Feb 23, 2015, 08:01 AM
Warbirds Lover
Dreamcatcher's Avatar
My Corsair was built with balsa and plywood and the AUW was 850g.
I think your foamy will be lighter so no problem using (hard) balsa + foam imho
Keep on the good job Mate !
Feb 23, 2015, 08:14 AM
What supports the landing gear?
Feb 23, 2015, 09:23 AM
Scale RC Plane Lover
julescrafter's Avatar
I hope so, thanks mate
Jules
just layer of foam connected to ribs and spar.
Feb 23, 2015, 11:39 AM
Warbirds Lover
on this point, jules, i think you are a bit optimistic...
I think you should use some hard wood / plywood to build the the landing gear supports and the ribs that supports the landing gear.
if you have no serious reinforcement in these area, you will have to perform very smooth kiss landings not to rip the gear out of the wing.
Just my two cents...
Cheers !
Pascal
Feb 23, 2015, 11:55 AM
Cheers !
Pascal
yeah, actually I'm worried more about ripping out the landing gear when landing then breaking the wing . I will go building the fuselage then will get back to the wing.
Feb 23, 2015, 11:04 PM
slebetman's Avatar
I've used solid foam to reinforce landing gears before. Just build it up in layers and then sand. Be sure to glue the foam to the top skin as well.
Regardless of weather you're using foam or wood or hard plastic as reinforcement the key is to spread the load wide enough to not rip the foam skins (that's really where most of your structural strength comes from. One trick I've seen done with jets is to fiberglass the insides of the wing around your hardpoints.
Feb 24, 2015, 03:56 AM
thanks for the tips, mate I'll do that
Jules
Feb 24, 2015, 06:11 AM
Warbirds Lover
interesting information,
Thanks a lot Slebetman
Pascal
Feb 25, 2015, 04:36 AM
Fuselage and stabilizer plans are printed (19 pages A4) , ready to transfer to foam.
Feb 25, 2015, 06:49 AM
Warbirds Lover
That sounds good !!
Mar 01, 2015, 09:13 AM
slow but sure on fuselage build
Jules - diyfoamplane.com
Mar 04, 2015, 03:50 AM
Fuselage building progress : cockpit and rear fuselage
Mar 04, 2015, 05:11 AM
Warbirds Lover
Pretty good job Julescrafter !
Becareful : The F4U Corsair fuselage suffers a weakness point just behind the canopy.
So i might recommend you to strengthen the area where your rear fuselage's skin joins the rear of your canopy (if it's not already done), it can avoid the fuselage to break in two pieces here in case of hard landing.
http://upload.wikimedia.org/wikipedi...0)_in_1945.jpg
I look forward the next steps with interest !
Mar 04, 2015, 05:38 AM
Thanks Pascal
Okay I'll redesign the construction on that particular spot. UPDATE : another progress today
thanks again,
Jules
Mar 07, 2015, 06:16 AM
Progress today
