Feb 14, 2015, 03:32 PM
Hovership
3rdeyepro's Avatar
New Product
Hovership ZUUL
Introducing the all carbon fiber folding mini quad ZUUL from Hovership.
Available at:
http://shop.hovership.com/
http://www.multirotorsuperstore.com/
The ZUUL frame system has interchangeable parts allowing a variety of build sizes and configurations.
  • Clean section option
  • GoPro cage option
  • CCD bracket option
  • Arms for 5" or 6" props
  • Firewall option
  • GoPro tilt wedge
Printable parts STL files: http://www.thingiverse.com/thing:740916
Feb 14, 2015, 03:33 PM
Hovership
3rdeyepro's Avatar
Zuul Superbeast Edition
The Zuul Superbeast Edition is a mini quad designed to cradle and protect a GoPro camera while capturing vibration-free video. The versatile frame system enables multiple build layouts and quick repairs.
Clean Section
The “clean” section’s vibration dampeners are protected during a crash with a hyperextension stopper. Cutouts on the underside of baseplate allow for easy access to replace bobbins in the field.
GoPro Cage
A spacious cage allows for the use of a wedge to tilt the camera up during fast forward flight. The entire camera cage is removable and upgradable.
Foldable
All of the arms on the Zuul can be folded in for compact transport. The folding arms also collapse during a crash to prevent damage to the frame. Don’t want the arms to fold? No problem, there is a fixed position hole for that!
Additional Features
  • Firewall plate to keep the battery from impacting the flight controller. Firewall is not compatible with larger flight controllers with 45x45mm mounting.
  • SMA extension mounting holes in top plate
  • Small cutout in arms for mounting LEDs under the arms and running the wires up to the topsides of arms
  • Battery strap cutouts on belly, rear of clean section and top plate
  • Mounting holes and cutout on base for PDBs with 30.5x30.5mm hole spacing
Recommended Setup
  • 2204-2208 size motors with M3 16x19mm mounting pattern
  • 12-18A ESCs
  • 5-6” props
  • 3-4S power, 1300-2200mAh capacity batteries
  • Mini CCD camera with tilt bracket
  • Hovership Mini Quad Landing gear to mount larger batteries on belly
Includes
  • Carbon fiber frame
  • 3D printed ABS plastic 15 GoPro tilt wedge
  • Hardware kit
  • M3x6mm motor screws
  • Stickers!
Specifications
  • Weight: 198g (including motor screws)
  • Wheelbase: 285mm (diagonal motor to motor)
  • Material: 3K weave carbon fiber. 3mm thick arms and upper cage, 1.5mm for all other parts.
  • Clean Section Clearance for ESCs: 10mm
Hovership
3rdeyepro's Avatar
Zuul Racehound Edition
The Zuul Racehound Edition is a stripped down version of the Superbeast mini quad frame. Using the same base and top plates, we removed the clean section and GoPro cage. The versatile frame system enables multiple build layouts and quick repairs.
NOW AVAILABLE in 265 and 285 sizes.
Spaced Out
The base plates are spaced apart 10mm for mounting the ESCs inside the body. The wider body of the Zuul frame allows for more room to mount components.
Foldable
Additional Features
  • CCD camera mounting plate
  • Battery strap cutouts on belly, rear of base section and top plate
Recommended Setup
  • 2204 size motors with M3 16x19mm mounting pattern
  • 12A ESCs
  • 5” props for 265 edition, 5-6" props for 285 edition
  • 3-4S power, 1300-1800mAh capacity batteries
  • CCD board camera
  • Mobius or similar camera
Includes
  • 3D printed ABS plastic base spacers
  • Hardware kit
  • Stickers!
Specifications
  • Weight: 155g (including motor screws)
  • Wheelbase: 265mm (diagonal motor to motor) or 285mm sizes available.
  • Material: 3K weave carbon fiber. 3mm thick arms, 1.5mm for all other parts.
  • Clearance for ESCs: 10mm
Feb 14, 2015, 03:34 PM
Hovership
3rdeyepro's Avatar
Videos
(1 min 11 sec)
(3 min 37 sec)
(1 min 42 sec)
FPV - Hovership ZUUL After School Special (4 min 0 sec)
Feb 14, 2015, 03:39 PM
Quad On!!
nate25j's Avatar
Man I like it a lot! Nice design.
Feb 14, 2015, 03:46 PM
"Furadi"
Conradm's Avatar
Thanks for making the thread! Can't wait to post my build.
Feb 16, 2015, 11:48 AM
"Furadi"
Conradm's Avatar
So how many people ordered this frame? What builds are people planning?
I'll be running Cobra 2208's with RG 30 amps.
Feb 18, 2015, 12:32 AM
"Furadi"
Conradm's Avatar
Doing a dry run on my FPV gear to see how the OSD remote wires in. Had to cut the rca type plugs off.
Feb 18, 2015, 08:32 PM
"Furadi"
Conradm's Avatar
Got my frame today. Very nice frame.
Feb 19, 2015, 03:17 PM
wamdue's Avatar
...just finished my baby BO330.... the Zuul was the just the frame I wanted.
Feb 19, 2015, 03:23 PM
"Furadi"
Conradm's Avatar
Wouldn't the baby BO330 be the... blackout?
At any rate, nice ZUUL. Specs? Why 5" props?
Feb 19, 2015, 03:32 PM
wamdue's Avatar
the SuperBeast is quite clearly an 'homage' to the Blackout330 but in the format of a Mini.
5x4 bullnose is my preference for extreme proximity vs. 6".
Cobra 2204/1960kv will run both.
Kiss18a, OneShot, CleanFlight, Naze, MinimOSD/KVRteam / etc..
Feb 19, 2015, 03:52 PM
"Furadi"
Conradm's Avatar
Interesting perspective. So is any frame that's designed to hold a gopro an "homage" to the BO 330?
Feb 19, 2015, 04:14 PM
wamdue's Avatar
Trying to understand your level of sarcasm here.....
Feb 19, 2015, 04:16 PM
"Furadi"
Conradm's Avatar
looks like Hovership posted some build guides for the Superbeast and Racehound.
http://www.hovership.com/guides/
Sold Hovership Zuul Superbeast Package Frostman83 Aircraft - Electric - Multirotor (FS/W) 0 Nov 19, 2016 01:32 AM
Sold Hovership Zuul Superbeast Package w/ Extra Frame Frostman83 Aircraft - Electric - Multirotor (FS/W) 0 Nov 10, 2016 12:02 AM
For Sale Hovership ZUUL Superbeast dairokkan Aircraft - Electric - Multirotor (FS/W) 0 Oct 13, 2016 01:23 AM
For Sale Hovership Zuul Superbeast BNF bmacw Aircraft - Electric - Multirotor (FS/W) 5 Oct 11, 2016 10:33 AM
For Sale Price Drop - Hovership Zuul Backpack Gimbal Drone TDIPWR Aircraft - Electric - Multirotor (FS/W) 2 Oct 01, 2016 09:15 PM
