Oct 15, 2015, 05:20 PM
Isaiah 40:31
Clickety's Avatar
A-10 retracts (0 min 13 sec)
Retracts in action!
Oct 16, 2015, 05:02 AM
Crash-safe
lessram's Avatar
Looks great.
The retracts have a nice sound.
One question though: Can you steer with the front wheel or do you configure the motors accordingly ?
well done
Cheers
Olli
Oct 16, 2015, 06:21 AM
MartinT's Avatar
Awesome, especially with the retracts and all!!!
Oct 16, 2015, 09:04 AM
Isaiah 40:31
Clickety's Avatar
Thanks guys, the front retract is non steerable, not planning on taxiing. Just short take offs and landings
Oct 18, 2015, 05:02 PM
Isaiah 40:31
Clickety's Avatar
3mm depron pieces added to wheel shrouds, and ailerons rounded and spackling/lightweight filler applied.
Oct 21, 2015, 04:31 PM
Isaiah 40:31
Clickety's Avatar
A-10 park jet build (0 min 32 sec)
Oct 22, 2015, 01:08 PM
Isaiah 40:31
Clickety's Avatar
This is the colour scheme I want to paint the Hog in.. It is called European Camouflage one. Was used in the 1980's, and its how I remember it when I first saw it.
I also think I'll finish sanding it to shape, and glue the vertical stabs on. I then want to try a flight test without the engine nacelles, as I need to understand if I need to add a correcting thrust angle to the props. It will be much easier to adjust with them off.
Oct 22, 2015, 04:41 PM
speedy01's Avatar
Nice. Attached is what I think is an attractive Euro scheme (I'm biased). I can send camo patterns as well as decal scans for those markings. England AFB, 1979, 76 TFS.
PM me if you'd like.
Gene K
Oct 23, 2015, 04:42 PM
Isaiah 40:31
Clickety's Avatar
Epoxied vertical stabs on, epoxied magnet into canopy, made lite ply retaining tab. Tested 3s battery performance and it has around 80-90% static thrust. Tested 4s battery and it has around 120-130% static thrust.
The vertical stabs are pretty comfortable in the airflow from the props.
It feels like the props will need a thrust angle to push the nose down, but the elevators have a big impact on pitch as they are in the airflow so I might risk a test flight.
Oct 24, 2015, 04:21 AM
That's looking sharp! I'm looking forward to the flight report, I bet this is going to look great in the air. What did you use as a thrust angle? 0 degrees? With the authority of those large elevators you will probably be able to correct it, so I also would go for it .
Oct 24, 2015, 04:52 AM
Isaiah 40:31
Clickety's Avatar
Thanks Robert, yeah zero degrees. I'm beginning to wonder if I should put on 3 degrees just to be safe.. Might make it easier to handle for the maiden
Oct 24, 2015, 08:05 AM
Isaiah 40:31
Clickety's Avatar
My buddy / launcher John, is away at the moment and it's a family get together weekend, so I'm postponing launch until next weekend. Meanwhile I'll do a bit more research into thrust angles and double check the a-10's CG position to minimise risk on maiden flight.
Oct 31, 2015, 05:42 AM
Isaiah 40:31
Clickety's Avatar
OK, did a few tests to get a better idea of the thrust and weights of this bird are.
Without battery, it currently weighs 680g. With battery 850g.
3S testing at full power:
Total thrust = 850g
Thrust / weight ratio = 1:1 thrust.
Drawing 210 watts at 20A
Thats around 6 minutes on a 2200 3s battery.
4S testing at full power:
Total thrust = 1420g
Thrust / weight ratio = 1:2.5 thrust.
Drawing 430 watts at 30A
Thats around 3 minutes on a 1800mah 4s battery
Certainly don't have a problem of being underpowered!
These Cobra motors and 5" HQ props are quite amazing!!
