Aug 17, 2016, 06:14 AM
XFM
XFM
eXperimental Flying Machines
Make floats by wrapping the landing gear with the packaging foam it came in.
Drowning problem solved
Aug 17, 2016, 06:42 AM
Now this is a tue rc multi . Looks perfectly safe.
Yep, the pilot is controlling it via a RC transmitter
how many 807s do I need to strap together to build one of these ?
skip to 1 minute in
Manned multirotor part 12 Flying and tuning in 1080p! (11 min 23 sec)
Aug 17, 2016, 07:18 AM
new2rc15
Originally Posted by canino
I dont go that far. Dunno about range. I went max 60 meters with it.
Did not try to connect with other tx. I have read that it was y.a.p.
Yes it can lift 808 and has headless and rth. You can go all ninja on it.
Dont you have one? Its pfretty much crash resistant.
Resistance is futile, all quads crash in my presence.
Originally Posted by 1101
Initially it would fall out of the sky, wobbled to death, on angle mode
So Ive turned angle strength right down, too far it seems.
I'll need to spend another night on it, its becoming more a personal challenge to get the thing flying now ,
My other brushed fpv micro's, with 'inferior' non adjustable boards, just work , as is
I never had this sort of pain , setting up naze boards in the brushless quads Ive had. Maybee my scisky board is a dud ?
My next built is here, 120mm brushless tarot frame . Its so small,so should have insane power with the 4000kv motors in it.
Ive ordered a ordered a micro fc/pdb F3 board for it.
shill...
http://www.banggood.com/Tarot-TL120H...p-1055476.html
and another shill, just cause you cant have too many JJRC1000's @ $12 each
http://www.gearbest.com/rc-quadcopte...#lkid=10097450
After all the time I spent getting my Scisky to arm, I would've taken my quadcopter hammer to it if it flew crappy
Originally Posted by haikss
Thanks for video Canino. It looks pretty good even better than u807 except the leds. If I knew its more durable than u807 I would buy. Sick of problems with nihui, either this or third nihui.
You guys and your nihui problems... Did you buy the 807 as a first quad too? See picture for solution
Originally Posted by SoloProFan
The quad for flying in the bathroom.
is the U807
Aug 17, 2016, 07:38 AM
new2rc15
skip to 1 minute in
https://www.youtube.com/watch?v=Uv5RigExyyQ
Is his seat part of an old arcade game? He should put a pusher motor on the back and call it the Screamer 250 plus. When is he gonna try acro?
Aug 17, 2016, 08:43 AM
We are not men, we are DEVO 7e
xanuser's Avatar
Faulty u807 - New. (0 min 15 sec)
Sigh.
Latest blog entry: MY notes/ Ascent 2"build notes
Aug 17, 2016, 09:37 AM
John Luciano's Avatar
Bad connection. Bad motor. Try spinning dead prop with your finger , see if it will start ? That will eliminate bad solder and then replace motor.
Manned multi rotor ? The Wright Bro's would be proud. Imagine if this catches on? It will be the Motorcycle of the future. They laughter at the Davis boys in 03. And Henry F in 27 and look we're that went . This may end up a commuter vehicle ,,!!
Aug 17, 2016, 10:39 AM
xanuser's Avatar
ran for about 30 seconds when i first tried to break in motors/gears at 30% throttle.
Probably bad solder or the motor is bad. Have to wait to hear from GB before I will take it apart to investigate.
Aug 17, 2016, 11:13 AM
I guess i was lucky with the u807s. Had 3 good units, sold the first 2 units (was short on cash).
Aug 17, 2016, 11:22 AM
Originally Posted by xanuser
Did you try calibrating gyros. Both sticks to the bottom left.
Aug 17, 2016, 12:06 PM
Xk x251 FPV
Great quad for begginers.
Im learning to fly FPV with it
Tuga Flyers (3 min 56 sec)
Aug 17, 2016, 12:11 PM
xanuser's Avatar
yep.
nope.
works for about a minute when first thing in the morning, but then after a few minutes of flying the motor stalls and just twitches.
when it does fly there's virtually no punch, and it veers to the side with bad motor. brand new 35-70c 600mah nanotech.
love BG... I cant open a trouble ticket yet, cause my "shipment is still in transit".
Aug 17, 2016, 12:28 PM
new2rc15
Unplug both counter-clockwise motors and take them out. Put the questionable one in the rear arm and test for spin up
Oh, and order some spare motors
Aug 17, 2016, 12:41 PM
xanuser's Avatar
yep. right after BG says they are going to replace or refund.
Aug 17, 2016, 12:45 PM
new2rc15
Good thinkin'
Aug 17, 2016, 01:33 PM
I think my final decision will be to buy an xk x251 and fly it a few months and then buy fpv for it
Mini-Review BOJIANG S1 Review (Nihui U807 Killer?) - [Setup, Flight Test, Pros & Cons] rc808hawaii Mini Multirotor Drones 20 Aug 07, 2018 04:32 PM
For Sale BRAND NEW Nihui U807 aggillator Aircraft - Electric - Multirotor (FS/W) 4 Nov 11, 2017 04:05 AM
Help! Taranis/4in1/Nihui U807/Flysky question landshark31 Beginner Multirotor Drones 0 Feb 02, 2017 12:29 AM
Help! Nihui U807 Quadcopter Not Pairing LuckyEarthling Beginner Multirotor Drones 3 Sep 22, 2015 06:52 PM
