This thread is privately moderated by fltekdiver, who may elect to delete unwanted replies.
Feb 07, 2015, 10:26 AM
Trader Rating: 127
$265.00 USD
Buyer pays shipping
Sold
Futaba 10JA10ch 2.4ghz fhss radio system tx rx w/ r3008sb
FUTABA 10JA 10CH 2.4GHZ FHSS RADIO SYSTEM TX RX W/ R3008SB
The Futaba 10JA has 10 Channels, Telemetry, Voice Output, Programmability with Multicopter programming
I will sell both the Futaba 10JA and R3008SB 8Ch receiver , Manual, wall charger, neck strap for $265.00 shipped
Here's the link to Futaba Website for the transmitter :
http://www.futaba-rc.com/systems/futk9200-10j/
10J
10-Channel 2.4GHz Computer Radio System
The 10J has it all!
Futaba consistently delivers the very best radios and the 10J is no exception. Its full list of features is below, but here are a few of the best: 10 channels, telemetry capable, fully programmable and user updateable. The functions can be assigned to a multitude sticks, switches, knobs and levers. The telemetry data can be viewed on the backlit LCD screen and audibly reported through headphones. Three buttons and a jog dial make it exceptionally easy to program. Plus, it's light weight, easy to handle and equipped with an astonishing 30 model memory. Updating is simple, so your transmitter will never be out of date.
All those features and more are included in a radio that's also the first to have multi-rotor helicopter programming. It's perfect for a whole host of applications: Airplane, helicopter, glider and multi-rotor menus are all included.
Even with all its features, the Futaba 10J is still the most inexpensive telemetry enabled radio system on the planet. It's priced right for a first time radio, but packed with so many features pros will love it as well.
When you're ready for a radio that can fly anything, comes packed with features and includes a powerful telemetry-enabled receiver, pick up the Futaba 10J. You'll be glad you did.
R3008SB receiver
T-FHSS
The R3008SB is a T-FHSS telemetry-capable receiver that features S.Bus and S.Bus2 compatibility and 8 conventional ports. The receiver also features an external battery voltage connector.
Free Software Download
Futaba 10J
S-FHSS S.Bus
Telemetry screen
The large backlit LCD display helps make programming easy, as well as clearly showing the timers and telemetry data.
spacer
•Futaba T-FHSS, S-FHSS 2.4GHz security
• Airplane, heli, glider and multi-rotor software
•30-model memory
•S.Bus capable T-FHSS receiver
•Telemetry
•Synthesized voice for telemetry data
•Vibration alerts for alarm conditions and low battery
•User-updatable software (requires optional CIU-2 interface)
•Wireless data transfer among 10J transmitters
•Built-in S.Bus programming link for S.Bus servos
•10-character model and user naming
•Large (128 x 64 dot) backlit LCD display
•10 channels (one variable knob, five 2-position switches, two 3-position switches, one momentary switch, two digital levers)
•Built-in diversity antenna
•Jog dial and 3 buttons for fast, easy programming
•Sub-trim and fail-safe (all channels)
•Servo reversing, endpoint adjustment, digital trims, dual rates/exponential* & ATL
•Trim step adjustability
•Trainer system
•Throttle cut
•2 count-up/-down timers + integrated timer
•Model timer
•Range check mode
•Servo cycle w/bar graph displays
•Assignable switch/lever/functions (Ch. 5-10)
spacer Airplane Features:
•6 programmable mixes, plus:
•9 factory-defined mixes
•Flaperons with differential rate
•Flap trim
•Differential ailerons
•Gyro sensitivity
•5-point throttle & pitch curves
•Throttle delay
•Idle down
Helicopter Features:
•10 factory-defined mixes
•8 swash plate types
•5 flight conditions w/delay
•Throttle curve (4 curves, 5 points)
•Pitch curve (5 curves, 5 points)
•Throttle hold & delay
•Swash AFR
•Electronic swash ring
spacer Glider Menu:
•3 factory-defined mixes
•5 wing types
•Gyro sensitivity
•Motor menu
•2 flight conditions
Multi-Rotor Menu:
•Gyro sensitivity/mixing
•Center stick alarm
Feb 08, 2015, 11:15 PM
Trader Rating: 0
i'll take this
Feb 08, 2015, 11:19 PM
Trader Rating: 127
No problem Eric, Thanks !
Feb 09, 2015, 06:44 PM
Trader Rating: 127
Thread back opened, never heard back from the buyer today
Feb 10, 2015, 10:36 AM
Trader Rating: 127
Sold , payment received from someone else !
