May 31, 2004, 05:09 PM
Question
**Metrics Size? building GWS EDF-55 A-10
Reading over the building instructions for the A-10....( Required ) a 1mm and 3mm drill bits. I did a search over the internet and can't find one site that sells Metrics Drill Bits that size. Can anyone suggest some other option?
Bob
May 31, 2004, 05:43 PM
dbl8ts's Avatar
Bob
Try www.hobby-lobby.com and search for KT569 ($9.90). I find the drill bit sizes (12 included) ideal for your needs.
May 31, 2004, 05:49 PM
DBL question
12 bits sizes 52-74 .....what does sizes 52-74 mean? I'm looking for 1mm and 3mm. will this work 52-74?
Bob
May 31, 2004, 06:18 PM
dbl8ts's Avatar
Bob
I am not sure. I know my larger titanium drill bit set has numbered bits, but I don't know what their applications are. I do know that I purchased the set I recommended to build my A-10 and Mini-Telemaster, and the bits cut the smaller holes needed. Remember, this is a foam model, so use light pressure. Or, try a little heat on the wires then insert them for a snug fit. By doing this, the melted foam hardens to an exact fit around the wire and creates a surface to give expoxy a stronger holding point.
