Dollar Tree Foam ... EZ-Jets - Page 3 - RC Groups
Feb 27, 2015, 10:07 AM
Robert4613's Avatar
Originally Posted by Lockey
Isopropol is very expensive in Australia, over $8.00 for only 125 ml
Methylated Spirits on the other hand is very cheap at $3.30 for 1lt and it does exactly the same job ... spray it on the paper, leave a few seconds and peel off the paper....
WOW! It's crazy how prices on certain things are across the globe.
Feb 27, 2015, 06:04 PM
Great builds and subscribing!
Currently building and flying the prop/slot F-22's like the other poster.
These look just as easy to build and swap from edf to prop and back.
The downward wing droop kinda reminds me of Firefox.
Feb 28, 2015, 02:09 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Maidened the Pusher today, was a little twitchy, but so was the EDF, maybe I have too much throw on the elevons
Flew a little livlier than the edf, more power than it needs wit a Hobby King D2826-6 2200kv Outrunner Motor and 7 x 4 prop
Got disorientated and put it in on its nose, its repairable and I think I might make the nose a little longer to make it a little easier to balance with maybe a smaller battery
Lockey
EZ SR72 Maiden with Pusher (4 min 35 sec)
Feb 28, 2015, 04:34 AM
Not always grumpy!!
insomaniac45's Avatar
well well well. it is nice to see its not just me that crashes...
had a magnetic tree pull my bird in from the sky yesterday.
as you can see she has t nasty impacts on the wing, but the fuse is destroyed.
time to review my build que, and most of them are from you.. lol.
Feb 28, 2015, 04:42 AM
Lockey's Avatar
Happens to us all mate, I am not as young as I used to be and my reflexes aren't as quick as they were
Thems the breaks eh
Lockey
Feb 28, 2015, 06:47 AM
Lockey's Avatar
Spent a little time this evening on the repair, lengthened the nos by about 55mm
Will change the plans (again) and make the nose longer
I fear I am going to have problems with balance on the Stealth though
Lockey
Feb 28, 2015, 07:59 AM
Lockey's Avatar
Anyone like to have a go at the C of G with the lengthened nose ?
The 2 little circles are where it was with the shorter nose and it was pretty close ... , have made it 70 mm longer
Lockey
Feb 28, 2015, 03:35 PM
ringo42's Avatar
I just got the plans all taped together. Should I modify them for the extra length?
Feb 28, 2015, 06:27 PM
Lockey's Avatar
As an EDF it will balance OK, in fact its just the opposite really, battery needs to go further back but as a pusher the battery needs to go further forward
SO ... I would reomend ..
If you are going to make it as a EDF .. leave it alone
If you are going to make it as a pusher .. make it longer
If you are undecided .. make it longer
I will post the modified plans when they are ready
Lockey
Feb 28, 2015, 06:35 PM
ringo42's Avatar
Thanks. Got the edf today. Will start cutting foam.
Feb 28, 2015, 08:20 PM
Lockey's Avatar
I have just done some tests ringo42 and the results have astounded me
By adding 70 mm to the nose (lengthening the nose by just 70 mm) it has taken the C of G 105 mm further forward making it even worse to balance
I just can't understand it and not sure what to advise ... or what to do ??
I used the same canard CG calculator on all 3 examples ... the first one being the original one and that seems to be the best place for the C of G after flying both EDF and Pusher
Please can someone explain
Lockey
Lockey
Feb 28, 2015, 10:17 PM
Lawn Dart Flyer's Avatar
Just got back into town today and seen your new info. Only thing i can think of with the pusher is the thrust angle. It looks like you are parallel with the fuse, maybe put original nose back on and add some up angle shim to the motor mount, this should make the nose go down. Reserved for personal build after i'm done with a few of my buddies builds
Feb 28, 2015, 10:28 PM
Here is the FlitTest link to your plane, super great community there and i encourage you to join, especially if you plan more DTFB builds http://forum.flitetest.com/showthread.php?16570-SR-72
Feb 28, 2015, 10:31 PM
skumgummi dave
Lockey
Lockey
Tony:
Which CG calculator are you using? Is this shape considered a canard? I am confused, as you said you used a canard CG calulator...
Dave-
Mar 01, 2015, 03:26 AM
Lockey's Avatar
Originally Posted by foamdave
Tony:
Dave-
Yes I did Dave, it was recommended that I use it (I think) and it worked OK so I thought I would use it again .. http://adamone.rchomepage.com/cg_canard.htm
I haven't found anything else that works right, I have the Flying Wing one but I can't seem to make it work properly with this shape wing http://wingcgcalc.bruder.com.br/en_US/?
Can you recommend anything else that would be better ?
Lockey
