30 RC Spacecraft check out my blog (click on my name) for the links.
Mar 18, 2015, 02:44 PM
Gravity is my enemy
Thanks Sarge, I'll go check it out!
Mar 19, 2015, 07:56 AM
It is SG - Talon. I have never been in the military.
Mar 19, 2015, 09:39 AM
Gravity is my enemy
If I had looked at your tag line under your name, I would have caught that. Sorry SG, no offense intended. I was active Army, so the SGT just jumped out at me. However, I guess I've sidetracked this thread enough.. So back on topic: Great bird Lockey, still going tractor on this one?
Mar 19, 2015, 11:05 AM
Isaiah 40:31
rc capo's Avatar
Even though I am a sci-fi fan, these types of model's never appealed to me, until I thought...if you lit one up with LED's, that world look cool cruising over the neighborhood at night. Just mask the electric whine of the motors with a loop of warp engine sfx..that could be fun!
Nov 10, 2015, 06:37 AM
Careful,.. confident,.. CRASH!
Dukejet's Avatar
Well guys just finished reading the thread! Can some tell me why the edf isn't in the bottom?
Inline with the nacelles-erons lol... thanks Bob!
I love that one. Half way through the thread I'm thinking 'let the whole thing pivot! '
but control wise, with the cf rod in a sleve hinge idea, is the best chance I think.
I'm not confident the body will produce lift because in profile shot it looks like the Aero foil is backwards?
So where's the cg? Or is that the Golden question.
Nov 10, 2015, 07:33 AM
It's not so much that as it is the very high thickness-to-chord ratio of the center of the disk. That and the very bulbous rear-belly (don't know what else to call it) are going to mean huge drag.
I think that's why SGTalon's profile version (see below) was a good flier - because he eliminated this issue by making it profile only. He also gained tons of useful lifting surface in the rear by doing so and thus ALSO made balancing much easier.
If you make it profile only it will be relatively straightforward (though tedious) to calculate CG, as it will be obvious which parts are lifting surfaces. Leaving it "true-to-scale" will make it much harder to determine.
Having said all of the above, it can definitely be done as "true-to-scale", but you will need a LOT of thrust, stall speed will be higher, and getting CG right will be challenging.
SGTalon's version:
RC Star Trek Voyager (4 min 43 sec)
Discussion Star Trek New Voyages, 4x03, World Enough and Time dll932 Life, The Universe, and Politics 16 Dec 08, 2016 03:15 PM
Sold Star trek original and voyager Nutball Non R/C Items (FS/W) 1 Feb 27, 2016 11:05 AM
Cool Star Trek Voyager - New Video! Plans and Kits available!! SGTalon Foamies (Scratchbuilt) 146 Feb 13, 2015 01:28 PM
Video Foamie Star Trek Voyager SGTalon Electric Plane Talk 16 Sep 03, 2010 08:24 AM
Star Trek Voyager...? Umi_Ryuzuki Submarines 8 Jul 30, 2005 09:03 PM
