Feb 13, 2015, 09:31 AM
AJ_Aircraft's Avatar
AJ Aircraft 73" AJ Laser 230z
Official thread for the 73" AJ Laser 230z.
Purchase here.
Build manual here.
The 411:
Wing Span - 73"
Length - 70"
AUW - 10-11 lb
Power(Elec) - 2500+ Watt motor, 120amp or 100amp ESC, 8s 4400mah lipo
Power(Gas) - 30-40cc
Radio - 5 channel with 4 high torque servos
What's in the box:
Carbon reinforced landing gear mount
Pre-hinged and sealed control surfaces
Carbon main gear
G-10 control horns
Dual ball links for all connections
Carbon wing tube
Optional SFGs included
Genuine Ultracote covering in 2 color scheme choices including the AJ Competition Scheme
Wing bags
Fuel tank
Muffler can mounts
AJ flies this airframe with the following equipment:
Hacker A60-5s
Falcon 21x10 prop
Jetti Mezon 120 or Castle Ice 100 ESC
Thunder Power 4s 4400mah G8 Performance Pro 45C x 2
Castle Pro BEC
Thunder Power 2s 2100mah G8 Pro-lite + 25C
Futaba 9157 servos on Elevator/Rudder
Futaba 9452 servos on Ailerons
Also needed to complete:
2x 12" extension for ailerons
2x 6" extensions from the receiver to the aileron servos
1x 24" extension for the elevator
2x 12" extensions for the ESC to Receiver (if electric)
2x 18" extensions will be needed for the throttle servo and ignition (if gas)
3" or 76mm spinner
Feb 13, 2015, 09:32 AM
Covering colors: (For Retro, Classic & Patriot)
True Red, HANU866
White, HANU870
Midnight Blue, HANU885
Black, HANU874
reserved2
Feb 13, 2015, 12:02 PM
House of Paine
weaser42's Avatar
This is my current favorite plane... that is all
Feb 13, 2015, 01:00 PM
"Thumbs"
Quiet E. Flyer's Avatar
Favorite pictures of the 73" Laser 230 at the 2015 Arizona Electric Festival
weaser42 takes great pictures too ......
Feb 13, 2015, 01:06 PM
House of Paine
weaser42's Avatar
The middle one was not my pic, the others probably are
Feb 13, 2015, 03:33 PM
"Thumbs"
Another one of your great shots of the 73"......
Correction: It is a shot of the 56" but still a great picture!
Feb 13, 2015, 04:15 PM
indywestrc & viehercfliers
Suds's Avatar
Originally Posted by Quiet E. Flyer
Another one your great shot of the 73"......
That looks like the 56"
Feb 13, 2015, 04:41 PM
"Thumbs"
My bad....you are probably right!! I may have to replace that picture in this thread!!
Feb 13, 2015, 06:02 PM
RC Addiction
c-182's Avatar
Here's mine.....great flying air frame !
Feb 13, 2015, 07:55 PM
I've started on the wings on mine! will update with pics to this thread as i go along!
cheers!
Feb 13, 2015, 08:51 PM
Suds's Avatar
73"er next to a 6' tall cyldesdale (aka mountain biker 200+ #) on a 45f degree February day in the midwest.
Feb 13, 2015, 08:53 PM
Huckin around the Shire
Enterprise7's Avatar
Just did a Jeti/Mezon update to mine. Ordered new arms for it as I used some leftover stuff that was way too big. My EPAs were in the 60s on the rudder.
Feb 14, 2015, 12:21 AM
Andrew Jesky's Avatar
Enterprise,
Do you have access to a Jeti Spinbox? If so you will want to program the controller to all the normal settings but the big one to change is the start power, it should be changed from Auto+0 to Auto+30 percent.
Andrew
Feb 14, 2015, 07:34 AM
I have the DS-16 radio so I can do that in the radio. I also have a Profi if I need to do changes otherwise. I am running the A60-8S, but I assume the setting is the same as the 5S. Timing is set to 15 and I think the manual says to run a higher setting.
Sold AJ Aircraft Laser 230Z 73" blunight Aircraft - Fuel - Airplanes (FS/W) 1 Feb 06, 2017 08:51 PM
Found AJ Aircraft Laser 230Z 73" NIB Steve_JR Aircraft - Fuel - Airplanes (FS/W) 3 Jul 10, 2016 09:13 AM
For Sale AJ Aircraft 73" Laser 230z in Competition NEW IN BOX PHC1 Aircraft - Fuel - Airplanes (FS/W) 1 May 10, 2016 07:39 AM
Sold AJ Aircraft 73" Laser 230z in Competition NEW IN BOX PHC1 Aircraft - Electric - Airplanes (FS/W) 0 May 08, 2016 01:23 PM
