Feb 03, 2015, 06:35 AM
Isaiah 40:31
Clickety's Avatar
Build Log
Saab Viggen Pusher
Hi Guys,
Having built Steve Shumates Excellent Gripen (one of my favourites), I set about designing the jet it replaced, the Viggen. Another one of my favourites. I love the funky shape and the awesome camouflage patterns. I saw one fly at RAF waddington air show last year and made my mind up to add it to my design list.
SAAB VIGGEN Swedish Air Force Historic Flight At RAF Waddington Airshow 2013 (6 min 20 sec)
Its a slightly larger parkjet with a 700mm wingspan, as I'm going to put in a larger motor in it than my usual 2212-6 2200kv. Its the Turnigy 2836 on 4s. Hopefully should make it nice and fast! I modified the shaft on the stock item, by grinding a groove in it, and tapping it through to make it work as a pusher rather than the tractor configuration. There are a few links on Hobbykings website blog on how to do it Of course it should still fly with the 2212-6 motor.
https://www.hobbyking.com/hobbyking/s...er_2350kv.html
Plans are posted on my Blog :-
https://www.rcgroups.com/forums/member.php?u=435614
Feb 04, 2015, 09:02 AM
My favourite plane too
Originally Posted by Clickety
Hi Guys,
https://www.youtube.com/watch?v=TCP-bQpCoHc
I'm just finishing off the plans, and will be starting the build process soon. See plans etc attached.
Thank you for the plans,y like too much the camouflage pattern,an design of this beautiful plane.
Feb 04, 2015, 11:38 AM
Isaiah 40:31
Clickety's Avatar
Assembly Drawing
Nice Model CharlesFly!
I've uploaded the assembly drawing onto my blog page - click on my name to the left.
Build photos to follow as soon as I can....
Feb 07, 2015, 02:34 AM
Isaiah 40:31
Clickety's Avatar
Cnc cut parts arrived.... 1 tube of POR and 3 hours later.....(lot of parts are just rested in place)
Feb 09, 2015, 03:38 AM
Isaiah 40:31
Clickety's Avatar
Update....
Carbon and Electrics in....
Feb 10, 2015, 03:08 AM
Isaiah 40:31
Clickety's Avatar
Servos added and configured on the tx. Reinforcement strips added. Fuselage top glued on.
Feb 10, 2015, 04:57 PM
Isaiah 40:31
Clickety's Avatar
Elevons and canards added, slight sanding of the nose/canopy
Feb 11, 2015, 01:38 AM
Isaiah 40:31
Clickety's Avatar
Angled fuselage sides added - these will be sanded to a gentle radius.
Feb 11, 2015, 10:09 AM
plane_spotter's Avatar
Excellent work Clickety, nice to see something different.
Feb 11, 2015, 04:27 PM
Saab Viggen
Beautiful Job in this jet fighter,congratulations.I hope the maiden flight video
greetings from Colombia.
Feb 12, 2015, 03:31 AM
Isaiah 40:31
Clickety's Avatar
Thanks guys! I wish my workbench was a beautiful job!! Anyhow I connected and set up the canards, stuck together the turtledeck and rough sanded the plane with 120 grit to quickly get the approximate shape. I'll use finer papers as it gets closer to completion.
I also utilised a spent rocket stick to make the wing pitot tubes / hard point.
Feb 13, 2015, 05:09 PM
Isaiah 40:31
Clickety's Avatar
Progress...
Canopy fitted with magnets, control horns made from 3mm ply, elevon links connected and adjusted. Prop attached.
Currently a 3s 2200 mah battery sits squarely in the middle of the battery compartment and it hits the cg position. I feel I can get a 4s 2600 in there if I needed to.
Throws are quite large so I've dialed in 50% expo. Hope it's not too twitchy.
All prepped for the maiden. Hopefully Sunday.
Feb 13, 2015, 05:11 PM
Isaiah 40:31
Clickety's Avatar
Oh yes, I've got to add the elliptical air intakes in 3mm depron, but they can wait until after the maiden!
Feb 17, 2015, 05:57 AM
Isaiah 40:31
Clickety's Avatar
Didn't manage to maiden at the weekend due to putting my back out!
Hopefully next weekend!
Feb 20, 2015, 05:37 PM
Isaiah 40:31
Clickety's Avatar
Maiden tommorrow
Added 3mm air intakes and sanded the intersecting fuselage to shape
Feb 22, 2015, 12:04 PM
Isaiah 40:31
Clickety's Avatar
sadly, all ready to launch and had a ESC or RC issue, so it was a no-show I'll try and get it repaired the week all being well!
Feb 23, 2015, 07:28 PM
Beautiful Job
I hope the maiden flight,and start the mine.
Greetings
Carlos B
Feb 23, 2015, 08:09 PM
Isaiah 40:31
Clickety's Avatar
Thanks Carlos,
I discovered that the TX/RX had lost its bind. so I re-binded it and its just waiting for a clear day....
Feb 25, 2015, 03:51 PM
gs1
gs1
Good luck with the maiden, I really like the Swedish camo for the Viggen - any decisions for the colour scheme yet?
Feb 25, 2015, 05:53 PM
Isaiah 40:31
Clickety's Avatar
Hi Gareth, thanks buddy. yeah definately the camo scheme. Looks awesome!
Mar 07, 2015, 03:09 PM
Isaiah 40:31
Clickety's Avatar
Viggen Maiden
Success!
In the blustery winds, she was bounced around a bit, but once I had gotten the feel for her, I managed to feel confident enough to do some low passes, and then some high alpha hovering, in fact I had her going backwards against the wind, felt very comfortable in the air!
very pleased
First flight :-
viggen maiden flight (4 min 51 sec)
( I had gotten the hang of it by flight 4!)
Mar 08, 2015, 01:47 PM
Isaiah 40:31
Clickety's Avatar
Flew it another 4 times today, and I am very happy with it! very controllable! Thrilling high speed passes.
Mar 08, 2015, 03:21 PM
rajazo's Avatar
LOOKS AWESOME!!!
the viggen was a beauty plane... on my 10th birthday I received one airfix plastic model,I could not resist to send it to the air and make it fly... a complete disaster, but lot of fun on the unique "fly"...
perhaps this might be the time to do serious (35year later)...
congrats
Mar 08, 2015, 05:24 PM
Isaiah 40:31
Clickety's Avatar
Thanks Rajazo! Greetings from the UK!
Next step - finishing it!
Mar 08, 2015, 07:47 PM
Congratulations good flight and beatiful job in this Viggen,I hope building the mine.
Carlos B.
Mar 09, 2015, 01:10 AM
Isaiah 40:31
Clickety's Avatar
Thanks Carlos if you build it please post pics!
Nov 13, 2015, 09:03 AM
Isaiah 40:31
Clickety's Avatar
Scale Decals attached for splinter Camo scheme
Nov 15, 2015, 12:20 PM
Isaiah 40:31
Clickety's Avatar
Put balsa leading edges on and shaped the trailing edges. Applied lightweight filler all over and sanded smooth. Applied a base coat of paint to help reveal the surface quality.
Nov 15, 2015, 12:27 PM
Isaiah 40:31
Clickety's Avatar
This is the scheme I intend to replicate
Nov 15, 2015, 08:50 PM
killickb
killickb's Avatar
Nicely done. Are you using elevons and moveable canard? If so is canard mixed with the elevon for pitch control ?
Seems would be a handful using both independently for pitch.
