May 27, 2004, 02:59 PM
and another aveox ? anyone know how to open their can?
aveox 27/13/3 out of warrant... want to extend/replace the leads..... how do i get it open?
May 27, 2004, 06:09 PM
Andy W's Avatar
The "leads" that come out of the can are the windings themselves. There's nothing you can do inside the can to extend them, you need to disconnect the existing wire from the windings outside of the can (there should be 1/2-1" of exposed wire there) and attach new wires.
That said, the can should have three little tiny set screws, and the matching hex wrench is in the box the motor came in.
..a
May 27, 2004, 07:44 PM
sneu's Avatar
..a
The 27XX motors have the rear ends pressed on with Locktite--use a heat gun to get the outer case pretty warm then tap the motor a table top(not a good table) which will push out the rear endbell. Be careful doing this as it is easy to damage the rear bearing. as Any said the wires out the back are the motor leads--so there is little to play with inside the motor.
Steve
May 27, 2004, 08:58 PM
Andy W's Avatar
Ah, sorry - most of my motors are 10xx or 14xx of Fxx.. didn't realize they lost the set screws with the metric conversion..
..a
