Mar 11, 2015, 11:39 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Originally Posted by David2011
Lockey,
Would it work with a centrally mounted aperture prop like the parkjets? It would be noisier but would help with the balance. Maybe a little bigger prop and lower KV?
David
Thanks for the thought David, but this would move the motor (and the weight) back more and make balancing even harder
I need more weight at the front and less weight at the back
thanks again mate for your input
Lockey
Mar 12, 2015, 04:17 AM
Lockey's Avatar
More work on the Voyager today, think I have the elevons worked out for maximum results, had to modify the rear fuselage a little
Lockey
Mar 12, 2015, 05:03 AM
Looks good.
Word of caution: Whatever shaft those mojos are going to be rotating on will have to be VERY strong and VERY rigid.
Mar 12, 2015, 05:13 AM
Lockey's Avatar
Not an easy trick Nuteman without adding a LOT of weight that I can barley afford
I was thinking red parts fixed and braced with CF tube as you suggested and hinged elevons rather than FULL flying elevons
Lockey
Mar 12, 2015, 05:30 AM
It is definitely the safer/easier way to proceed (and as you pointed out - less costly in weight).
Also, I strongly urge flattening those nacelles (yes, despite the cost in "looks"). You will have a LOT of rotating mass already - Sir Newton says that will have certain consequences
Mar 12, 2015, 06:17 AM
Lockey's Avatar
OK, I will go with profile type nacelles ... initially
Lockey
Mar 12, 2015, 06:38 AM
Damn, I envy you man!
The most I've had time for in the last few weeks is to put landing gear on my 65 inch span canard.
Oh well, maybe I'll have more time when I retire
Mar 12, 2015, 07:37 AM
We shall serve the Lord
kingsflyer's Avatar
Very Nice! I like the idea of the moving nacelles and using them as your elevon aerodynamic counterbalances.
McD
Latest blog entry: LEDs on my T-28
Mar 12, 2015, 08:28 AM
Lockey's Avatar
Thats a BIG nuteman, although i don't know what I would do without a hobby
Thanks Mike, all we have to do now is see if it works eh
I am thinking ... 6 mm Depron for all the flat parts and foam board (without the paper) or MPF for the bendy bits
This is the motor I am thinking of using, it should have plenty of humph and its quite a heavy motor to help with the CG and it will run on either 3's or 4's battery
https://www.hobbyking.com/hobbyking/s...dProduct=21480
Lockey
Mar 12, 2015, 11:42 AM
DFS#000178
Rampage's Avatar
It'd be neat to get a bunch of these together.
NCC 74600 Intrepid
NCC 74656 Voyager
NCC 74705 Bellerophon
Are the three known ships of the line. It'd be kinda' cool to have all 3 of them in the same place at the same time.
Mar 13, 2015, 11:55 AM
Quad Erat Demonstrandum
scousethief's Avatar
2 carbon rods one inside the other acting as hinges for the control surfaces should be enough i ran a twin edf mig with the same for nearly 2 years without issue , only reason its not still flying is Spektrum receivers and some knob with a dodgy router somewhere at the back of the flying field
Mar 13, 2015, 06:07 PM
SebastianG.'s Avatar
Hi Lockey,
not quite sure if it would effect the stability of the ship, but would it help to put some dihedral in your nacelles and use it as v tail?
Mar 13, 2015, 07:22 PM
Lockey's Avatar
Thanks for the CF rod idea scouse, although I think it would be rather difficult to get one CF rod inside another CF rod ... think you might mean CF rod inside a CF tube ... sorry scouse, had to do it ... one pome to another or should I say ... one Yorkshire lad to another OR are you a Scouse pretending to be a Yorkshire lad ?
I am not sure about having dihedral on the nacelles SG, maybe nuteman might want to comment ?
By the way, I have the plans / patterns almost finished ... anyone like to have a crack at building and testing it with me ?
Lockey
PS. SGTalon, I have sent you a PM
Mar 13, 2015, 10:24 PM
SG Talon... Super Genius.
The dihedral on the nacelles has no effect that I am able to tell. I think it looks cool though.
Mar 13, 2015, 10:47 PM
Lockey's Avatar
Thanks SG, I think I might just go with the straight ones first and see how we go
I am also back playing with the EDF version and will go with the EDF IF the prop version flies good
Is this duct now too far down or will it work ?? ... it would be better if it can be here as it will help with the positioning of the duct and make the thrust vectoring work better as it will be in the centre of the elevons
Lockey
Discussion Star Trek New Voyages, 4x03, World Enough and Time dll932 Life, The Universe, and Politics 16 Dec 08, 2016 03:15 PM
Sold Star trek original and voyager Nutball Non R/C Items (FS/W) 1 Feb 27, 2016 11:05 AM
Cool Star Trek Voyager - New Video! Plans and Kits available!! SGTalon Foamies (Scratchbuilt) 146 Feb 13, 2015 01:28 PM
Video Foamie Star Trek Voyager SGTalon Electric Plane Talk 16 Sep 03, 2010 08:24 AM
Star Trek Voyager...? Umi_Ryuzuki Submarines 8 Jul 30, 2005 09:03 PM
