This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Feb 01, 2018, 07:09 AM
Originally Posted by flavio martins
Hey FPV friends,
Is possible to use the the eagle tree GPS in a frsky telemetry without the vector? I have this GPS without use.
Tks
http://www.eagletreesystems.com/inde...=65&search=GPS
That Expander module communicates by I2C bus so you'll have a lot of work to get it communicating with FrSky.
You'd need to now the exact communications address ID and data protocol.
Geoff
Feb 14, 2018, 10:23 PM
Originally Posted by FPVV
Hey guys,
If someone looking to connect the New DJI goggles to vector Uart this is the way,
Has anyone found success with this setup? I have a MicroVector and the new DJI Googles Racing Edition with OcuSync Air System, and I have the two connected via UART as documented (Vector RX to OcuSync TX, and Vector TX to OcuSync RX). I have factory-reset my MicroVector, and configured its UART output mode to Taranis (which I'm assuming is SmartPort, that is supported by the OcuSync system).
Unfortunately, I have no readings showing (no voltage value, no artificial horizon data). Is there something additional that I must do to enable UART output on the MicroVector? Am I correct that "Taranis" UART mode is in fact using the SmartPort protocol? Is there anything else I can troubleshoot?
I'm using firmware 2.66 on my MicroVector. SBUS communication is working great, but zero results from UART.
Thanks for any help or advice! Much appreciated.
Feb 18, 2018, 12:55 PM
How to Display Vector telemetry on your Taranis radio
Hey FPV friends,
Tks
Hi Flavio,
Contrario to what Garris2 said, this (old) module I own doesn’t work on i2c like the new gps ET. I own this gps ET V4 mediatek (that was plug to osd pro via e logger v4) and it could work I think after change the rate to 1hz and 9600 bps.
I know it because I successfully plug in to arduplane 3.2.3 in gps type ‘auto’(1) with success.
GPS v4 wire:
- red Vcc
- white ground
- brown Rx
- yellow Tx
(Yes ! Brown is NOT the ground but Rx)
Default config is 38k.
This gps work really really well and fix is solid, far better than ublow. I really trust eagle tree hardware without issues at all.
Feb 19, 2018, 09:20 AM
My apologies to Flavio and Macfly, I thought Flavio was asking about the newer GPS modules.
Geoff
Apr 07, 2018, 05:04 AM
Hi,
did you find the solution ?
Pascal
May 04, 2018, 11:36 AM
So I wanted to give this a go so I can have some telemetry on my Taranis when not using FPV. My reciever is a X4R. Seems to be some conflicting info in this thread on whether or not it will work. Can someone confirm this works with full Vector and X4r? I dont want to go thru the trouble of building a cable for it and finding out it doesn't work correctly. Plus I'm running OpenTX 2.2 so there's that too.
Jun 27, 2018, 02:57 PM
martin19117's Avatar
connection to X4R to microvector
Originally Posted by dinuc
Photos !!
hi so the yellow connection from the X4R goes to the 2 wires orange & yellow on the vector? The black X4R goes to the black Wire on Vector.
Oct 29, 2018, 10:40 AM
Any news on this?
Originally Posted by maguet11020
Hi,
Pascal
Hi, any news on this?
Jan 12, 2019, 10:09 PM
Hello,
I flying with Frsky Taranis and i receive the telemetry from the vector (after i made a cable from Uart to S.port) on R9m receiver
The telemetry i got is:
Volt, A, Speed, Alt, GPS and more.
What i don't see is:
Hdg and mah (how much used) - but i still ok with that.
someone get something else?
Also,
The telemetry work with Delay! 2-3 sec
and the air speed receive the telemetry to the Taranis with delay.
I set up stall speed with alert on my Taranis and because the delay is not work perfect.
Now. on my second plane i have Frsky air speed sensor (that frsky made)
and is working perfect without any delay.
I tried to cancel the log to the SD (maybe is make delay) but no change.
Also, some times i "lost telemetry" then is back after a few sec
Please advise
Jan 13, 2019, 03:23 PM
ok, so after i did some test today i disconnected the vector from the R9M receiver and i connected the Frsky Air sensor - Work perfect.
So that mean the frsky system work fine. the delay come from the vector - 100% !
Jan 28, 2019, 01:42 AM
Yaapu LUA script
Will this work with Yaapu telemetry widget?
Jan 28, 2019, 01:44 AM
will this work with Yaapu LUA script?
Jan 28, 2019, 10:00 AM
No, ArduPilot telemetry protocol only
