Feb 28, 2015, 02:43 PM
Question
dumas creole queen 2029 motor specs
can anyone tell me how many turns this dumas creole queen 2029 motor has.
Feb 28, 2015, 06:32 PM
Big Boats Rule!
boater_dave's Avatar
High count Pittman with a gearhead giving about 180 rpm, as I recall.
Dave
Feb 28, 2015, 07:31 PM
thanks but im trying to find out how many turns it is to see if i can use my 15 turn pro boat esc.
Feb 28, 2015, 07:55 PM
Central Florida
r/cjunkie's Avatar
I'm using a standard blue proboat esc on mine. No issues to this date Been using over a year
Craig
Feb 28, 2015, 09:40 PM
thanks that is what i wanted to know
Mar 01, 2015, 01:55 AM
Big Boats Rule!
That motor should draw very low amps and any esc should work, as long as it can handle your battery voltage. I never could understand why esc manufacturers used the ridiculous 'turns' reference in place of actual capability.
Dave
Mar 01, 2015, 01:37 PM
thats true i dont even know what the number of turns means
Mar 02, 2015, 06:15 AM
There is just so much room inside a motor of a given size for wire to be wrapped round the armature poles. The thicker the wire, the fewer turns can be fitted. With thick wire and few turns, you draw a lot more current, and, motor power being related to Amp draw times number of turns, you get more power out at a given voltage. So the lower the turns number, the higher the amp draw, and the more likely that the motor will spin faster.
